While working on correcting wind forcing in IS4DVAR, I found something suspicious.
Utility/normalization.F looks like
# if defined ADJUST_WSTRESS || defined ADJUST_STFLUX (line 2236)
IF (LwrtNRM(ifile,ng)) THEN (line 2244)
# endif (line 2488)
# if defined ADJUST_STFLUX && defined SOLVE3D (line 2489)
END IF (line 2636)
# endif (line 2637)
I can see the same suspicious structure later in this code.
# if defined ADJUST_WSTRESS || defined ADJUST_STFLUX (line 4527)
IF (LwrtNRM(ifile,ng)) THEN (line 4535)
# endif (line 4722)
# if defined ADJUST_STFLUX && defined SOLVE3D (line 4724)
END IF (line 4855)
# endif (line 4856)
Thank you.
Hajoon
