Possible bug in Utility/normalization.F
hjsong
#1 Unread post by hjsong »
While working on correcting wind forcing in IS4DVAR, I found something suspicious.
Utility/normalization.F looks like
# if defined ADJUST_WSTRESS || defined ADJUST_STFLUX  (line 2236)
      IF (LwrtNRM(ifile,ng)) THEN                     (line 2244)
# endif                                               (line 2488)
# if defined ADJUST_STFLUX && defined SOLVE3D         (line 2489)
      END IF                                          (line 2636)
# endif                                               (line 2637)
So there will be an error if only 'ADJUST_WSTRESS' is defined.
I can see the same suspicious structure later in this code.
# if defined ADJUST_WSTRESS || defined ADJUST_STFLUX  (line 4527)
      IF (LwrtNRM(ifile,ng)) THEN                     (line 4535)
# endif                                               (line 4722)
# if defined ADJUST_STFLUX && defined SOLVE3D         (line 4724)
      END IF                                          (line 4855)
# endif                                               (line 4856)
I could be wrong, so please check this part.
Thank you.
Hajoon
Re: Possible bug in Utility/normalization.F
#2 Unread post by arango »
This was corrected several weeks ago. You need to update your code.
#3 Unread post by arango »
OK. This is a new one :oops: It only appeared when the ADJUST_WSTRESS is activated alone. Thank you for reporting this problem. This is now corrected in the following trac :arrow: ticket.
Please update :!:
hjsong
#4 Unread post by hjsong »
Dear Hernan,
Thank you.
I got that error when I turned on ONLY "ADJUST_WSTRESS".
I will update it!
Best,
Hajoon
