about the latest roms model
wrh
#1 Unread post by wrh »
when I run the latest version of roms ,I had the following problem:
oceanO: string.c:177: NC_check_name: Assertion `name != ((void *)0)' failed.
could you tell me what's wrong? thank you!
Re: about the latest roms model
#2 Unread post by arango »
It is very likely that you did not updated varinfo.dat for your application. New metadata variables were added for diagnostic variables. This is always documented as a warning in the trac tickets.
wrh
#3 Unread post by wrh »
yes now the model is ok ! thank you for your reply!
