How to setup ncgen?
duckweed
How to setup ncgen?
#1 Unread post by duckweed »
hi,
when i run ncgen,the error:
ncgen: Command not found.
when i run :
which ncdump
ncdump: Command not found.
which ncgen
however my linux server has an netcdf library,and it has ncdump and ncgen files
how to solve it?
thanks a lot!
jacopo
Re: How to setup ncgen?
#2 Unread post by jacopo »
add the path where ncdump is in your ~home/.profile
duckweed
#3 Unread post by duckweed »
Thank you very much!
I know yur mean. However, what's the command format? Can you tell me an example?
Thanks a lot!
jacopo
#4 Unread post by jacopo »
PATH=$PATH:home/thingumajig/netcdf_dir/bin
export PATH
home/thingumajig/netcdf_dir/bin is the dir where your ncdump/ncgen are, so modify the name according to where you put netcdf.
Add these lines to your:
$HOME/.profile
if you are a ksh or sh user
$HOME/.bashrc
if you are a bash user
export PATH is probably already in there. In that case, just add the first line.
then from the command line
source .profile (or .bashrc)
and try again with ncdump
#5 Unread post by arango »
ncdump and ncgen are programs from the NetCDF library and not ROMS :!: You need to find out where are those programs installed in you computer. There is plenty information in the wiki and in this forum about the NetCDF library.
:idea: You need to do some reading. You need to understand NetCDF pretty well before attempting to runs ROMS.
