when I run the latest version of roms ,I had the following problem:
oceanO: string.c:177: NC_check_name: Assertion `name != ((void *)0)' failed.
could you tell me what's wrong? thank you!
about the latest roms model
Re: about the latest roms model
It is very likely that you did not updated varinfo.dat for your application. New metadata variables were added for diagnostic variables. This is always documented as a warning in the trac tickets.
yes now the model is ok ! thank you for your reply!
