The simulation temperature is too high, and the output swrad and lwrad of the roms are too large
wanghaoyu
#1 Unread post by wanghaoyu »
I am a beginner in roms, and the temperature deviation in the simulation results is very large. Comparing the results of the thermal radiation flux input by forcing_file and the thermal radiation flux output by roms, it is found that there are large deviations in each heat flux. The swrad output by roms is about three times that of the swrad input by forcing_file, and the lwrad output by roms is also much larger than the lwrad input by forcing_file, but the spatial distribution has almost no relationship. Wonder what the cause of this problem is (forcing_file's data source is REA5) The time resolution of the forced field file is 1 hour。
Note: The absolute value of lwrad output by ROMs is larger than that of lwrad input by forcing_file
Thank you very much!
/*Model configuration OPTIONS:*/
#undef  SPHERICAL
#define CURVGRID      /* Define to compute the extra non-linear advection terms which arise when using curvilinear coordinates.*/
#define POWER_LAW      /* default */
#define K_GSCHEME      /* default */
#undef  FLOATS
#undef  FLOAT_VWALK
#undef  STATIONS
#define  SPLINES
#undef  WET_DRY
/* Grid and Initial */
#undef ANA_GRID
#undef ANA_INITIAL
/** OPTIONS associated with momentum equations:*/
#define UV_ADV       /*use to turn ON or OFF advection terms*/
#define UV_COR       /*use to turn ON or OFF Coriolis termV*/
#define UV_VIS2      /*use to turn ON or OFF harmonic horizontal mixing*/
/*Pressure gradient algorithm OPTIONS:*/
#define DJ_GRADPS      /* Pressure gradient options Define for splines density Jacobian */
/*OPTIONS associated with tracers equations: */
#define TS_DIF2        /*use to turn ON or OFF harmonic horizontal mixing*/
#undef  TS_DIF4
#undef  TS_U3HADVECTION
#undef  TS_C4VADVECTION
#define TS_MPDATA
#define NONLIN_EOS     /*use the nonlinear equation of state*/
#define SOLAR_SOURCE
#define QCORRECTION     /*Define to use the net heat flux correction.*/
#define SCORRECTION     /*Define to use freshwater flux correction.*/
#undef  SRELAXATION     /*Define to use salinity relaxation as a freshwater flux.*/
/*OPTIONS for horizontal mixing of momentum:*/
#undef  VISC_GRID
#define MIX_S_UV     /*use if mixing along constant S-surfaces*/
#undef  MIX_GEO_UV
/*OPTIONS for horizontal mixing of tracers: */
#define  DIFF_GRID     /* define */
#define  MIX_S_TS      /*use if mixing along constant S-surfaces*/
#undef MIX_GEO_TS      /* Mixing along geopotential (constant Z) surfaces */
/* Lateral boundary */
#undef RADIATION_2D          /* Define for tangential phase speed in radiation conditions*/
#undef SPONGE
/* bottom boundary layer */
#define UV_QDRAG     /* Define for quadratic bottom friction */
#undef UV_LOGDRAG    /* Define for logarithmic bottom friction*/
#undef UV_LDRAG      /* Define for linear bottom friction */
/* Real-time forced config.  */
#define BULK_FLUXES
#define DIURNAL_SRFLUX
#undef  LONGWAVE_OUT   /* Using computing OLR */
#define LONGWAVE
#define CLOUDS
#define EMINUSP        /* compute evaporation minus precipitation */
#define COOL_SKIN      /* lxc 191210  use if cool skin correction */
#undef  ANA_SSFLUX
#undef  ANA_STFLUX      /*use if analytical surface net heat flux*/
#undef ATM_PRESS
#define ANA_BTFLUX     /* analytical bottom temperature flux */
#define ANA_BSFLUX     /* analytical bottom salinity flux */
#undef  ANA_SMFLUX     /*use if analytical surface momentum stress*/
#undef  ANA_SRFLUX     /* analytic kinematic surface shortwave radiation */
/* Turbulence closure */
#define  MY25_MIXING    /* MY25_MIXING GLS_MIXING*/
#undef  GLS_MIXING
#undef  LMD_MIXING       /* Large/McWilliams/Doney interior mixing  KPP */
#define LIMIT_VDIFF
#define LIMIT_VVISC
#if defined GLS_MIXING || defined MY25_MIXING /* MY25_MIXING && GLS_MIXING */
# undef  CANUTO_A        /* Define for Canuto A-stability function formulation. */
# define KANTHA_CLAYSON /* Define for Kantha and Clayson stability function. */
# define K_C2ADVECTION   /* Define for 2th-order centered advection. */
# undef  K_C4ADVECTION   /* Define for 4th-order centered advection. */
# define N2S2_HORAVG    /* Define for horizontal smoothing of buoyancy/shear */
# undef CHARNOK        /* Define for Charnok surface roughness from wind stress*/
# undef CRAIG_BANNER   /* Define for Craig and Banner wave breaking surface flux.*/
# undef RI_SPLINES
# undef ZOS_HSIG        /* Define for surface roughness from wave amplitude. */
# undef TKE_WAVEDISS    /* Define for wave breaking surface flux from wave amplitude. */
#ifdef LMD_MIXING
# define LMD_RIMIX                             /* Add diffusivity due to shear instability */
# define LMD_CONVEC                            /* Add convective mixing due to shear instability */
# define LMD_DDMIX                             /* Add double-diffusive mixing */
# define LMD_SKPP                              /* KPP surface boundary layer mixing */
# define LMD_NONLOCAL                          /* LMD convective nonlocal transport */
# define LMD_SHAPIRO                           /* Shapiro filtering boundary layer depth */
# define LMD_BKPP                              /* KPP bottom boundary layer mixing */
# define RI_SPLINES                            /* Splines reconstruction for Richardson Number */
/* Climatology */
#define  TCLIMATOLOGY
#define  TCLM_NUDGING
#undef  ZCLIMATOLOGY
#undef  ZCLM_NUDGING
#undef  M2CLIMATOLOGY
#undef  M2CLM_NUDGING
#undef  M3CLIMATOLOGY
#undef  M3CLM_NUDGING
/* tide force */
#define RAMP_TIDES
#define SSH_TIDES
#define UV_TIDES
/* Tide boundary */
#ifdef SSH_TIDES
# define ADD_FSOBC
#ifdef UV_TIDES
# define ADD_M2OBC
/* river */
#undef UV_PSOURCE
#undef TS_PSOURCE
#undef Q_PSOURCE
/* Output */
#undef DIAGNOSTICS_TS
#undef DIAGNOSTICS_UV
#undef DIAGNOSTICS_BIO
#define AVERAGES     /*write out time-averaged model fields*/
 UPWELLING           Upwelling
 ADD_FSOBC           Adding tidal elevation to processed OBC data.
 ADD_M2OBC           Adding tidal currents to processed OBC data.
 ATM_PRESS           Impose atmospheric pressure onto sea surface.
 BULK_FLUXES         Surface bulk fluxes parameterization.
 COOL_SKIN           Surface cool skin correction.
 DIFF_GRID           Horizontal diffusion coefficient scaled by grid size.
 DIURNAL_SRFLUX      Modulate shortwave radiation by the local diurnal cycle.
 EMINUSP             Compute Salt Flux using E-P.
 LONGWAVE            Compute net longwave radiation internally.
 MIX_S_TS            Mixing of tracers along constant S-surfaces.
 MY25_MIXING         Mellor/Yamada Level-2.5 mixing closure.
 QCORRECTION         Surface net heat flux correction.
 K_C2ADVECTION       Second-order centered differences advection of TKE fields.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 RAMP_TIDES          Ramping tidal forcing for one day.
 SCORRECTION         Surface salinity flux correction.
 SOLAR_SOURCE        Solar Radiation Source Term.
 SSH_TIDES           Add tidal elevation to SSH climatology.
 TCLIMATOLOGY        Processing tracer climatology data.
 TCLM_NUDGING        Nudging toward tracer climatology.
 TS_MPDATA           Recursive flux corrected MPDATA 3D advection of tracers.
 TS_DIF2             Harmonic mixing of tracers.
 UV_TIDES            Add tidal currents to 2D momentum climatologies.
 Process Information:
 Node #  0 (pid=   73810) is active.
 Node # 23 (pid=   73833) is active.
 Node # 31 (pid=   73845) is active.
 Node #  7 (pid=   73817) is active.
 Node # 27 (pid=   73839) is active.
 Node #  1 (pid=   73811) is active.
 Node # 19 (pid=   73829) is active.
 Node #  3 (pid=   73813) is active.
 Node # 11 (pid=   73821) is active.
 Node # 15 (pid=   73825) is active.
 Node # 20 (pid=   73830) is active.
 Node # 28 (pid=   73840) is active.
 Node # 18 (pid=   73828) is active.
 Node # 21 (pid=   73831) is active.
 Node # 22 (pid=   73832) is active.
 Node # 24 (pid=   73835) is active.
 Node # 25 (pid=   73836) is active.
 Node # 26 (pid=   73837) is active.
 Node # 29 (pid=   73842) is active.
 Node # 30 (pid=   73843) is active.
 Node #  8 (pid=   73818) is active.
 Node #  9 (pid=   73819) is active.
 Node # 10 (pid=   73820) is active.
 Node # 12 (pid=   73822) is active.
 Node # 13 (pid=   73823) is active.
 Node # 14 (pid=   73824) is active.
 Node # 16 (pid=   73826) is active.
 Node # 17 (pid=   73827) is active.
 Node #  2 (pid=   73812) is active.
 Node #  4 (pid=   73814) is active.
 Node #  5 (pid=   73815) is active.
 Node #  6 (pid=   73816) is active.
 level   S-coord     Cs-curve   Z   at hmin       at hc    half way     at hmax
    30   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    29  -0.0333333  -0.0000142       -0.317      -3.335      -6.198      -6.473
    28  -0.0666667  -0.0000582       -0.635      -6.672     -12.464     -13.087
    27  -0.1000000  -0.0001359       -0.952     -10.014     -18.807     -19.860
    26  -0.1333333  -0.0002543       -1.270     -13.359     -25.243     -26.825
    25  -0.1666667  -0.0004242       -1.588     -16.709     -31.796     -34.034
    24  -0.2000000  -0.0006611       -1.905     -20.066     -38.502     -41.559
    23  -0.2333333  -0.0009863       -2.223     -23.432     -45.408     -49.501
    22  -0.2666667  -0.0014292       -2.540     -26.810     -52.583     -57.999
    21  -0.3000000  -0.0020301       -2.858     -30.203     -60.118     -67.243
    20  -0.3333333  -0.0028431       -3.176     -33.618     -68.136     -77.490
    19  -0.3666667  -0.0039419       -3.494     -37.061     -76.805     -89.086
    18  -0.4000000  -0.0054256       -3.812     -40.543     -86.350    -102.500
    17  -0.4333333  -0.0074279       -4.131     -44.076     -97.077    -118.364
    16  -0.4666667  -0.0101289       -4.449     -47.680    -109.395    -137.528
    15  -0.5000000  -0.0137708       -4.768     -51.377    -123.857    -161.136
    14  -0.5333333  -0.0186789       -5.088     -55.201    -141.203    -190.726
    13  -0.5666667  -0.0252893       -5.409     -59.196    -162.426    -228.356
    12  -0.6000000  -0.0341851       -5.731     -63.419    -188.855    -276.781
    11  -0.6333333  -0.0461435       -6.054     -67.948    -222.261    -339.672
    10  -0.6666667  -0.0621954       -6.379     -72.886    -264.990    -421.899
     9  -0.7000000  -0.0836996       -6.707     -78.370    -320.140    -529.879
     8  -0.7333333  -0.1124317       -7.038     -84.577    -391.753    -672.001
     7  -0.7666667  -0.1506842       -7.373     -91.735    -485.052    -859.091
     6  -0.8000000  -0.2013660       -7.715    -100.137    -606.664   -1104.891
     5  -0.8333333  -0.2680795       -8.064    -110.141    -764.793   -1426.416
     4  -0.8666667  -0.3551271       -8.423    -122.179    -969.240   -1843.989
     3  -0.9000000  -0.4673667       -8.794    -136.737   -1231.070   -2380.555
     2  -0.9333333  -0.6097911       -9.179    -154.312   -1561.657   -3059.698
     1  -0.9666667  -0.7866588       -9.581    -175.333   -1970.701   -3901.534
     0  -1.0000000  -1.0000000      -10.000    -200.000   -2462.825   -4915.651
 Time Splitting Weights for Grid 01:    ndtfast =  30    nfast =  42
 37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
 42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
 ndtfast, nfast =   30  42   nfast/ndtfast =  1.40000
 Power filter parameters, Fgamma, gamma =  0.28400   0.18933
 Minimum X-grid spacing, DXmin =  3.38578554E+00 km
 Maximum X-grid spacing, DXmax =  3.65036801E+00 km
 Minimum Y-grid spacing, DYmin =  3.38658696E+00 km
 Maximum Y-grid spacing, DYmax =  3.65036800E+00 km
 Minimum Z-grid spacing, DZmin =  3.17467091E-01 m
 Maximum Z-grid spacing, DZmax =  1.01411681E+03 m
 Minimum barotropic Courant Number =  7.69782170E-03
 Maximum barotropic Courant Number =  1.78402175E-01
 Maximum Coriolis   Courant Number =  3.56141826E-03
 Horizontal mixing scaled by grid size, GRDMAX =  3.65036801E+00 km
 NLM: GET_STATE - Read state initial conditions,             t = 13041 00:00:00
                   (Grid 01, File: roms_ini_bio_SEMES_Y2005M9D15.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min =  1.18048750E+00 Max =  3.21926625E+01)
                - salinity
                   (Min =  3.19417303E+00 Max =  3.51839344E+01)
    GET_NGFLD   - tidal period
                   (Min =  2.19720215E+04 Max =  2.38071489E+06)
    GET_2DFLD   - tidal elevation amplitude
                   (Min =  0.00000000E+00 Max =  1.51446960E+00)
    GET_2DFLD   - tidal elevation phase angle
                   (Min = -6.21520629E+00 Max =  6.26688145E+00)
    GET_2DFLD   - tidal current inclination angle
                   (Min =  0.00000000E+00 Max =  3.14159265E+00)
    GET_2DFLD   - tidal current phase angle
                   (Min =  0.00000000E+00 Max =  6.28317746E+00)
    GET_2DFLD   - maximum tidal current, ellipse major axis
                   (Min =  0.00000000E+00 Max =  1.31107979E+00)
    GET_2DFLD   - minimum tidal current, ellipse minor axis
                   (Min = -4.34316414E-01 Max =  4.28473644E-01)
    GET_2DFLD   - surface u-wind component,                  t = 13041 00:00:00
                   (Rec=0000337, Index=1, File: frc_TEST_ERA5_allflux_200509_ty.nc)
                   (Tmin=      13027.0000 Tmax=      13056.9583)
                   (Min = -1.20717460E+01 Max =  1.15309949E+01)
    GET_2DFLD   - surface v-wind component,                  t = 13041 00:00:00
                   (Min = -8.55017569E+00 Max =  6.63321643E+00)
    GET_2DFLD   - surface air pressure,                      t = 13041 00:00:00
                   (Min =  1.00601525E+03 Max =  1.02006424E+03)
    GET_2DFLD   - cloud fraction,                            t = 13041 00:00:00
                   (Rec=0006169, Index=1, File: frc_era5_cloud_a_2005.nc)
                   (Tmin=      12784.0000 Tmax=      13148.9583)
                   (Min =  1.00000000E+35 Max = -1.00000000E+35)
    GET_2DFLD   - solar shortwave radiation flux,            t = 13041 00:00:00
                   (Min =  3.55456141E-06 Max =  7.56122269E-05)
    GET_2DFLD   - surface air temperature,                   t = 13041 00:00:00
                   (Min =  1.95759433E+01 Max =  2.92698691E+01)
    GET_2DFLD   - surface air relative humidity,             t = 13041 00:00:00
                   (Min =  6.16344622E-01 Max =  9.89388249E-01)
    GET_2DFLD   - rain fall rate,                            t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  2.44368651E-03)
    GET_2DFLD   - sea surface temperature climatology,       t = 13039 00:00:00
                   (Rec=0000009, Index=1, File: frc_clim_SST_SSS_dqdsst_2005_n30.nc)
                   (Tmin=      12799.0000 Tmax=      13129.0000)
                   (Min =  2.72368069E+01 Max =  2.94101939E+01)
    GET_2DFLD   - surface net heat flux sensitivity to SST,  t = 13039 00:00:00
                   (Min = -1.18035124E-05 Max = -8.01556558E-06)
    GET_2DFLD   - sea surface salinity climatology,          t = 13039 00:00:00
                   (Min =  3.23880551E+01 Max =  3.44728087E+01)
    GET_NGFLD   - free-surface western boundary condition,   t = 13041 00:00:00
                   (Rec=0000258, Index=2, File: cemse_d_bry_bio_20050101_1030.nc)
                   (Tmin=      12784.0000 Tmax=      13086.0000)
                   (Min =  0.00000000E+00 Max =  6.83075905E-01)
    GET_NGFLD   - free-surface eastern boundary condition,   t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  1.06184626E+00)
    GET_NGFLD   - free-surface southern boundary condition,  t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  8.07825029E-01)
    GET_NGFLD   - free-surface northern boundary condition,  t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  7.11838961E-01)
    GET_NGFLD   - 2D u-momentum western boundary condition,  t = 13041 00:00:00
                   (Min = -7.70364627E-02 Max =  2.16668651E-01)
    GET_NGFLD   - 2D v-momentum western boundary condition,  t = 13041 00:00:00
                   (Min = -1.10341370E-01 Max =  1.27293915E-01)
    GET_NGFLD   - 2D u-momentum eastern boundary condition,  t = 13041 00:00:00
                   (Min = -1.22617400E+00 Max =  2.44689018E-01)
    GET_NGFLD   - 2D v-momentum eastern boundary condition,  t = 13041 00:00:00
                   (Min = -2.70071328E-01 Max =  3.30601603E-01)
    GET_NGFLD   - 2D u-momentum southern boundary condition, t = 13041 00:00:00
                   (Min = -1.20071493E-01 Max =  3.41540903E-01)
    GET_NGFLD   - 2D v-momentum southern boundary condition, t = 13041 00:00:00
                   (Min = -6.12512715E-02 Max =  2.34142378E-01)
    GET_NGFLD   - 2D u-momentum northern boundary condition, t = 13041 00:00:00
                   (Min = -1.86703995E-01 Max =  2.25412205E-01)
    GET_NGFLD   - 2D v-momentum northern boundary condition, t = 13041 00:00:00
                   (Min = -3.19934785E-02 Max =  3.11969817E-01)
    GET_NGFLD   - 3D u-momentum western boundary condition,  t = 13041 00:00:00
                   (Min = -2.74214387E-01 Max =  5.00771761E-01)
    GET_NGFLD   - 3D v-momentum western boundary condition,  t = 13041 00:00:00
                   (Min = -2.26046845E-01 Max =  2.55784631E-01)
    GET_NGFLD   - 3D u-momentum eastern boundary condition,  t = 13041 00:00:00
                   (Min = -1.45024538E+00 Max =  4.27845210E-01)
    GET_NGFLD   - 3D v-momentum eastern boundary condition,  t = 13041 00:00:00
                   (Min = -4.38443810E-01 Max =  1.00030279E+00)
    GET_NGFLD   - 3D u-momentum southern boundary condition, t = 13041 00:00:00
                   (Min = -2.54013419E-01 Max =  1.01482058E+00)
    GET_NGFLD   - 3D v-momentum southern boundary condition, t = 13041 00:00:00
                   (Min = -5.42362750E-01 Max =  3.69309217E-01)
    GET_NGFLD   - 3D u-momentum northern boundary condition, t = 13041 00:00:00
                   (Min = -5.86790502E-01 Max =  3.79205197E-01)
    GET_NGFLD   - 3D v-momentum northern boundary condition, t = 13041 00:00:00
                   (Min = -1.23156771E-01 Max =  9.98629451E-01)
    GET_NGFLD   - temperature western boundary condition,    t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  2.96491337E+01)
    GET_NGFLD   - salinity western boundary condition,       t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  3.47618828E+01)
    GET_NGFLD   - temperature eastern boundary condition,    t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  3.00593662E+01)
    GET_NGFLD   - salinity eastern boundary condition,       t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  3.48850174E+01)
    GET_NGFLD   - temperature southern boundary condition,   t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  2.98282223E+01)
    GET_NGFLD   - salinity southern boundary condition,      t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  3.47229156E+01)
    GET_NGFLD   - temperature northern boundary condition,   t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  2.93253021E+01)
    GET_NGFLD   - salinity northern boundary condition,      t = 13041 00:00:00
                   (Min =  0.00000000E+00 Max =  3.47413216E+01)
Average daily data of the first day of swrad output by roms
Average daily data of the first day of swrad output by forcing_file
Average daily data of the first day of lwrad output by roms
Average daily data of the first day of lwrad output by forcing_file
wenpuho
Re: The simulation temperature is too high, and the output swrad and lwrad of the roms are too large
#2 Unread post by wenpuho »
Nonlinear/bulk_flux.F would calculate longwave when #LONGWAVE or #LONGWAVE_OUT is defined; otherwise, you should provide longwave radiation flux (lwrad) in netcdf input.
For shortwave radiation flux, you need to provide it when define #SHORTWAVE (see Include/globaldef.h to check the condition requiring #SHORTWAVE) and there are two possible ways to provide it: 1. define #ANA_SRFLUX, roms would calculate srflx in ana_srflux subroutine, and the dependent surface variables would be according to which option is defined: #ALBEDO, #DIURNAL_SRFLUX, or nothing. Note that in this case you may or may not need the sward as input. 2. sward directly in the netcdf input without the above options.
That's why your output swrad feature was similar to the input (#DIURNAL_SRFLUX was defined, a function of lon, lat and day) and output lwrad was totally different (calculated by bulk_flux.F)
wanghaoyu
#3 Unread post by wanghaoyu »
Thank you very much for your reply. Just as you said, the output swrad is three times that of the forced field input swrad, because I have defined #DIURNAL_SRFLUX, but I still have a question about what operations swrad will undergo after roms defines DIURNAL_SRFLUX. What are the characteristics of the calculated temp (what is the difference from not defining #DIURNAL_SRFLUX)
wenpuho
#4 Unread post by wenpuho »
The subroutine ana_srflx.h documents how roms calculate shortwave radiation:
#if defined ALBEDO || defined DIURNAL_SRFLUX
!  Compute shortwave radiation (degC m/s):
!  ALBEDO option: Compute shortwave radiation flux using the Laevastu
!                 cloud correction to the Zillman equation for cloudless
!  radiation (Parkinson and Washington 1979, JGR, 84, 311-337).  Notice
!  that flux is scaled from W/m2 to degC m/s by dividing by (rho0*Cp).
!  DIURNAL_SRFLUX option: Modulate shortwave radiation SRFLX (which
!                         read and interpolated elsewhere) by the local
!  diurnal cycle (a function of longitude, latitude and day-of-year).
!  This option is provided for cases where SRFLX computed by SET_DATA is
!  an average over >= 24 hours. For "diurnal_srflux" to work ana_srflux
!  must be undefined. If you want a strictly analytical diurnal cycle
!  enter it explicitly at the end of this subroutine or use the "albedo"
!  option.
!  For a review of shortwave radiation formulations check:
!    Niemela, S., P. Raisanen, and H. Savijarvi, 2001: Comparison of
!      surface radiative flux parameterizations, Part II, Shortwave
!      radiation, Atmos. Res., 58, 141-154.
Namely, you have two choices when you need swrad to drive model and want to #undef DIURNAL_SRFLUX: define ALBEDO (see how roms computes srflx in ana_srflux.h) or provide swrad in netcdf forcing file; otherwise the model would report error.
The algorithm/formulation of calculating srflx between #define ALBEDO and DIURNAL_SRFLUX are two different things, the former one would compute according to the surface atmosphere variables (i.e., cloud, Hair, Tair and Pair), and the latter one reads the daily value and distributes this over an idealized diurnal cycle (see this topic:viewtopic.php?t=2930)
#5 Unread post by wilkin »
This is a good example of where going to the source code and reading the comments will answer your question.
First, how to find where in the code a CPP option is active? Try a recursive grep looking for that string
grep -r DIURNAL_SRFLUX .
./Functionals/ana_srflux.h:!  DIURNAL_SRFLUX option: Modulate shortwave radiation SRFLX (which
This uncovers a comment in ./Functionals/ana_srflux.h that seems to be relevant.
Open ana_srflux.h and search for DIURNAL_SRFLUX.
You find ...
!  option.
So, this tells you what the option is intended to do, and that it can only be applied to data that do not resolve the diurnal cycle. Continue browsing the file to learn more ...
# elif defined DIURNAL_SRFLUX
!  SRFLX is reset on each time step in subroutine SET_DATA which
!  interpolates values in the forcing file to the current date.
!  This DIURNAL_SRFLUX option is provided so that SRFLX values
!  corresponding to a greater or equal daily average can be modulated
!  by the local length of day to produce a diurnal cycle with the
!  same daily average as the original data.  This approach assumes
!  the net effect of clouds is incorporated into the SRFLX data.
!  Normalization = (1/2*pi)*INTEGRAL{ABS(a+b*COS(t)) dt}  from 0 to 2*pi
!                = (a*ARCCOS(-a/b)+SQRT(b**2-a**2))/pi    for |a| < |b|
If you read on in the code (admittedly, the further comments are minimal) you will see ....
            cff=(cff1*ACOS(-cff1/cff2)+SQRT(cff2*cff2-cff1*cff1))/pi
            srflx(i,j)=MAX(0.0_r8,                                      &
     &                     srflx(i,j)/cff*                              &
     &                     (cff1+cff2*COS(Hangle-lonr(i,j)*deg2rad)))
... and to understand that, you need to go back up to earlier code to figure out what cff1 and cff2 (the coefficients "a" and "b" in the formula) are.
!  Local daylight, GMT time zone, is a function of the declination
!  (Dangle) and hour angle adjusted for the local meridian
!  (Hangle-lonr(i,j)*deg2rad).
          LatRad=latr(i,j)*deg2rad
          cff1=SIN(LatRad)*SIN(Dangle)
          cff2=COS(LatRad)*COS(Dangle)
so now you can probably figure out that the integral limits "a" and "b" in the normalization refer to the local times of sunrise and sunset (there are special cases in the code for 24-hour polar day and polar night.
The code uses variable Hangle that was introduced for other purposes, so search further to see that
!  Compute hour angle (radians).
      Hangle=(12.0_r8-hour)*pi/12.0_r8
So, if you don't define DIURNAL_SRFLUX you get the default behavior of ROMS, which is to interpolate in time the values that were read from your input file at whatever times you set them to have.
wanghaoyu
#6 Unread post by wanghaoyu »
Thank you very much wilkin, your reply was very detailed and completely solved my problem. :lol:
