Creating initial field, boundary field files from grid files
zhaolv
Location: Changsha University of Science and Technology
#1 Unread post by zhaolv »
HI!
I have a question now. Why some grid files have all zero data in clm and bdy files when creating initial and boundary files? Including u, v, temp, salt and other data.
I am currently using the GridBuilder program to create the grid. However, I have found that the grid files generated using this program have zero data for u, v, temp etc. when creating the primary boundary file.
I'm sure it's not a network fluctuation problem because when I create the grid using the method in COAWST, the data is present in the regenerated primary boundary file.The time period I used was 13-17 September 2018
I have placed the grid generated by my GridBuilder below in the hope that you can help me.
Grid_Builder_roms.zip
(4.6 MiB) Downloaded 212 times
zhaolv
Re: Creating initial field, boundary field files from grid files
#2 Unread post by zhaolv »
Does anyone know what the cause is, please?
#3 Unread post by kate »
You haven't told us which tools you are using to generate initial and boundary files. Impossible to say from here what's wrong.
zhaolv
#4 Unread post by zhaolv »
I'm sorry that I didn't explain myself clearly. I am using the method in coawst. Use the file "roms_master_climatology_coawst_mw.m". I have placed the file below.
Thank you for your guidance.
Roms_master_climatology_coawst_mw.m
(7.2 KiB) Downloaded 212 times
