HI!
I have a question now. Why some grid files have all zero data in clm and bdy files when creating initial and boundary files? Including u, v, temp, salt and other data.
I am currently using the GridBuilder program to create the grid. However, I have found that the grid files generated using this program have zero data for u, v, temp etc. when creating the primary boundary file.
I'm sure it's not a network fluctuation problem because when I create the grid using the method in COAWST, the data is present in the regenerated primary boundary file.The time period I used was 13-17 September 2018
I have placed the grid generated by my GridBuilder below in the hope that you can help me.
Creating initial field, boundary field files from grid files
- Location: Changsha University of Science and Technology
- Grid_Builder_roms.zip
- (4.6 MiB) Downloaded 765 times
Re: Creating initial field, boundary field files from grid files
Does anyone know what the cause is, please?
You haven't told us which tools you are using to generate initial and boundary files. Impossible to say from here what's wrong.
I'm sorry that I didn't explain myself clearly. I am using the method in coawst. Use the file "roms_master_climatology_coawst_mw.m". I have placed the file below.
Thank you for your guidance.
Roms_master_climatology_coawst_mw.m
- (7.2 KiB) Downloaded 779 times
