ERROR: Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.
markus.qs
#1 Unread post by markus.qs »
Hello
I'm trying to model a local lake called Norsjø in ROMS.
When running ROMS I stumble over an error which my colleagues and I find quite difficult.
I represent the problem below:
Backtrace for this error:
#0 0x7f5fa7588d21 in ???
#1 0x7f5fa7587ef5 in ???
#2 0x7f5fa68e320f in ???
#3 0x5579f202d98c in omega_tile
at /home/markus/roms_project2/NORSJO2/Build_romsG/omega.f90:215
#4 0x5579f203880e in __omega_mod_MOD_omega
at /home/markus/roms_project2/NORSJO2/Build_romsG/omega.f90:73
#5 0x5579f1fa5c44 in initial_
at /home/markus/roms_project2/NORSJO2/Build_romsG/initial.f90:193
#6 0x5579f1f9bf26 in __roms_kernel_mod_MOD_roms_initialize
at /home/markus/roms_project2/NORSJO2/Build_romsG/roms_kernel.f90:131
#7 0x5579f1f9c20f in myroms
at /home/markus/roms_project2/NORSJO2/Build_romsG/master.f90:73
#8 0x5579f1f9ca38 in main
at /home/markus/roms_project2/NORSJO2/Build_romsG/master.f90:50
Floating point exception (core dumped)
How do I solve this feedback?
Markus
varinfo.dat
(160.58 KiB) Downloaded 1110 times
roms_norsjo.in
(152.5 KiB) Downloaded 1070 times
norsjo.h
(5.42 KiB) Downloaded 1136 times
build_roms.sh
(11.63 KiB) Downloaded 1273 times
norsjo_init.nc
(126.62 KiB) Downloaded 1100 times
norsjo.nc
(1.27 MiB) Downloaded 1123 times
norsjo_forcing_it_grid.nc
(80.38 MiB) Downloaded 1334 times
Re: ERROR: Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.
Can you show us what is on this line? Each person's omega.f90 can differ from the others due to differing cpp options.
markus.qs
#3 Unread post by markus.qs »
I figured it out.
I had to change the h_min value in the grid-file from 0 meter to 1 meter (or another value unequal to 0).
badpa.reza
#4 Unread post by badpa.reza »
Hello there,
I am a beginner in ROMS. After running ROMS, I have faced this error, and I cannot figure out what is the problem.
GET_2DFLD_NF90   - surface u-wind component,                            2000-01-01 00:00:00.00
                      (Grid=01, Rec=1, Index=1, File: lis_wind_era5.nc)
                      (Tmin=          0.0000 Tmax=         30.0000)   t =          0.0000
                      (Min =  1.79217662E+00 Max =  2.23618578E+00)   regrid = T
  GET_2DFLD_NF90   - surface v-wind component,                            2000-01-01 00:00:00.00
                      (Min = -2.25005922E+00 Max = -1.64221652E-01)   regrid = T
  GET_2DFLD_NF90   - surface air pressure,                                2000-01-01 00:00:00.00
                      (Grid=01, Rec=1, Index=1, File: lis_Pair_era5.nc)
                      (Min =  1.02043787E+03 Max =  1.02062727E+03)   regrid = T
  GET_2DFLD_NF90   - net solar shortwave radiation flux,                  2000-01-01 00:00:00.00
                      (Grid=01, Rec=1, Index=1, File: lis_swrad_era5.nc)
                      (Min =  2.11117475E-20 Max =  2.11117475E-20)   regrid = T
  GET_2DFLD_NF90   - downward longwave radiation flux,                    2000-01-01 00:00:00.00
                      (Grid=01, Rec=1, Index=1, File: lis_lwrad_era5.nc)
                      (Min =  5.16123890E-05 Max =  5.60720697E-05)   regrid = T
  GET_2DFLD_NF90   - surface air temperature,                             2000-01-01 00:00:00.00
                      (Grid=01, Rec=1, Index=1, File: lis_Tair_era5.nc)
                      (Min = -1.46856628E+00 Max =  1.07004069E+00)   regrid = T
  GET_2DFLD_NF90   - surface air relative humidity,                       2000-01-01 00:00:00.00
                      (Grid=01, Rec=1, Index=1, File: lis_Qair_era5.nc)
                      (Min =  7.38970710E-01 Max =  8.75114982E-01)   regrid = T
  GET_2DFLD_NF90   - rain fall rate,                                      2000-01-01 00:00:00.00
                      (Grid=01, Rec=1, Index=1, File: lis_rain_era6.nc)
                      (Min =  1.00000001E-01 Max =  1.00000001E-01)   regrid = T
#0  0x7faac4f67d21 in ???
#1  0x7faac4f66ef5 in ???
#2  0x7faac4c2e08f in ???
#3  0x5585a3907ed8 in __mod_netcdf_MOD_netcdf_get_fvar_1d
        at /home/rbadpa/roms_project/reza/Build_romsG/mod_netcdf.f90:1845
#4  0x5585a3d1719f in get_ngfld_nf90_
        at /home/rbadpa/roms_project/reza/Build_romsG/get_ngfld.f90:285
#5  0x5585a3d18fc6 in get_ngfld_
        at /home/rbadpa/roms_project/reza/Build_romsG/get_ngfld.f90:82
#6  0x5585a39b600f in get_data_
        at /home/rbadpa/roms_project/reza/Build_romsG/get_data.f90:214
#7  0x5585a31ef3b0 in initial_
        at /home/rbadpa/roms_project/reza/Build_romsG/initial.f90:249
#8  0x5585a30b9cfe in __roms_kernel_mod_MOD_roms_initialize
        at /home/rbadpa/roms_project/reza/Build_romsG/roms_kernel.f90:134
#9  0x5585a30b890a in myroms
        at /home/rbadpa/roms_project/reza/Build_romsG/master.f90:75
#10  0x5585a30b8b43 in main
        at /home/rbadpa/roms_project/reza/Build_romsG/master.f90:50
My files are attached. It would be great if you guide me.
Thank you for your time and help in advance.
varinfo.rar
(19.61 KiB) Downloaded 959 times
ROMS forcing file.rar
(78.57 MiB) Downloaded 1499 times
mod_netcdf.f90
(263.61 KiB) Downloaded 1064 times
lisound_ini.nc
(525.1 KiB) Downloaded 931 times
lisound_bry.nc
(1.11 MiB) Downloaded 944 times
lisound.in
(155.64 KiB) Downloaded 1048 times
lisound.h
(6.69 KiB) Downloaded 1219 times
#5 Unread post by kate »
The questions is - what does get_data.f90 want to read after the rain field? Is there something wrong with that file? Have you looked at that file with say ncview?
badpa.reza
#6 Unread post by badpa.reza »
Dear Kate,
Thank you for your reply.
The first time, I checked the rain file, the magnitude was around 1.790271e-12. I have modified the magnitude, and again I received this error. I guessed maybe my header file has a problem, but I couldn't figure it out.
#7 Unread post by kate »
No, the rain file is fine. What file does get_data want to read after that for *your* case?
badpa.reza
#8 Unread post by badpa.reza »
I did understand what you said. I checked the get_data file (attached), and it wants to read my boundary file. Apparently, the problem is related to bry file. I used matlab code to build the bry file by Mercator dataset.
get_data.f90
(24.64 KiB) Downloaded 1088 times
lisound_bry.nc
(1.11 MiB) Downloaded 1039 times
#9 Unread post by kate »
According to your input file:
          Lm == 70	           ! Number of I-direction INTERIOR RHO-points
          Mm == 70           ! Number of J-direction INTERIOR RHO-points
           N == 30            ! Number of vertical levels
This is not the same size grid as your boundary file:
netcdf lisound_bry {
dimensions:
	xi_rho = 57 ;
	xi_u = 56 ;
	xi_v = 57 ;
	eta_rho = 17 ;
	eta_u = 17 ;
	eta_v = 16 ;
	s_rho = 15 ;
	s_w = 16 ;
	tracer = 2 ;
	bry_time = UNLIMITED ; // (31 currently)
Also, the SE corner of your boundary conditions contain NaN values outside the domain. Then again, you have this:
   LBC(isFsur) ==   Clo     Clo     Clo     Clo         ! free-surface
   LBC(isUbar) ==   Clo     Clo     Clo     Clo         ! 2D U-momentum
   LBC(isVbar) ==   Clo     Clo     Clo     Clo         ! 2D V-momentum
   LBC(isUvel) ==   Clo     Clo     Clo     Clo         ! 3D U-momentum
   LBC(isVvel) ==   Clo     Clo     Clo     Clo         ! 3D V-momentum
   LBC(isMtke) ==   Clo     Clo     Clo     Clo         ! mixing TKE
so it might not actually be reading the boundary file.
badpa.reza
#10 Unread post by badpa.reza »
Thank you so much for checking my files. However, I think my input file that I uploaded here in my first question is:
          Lm == 55            ! Number of I-direction INTERIOR RHO-points
          Mm == 15            ! Number of J-direction INTERIOR RHO-points
           N == 15            ! Number of vertical levels
And my boundary condition is:
LBC(isFsur) ==   Clo     Che     Che     Clo         ! free-surface
   LBC(isUbar) ==   Clo     Shc     Shc     Clo         ! 2D U-momentum
   LBC(isVbar) ==   Clo     Shc     Shc     Clo         ! 2D V-momentum
   LBC(isUvel) ==   Clo     Rad     Rad     Clo         ! 3D U-momentum
   LBC(isVvel) ==   Clo     Rad     Rad     Clo         ! 3D V-momentum
   LBC(isTvar) ==   Clo     Rad     Rad     Clo \       ! temperature
                           Clo     Rad     Rad     Clo         ! salinity
I think the input you mentioned does not belong to me. I attached it here.
I am so grateful for your help.
lisound.in
(155.64 KiB) Downloaded 926 times
badpa.reza
#11 Unread post by badpa.reza »
Dear Kate,
I checked zeta_east, and as you mentioned the SE corner of my boundary conditions contains NaN values outside the domain.
Thank you so much for your help.
Reza
