ERROR: Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.
Hello
I'm trying to model a local lake called Norsjø in ROMS.
When running ROMS I stumble over an error which my colleagues and I find quite difficult.
I represent the problem below:
Backtrace for this error:
#0 0x7f5fa7588d21 in ???
#1 0x7f5fa7587ef5 in ???
#2 0x7f5fa68e320f in ???
#3 0x5579f202d98c in omega_tile
at /home/markus/roms_project2/NORSJO2/Build_romsG/omega.f90:215
#4 0x5579f203880e in __omega_mod_MOD_omega
at /home/markus/roms_project2/NORSJO2/Build_romsG/omega.f90:73
#5 0x5579f1fa5c44 in initial_
at /home/markus/roms_project2/NORSJO2/Build_romsG/initial.f90:193
#6 0x5579f1f9bf26 in __roms_kernel_mod_MOD_roms_initialize
at /home/markus/roms_project2/NORSJO2/Build_romsG/roms_kernel.f90:131
#7 0x5579f1f9c20f in myroms
at /home/markus/roms_project2/NORSJO2/Build_romsG/master.f90:73
#8 0x5579f1f9ca38 in main
at /home/markus/roms_project2/NORSJO2/Build_romsG/master.f90:50
Floating point exception (core dumped)
How do I solve this feedback?
Markus
Markus
varinfo.dat
- (160.58 KiB) Downloaded 1116 times
roms_norsjo.in
- (152.5 KiB) Downloaded 1078 times
norsjo.h
- (5.42 KiB) Downloaded 1143 times
build_roms.sh
- (11.63 KiB) Downloaded 1278 times
- norsjo_init.nc
- (126.62 KiB) Downloaded 1107 times
- norsjo.nc
- (1.27 MiB) Downloaded 1131 times
- norsjo_forcing_it_grid.nc
- (80.38 MiB) Downloaded 1339 times
Re: ERROR: Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.
Can you show us what is on this line? Each person's omega.f90 can differ from the others due to differing cpp options./home/markus/roms_project2/NORSJO2/Build_romsG/omega.f90:215
I figured it out.
I had to change the h_min value in the grid-file from 0 meter to 1 meter (or another value unequal to 0).
Hello there,
I am a beginner in ROMS. After running ROMS, I have faced this error, and I cannot figure out what is the problem.
My files are attached. It would be great if you guide me.
Thank you for your time and help in advance.
GET_2DFLD_NF90 - surface u-wind component, 2000-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: lis_wind_era5.nc)
(Tmin= 0.0000 Tmax= 30.0000) t = 0.0000
(Min = 1.79217662E+00 Max = 2.23618578E+00) regrid = T
GET_2DFLD_NF90 - surface v-wind component, 2000-01-01 00:00:00.00
(Min = -2.25005922E+00 Max = -1.64221652E-01) regrid = T
GET_2DFLD_NF90 - surface air pressure, 2000-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: lis_Pair_era5.nc)
(Min = 1.02043787E+03 Max = 1.02062727E+03) regrid = T
GET_2DFLD_NF90 - net solar shortwave radiation flux, 2000-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: lis_swrad_era5.nc)
(Min = 2.11117475E-20 Max = 2.11117475E-20) regrid = T
GET_2DFLD_NF90 - downward longwave radiation flux, 2000-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: lis_lwrad_era5.nc)
(Min = 5.16123890E-05 Max = 5.60720697E-05) regrid = T
GET_2DFLD_NF90 - surface air temperature, 2000-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: lis_Tair_era5.nc)
(Min = -1.46856628E+00 Max = 1.07004069E+00) regrid = T
GET_2DFLD_NF90 - surface air relative humidity, 2000-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: lis_Qair_era5.nc)
(Min = 7.38970710E-01 Max = 8.75114982E-01) regrid = T
GET_2DFLD_NF90 - rain fall rate, 2000-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: lis_rain_era6.nc)
(Min = 1.00000001E-01 Max = 1.00000001E-01) regrid = T
#0 0x7faac4f67d21 in ???
#1 0x7faac4f66ef5 in ???
#2 0x7faac4c2e08f in ???
#3 0x5585a3907ed8 in __mod_netcdf_MOD_netcdf_get_fvar_1d
at /home/rbadpa/roms_project/reza/Build_romsG/mod_netcdf.f90:1845
#4 0x5585a3d1719f in get_ngfld_nf90_
at /home/rbadpa/roms_project/reza/Build_romsG/get_ngfld.f90:285
#5 0x5585a3d18fc6 in get_ngfld_
at /home/rbadpa/roms_project/reza/Build_romsG/get_ngfld.f90:82
#6 0x5585a39b600f in get_data_
at /home/rbadpa/roms_project/reza/Build_romsG/get_data.f90:214
#7 0x5585a31ef3b0 in initial_
at /home/rbadpa/roms_project/reza/Build_romsG/initial.f90:249
#8 0x5585a30b9cfe in __roms_kernel_mod_MOD_roms_initialize
at /home/rbadpa/roms_project/reza/Build_romsG/roms_kernel.f90:134
#9 0x5585a30b890a in myroms
at /home/rbadpa/roms_project/reza/Build_romsG/master.f90:75
#10 0x5585a30b8b43 in main
at /home/rbadpa/roms_project/reza/Build_romsG/master.f90:50
- varinfo.rar
- (19.61 KiB) Downloaded 966 times
- ROMS forcing file.rar
- (78.57 MiB) Downloaded 1506 times
mod_netcdf.f90
- (263.61 KiB) Downloaded 1071 times
- lisound_ini.nc
- (525.1 KiB) Downloaded 937 times
- lisound_bry.nc
- (1.11 MiB) Downloaded 953 times
lisound.in
- (155.64 KiB) Downloaded 1054 times
lisound.h
- (6.69 KiB) Downloaded 1226 times
The questions is - what does get_data.f90 want to read after the rain field? Is there something wrong with that file? Have you looked at that file with say ncview?
Dear Kate,
Thank you for your reply.
The first time, I checked the rain file, the magnitude was around 1.790271e-12. I have modified the magnitude, and again I received this error. I guessed maybe my header file has a problem, but I couldn't figure it out.
No, the rain file is fine. What file does get_data want to read after that for *your* case?
I did understand what you said. I checked the get_data file (attached), and it wants to read my boundary file. Apparently, the problem is related to bry file. I used matlab code to build the bry file by Mercator dataset.
get_data.f90
- (24.64 KiB) Downloaded 1094 times
- lisound_bry.nc
- (1.11 MiB) Downloaded 1046 times
According to your input file:
This is not the same size grid as your boundary file:
Also, the SE corner of your boundary conditions contain NaN values outside the domain. Then again, you have this:
so it might not actually be reading the boundary file.
Lm == 70 ! Number of I-direction INTERIOR RHO-points
Mm == 70 ! Number of J-direction INTERIOR RHO-points
N == 30 ! Number of vertical levels
netcdf lisound_bry {
dimensions:
xi_rho = 57 ;
xi_u = 56 ;
xi_v = 57 ;
eta_rho = 17 ;
eta_u = 17 ;
eta_v = 16 ;
s_rho = 15 ;
s_w = 16 ;
tracer = 2 ;
bry_time = UNLIMITED ; // (31 currently)
LBC(isFsur) == Clo Clo Clo Clo ! free-surface
LBC(isUbar) == Clo Clo Clo Clo ! 2D U-momentum
LBC(isVbar) == Clo Clo Clo Clo ! 2D V-momentum
LBC(isUvel) == Clo Clo Clo Clo ! 3D U-momentum
LBC(isVvel) == Clo Clo Clo Clo ! 3D V-momentum
LBC(isMtke) == Clo Clo Clo Clo ! mixing TKE
Thank you so much for checking my files. However, I think my input file that I uploaded here in my first question is:
And my boundary condition is:
I think the input you mentioned does not belong to me. I attached it here.
I am so grateful for your help.
Lm == 55 ! Number of I-direction INTERIOR RHO-points
Mm == 15 ! Number of J-direction INTERIOR RHO-points
N == 15 ! Number of vertical levels
LBC(isFsur) == Clo Che Che Clo ! free-surface
LBC(isUbar) == Clo Shc Shc Clo ! 2D U-momentum
LBC(isVbar) == Clo Shc Shc Clo ! 2D V-momentum
LBC(isUvel) == Clo Rad Rad Clo ! 3D U-momentum
LBC(isVvel) == Clo Rad Rad Clo ! 3D V-momentum
LBC(isTvar) == Clo Rad Rad Clo \ ! temperature
Clo Rad Rad Clo ! salinity
lisound.in
- (155.64 KiB) Downloaded 932 times
Dear Kate,
I checked zeta_east, and as you mentioned the SE corner of my boundary conditions contains NaN values outside the domain.
Thank you so much for your help.
Reza
Reza
