hi,
when i run ncgen,the error:
ncgen: Command not found.
when i run :
which ncdump
ncdump: Command not found.
which ncgen
however my linux server has an netcdf library,and it has ncdump and ncgen files
how to solve it?
thanks a lot!
How to setup ncgen?
Re: How to setup ncgen?
add the path where ncdump is in your ~home/.profile
Thank you very much!
I know yur mean. However, what's the command format? Can you tell me an example?
Thanks a lot!
Thanks a lot!
PATH=$PATH:home/thingumajig/netcdf_dir/bin
export PATH
Add these lines to your:
$HOME/.profile
$HOME/.bashrc
export PATH is probably already in there. In that case, just add the first line.
then from the command line
source .profile (or .bashrc)
ncdump and ncgen are programs from the NetCDF library and not ROMS
You need to find out where are those programs installed in you computer. There is plenty information in the wiki and in this forum about the NetCDF library.
You need to do some reading. You need to understand NetCDF pretty well before attempting to runs ROMS.
