Wrong Temperature and salinity outputs
javadi
#1 Unread post by javadi »
Dear Users,
I ran the model for 6 years with this .h. The result does not show proper vertical temperature and salinity.Here I compare with observation. I try to model the temperature, salinity, and circulation of my domain. How to solve this problem?
Please help me with your interesting comments.
#define UV_LDRAG
#undef MIX_GEO_UV
#define SPLINES_VDIFF
#define SPLINES_VVISC
#undef TS_DIF4
#undef MIX_GEO_TS
#define MIX_S_TS
#define DIAGNOSTICS_TS
#define DIAGNOSTICS_UV
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
# define LMD_MIXING
# ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# define LI_FOX_KEMPER
# undef LMD_BKPP
# define LMD_NONLOCAL
# define LMD_SHAPIRO
# define LMD_DDMIX
# define LIMIT_VDIFF
#if defined BIO_FENNEL || defined ECOSIM || \
defined NPZD_POWELL || defined NEMURO
# define ANA_BIOLOGY
# define ANA_SPFLUX
# define ANA_BPFLUX
# define ANA_SRFLUX
#if defined NEMURO
# define HOLLING_GRAZING
# undef IVLEV_EXPLICIT
#ifdef BIO_FENNEL
# define CARBON
# define DENITRIFICATION
# define BIO_SEDIMENT
# define DIAGNOSTICS_BIO
#undef ANA_PSOURCE
#ifdef PERFECT_RESTART
# undef AVERAGES
# undef DIAGNOSTICS_BIO
# undef DIAGNOSTICS_TS
# undef DIAGNOSTICS_UV
# define OUT_DOUBLE
Re: Wrong Temperature and salinity outputs
Your model is salty at the surface when it should be fresh. What are you using for fresh water forcing?
javadi
#3 Unread post by javadi »
I used river runoff when activating #undef ANA_PSOURCE. Also, I think that the model has a problem in flux too as the water is a little cooler than observation. I think that the model has a problem with vertical forcing and fluxes.
So how are you forcing it? You have:
#define ANA_STFLUX
#define ANA_SSFLUX
Are these set to zero or something reasonable?
Note that I have been using BULK_FLUXES (with CCSM_FLUXES) and atmospheric reanalysis fields for over a decade now.
javadi
#5 Unread post by javadi »
Dear Kate
Thanks for your response.
I try to model the temperature, salinity, density, and water circulation(eddies) of my domain, not biology work . Based on your response, I have reviewed your application at Github(Apps-master). I have changed my upwelling.h file. here is the new one. Is it ok?
#define UV_LDRAG
#undef MIX_GEO_UV
#undef TS_DIF4
#undef MIX_GEO_TS
#define MIX_S_TS
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_SMFLUX
# define LMD_MIXING
# ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# undef LMD_BKPP
# define LMD_DDMIX
# undef GLS_MIXING
# undef MY25_MIXING
# if defined GLS_MIXING || defined MY25_MIXING
#ifdef SOLVE3D
# define CORE_FORCING
# define BULK_FLUXES
# define CCSM_FLUXES
# if defined BULK_FLUXES || defined CCSM_FLUXES
# define LONGWAVE_OUT
# define DIURNAL_SRFLUX
# define EMINUSP
# undef ANA_SRFLUX
# undef ALBEDO_CLOUD
# define ALBEDO_CURVE
# undef LONGWAVE
#undef ANA_PSOURCE
# undef AVERAGES
#6 Unread post by kate »
#define MIX_S_TS
This is OK if your bottom is flat, otherwise it leads to mixing along s-surfaces which can be unrealistic. I don't see anything else wrong, but I could be missing something, who knows.
javadi
#7 Unread post by javadi »
Dear Kate
Thanks!
When omitting #define MIX_S_TS, I have faced this error :
18 | T3DMIX: must define one of MIX_S_TS, MIX_GEO_TS, MIX_ISO_TS
| 1
Error: Unclassifiable statement at (1)
t3dmix.f90:16:20:
javadi
#8 Unread post by javadi »
I have defined #defined MIX_GEO_TS and compile the model successfully. The model works correctly for one month but at the end of each month, we have faced an error. For example, when the model starts in January, the model has faced problems on 31 January. While I started in February, the model has faced an error on the 28 February(the same time). The error is
5899 2013-02-28 10:26:40.00 3.282258E-03 3.203207E+03 3.203210E+03 5.412928E+13
(043,146,01) 4.822500E-02 4.499562E-02 5.208305E-01 8.471538E-01
GET_2DFLD - solar shortwave radiation flux, 2013-02-28 13:30:00.00
(Grid=01, Rec=469, Index=1, File: gom_swrad_era1.nc)
(Tmin= -31.0625 Tmax= 333.8125) t = 27.4375
(Min = 1.27788394E-05 Max = 2.53744384E-05) regrid = T
GET_2DFLD - downwelling longwave radiation flux, 2013-02-01 01:30:00.00
(Grid=01, Rec=306, Index=1, File: gom_lwrad_era1.nc)
(Tmin= -31.1875 Tmax= 333.8125) t = -0.0625
(Min = 6.20185804E-05 Max = 8.34224417E-05) regrid = T
GET_2DFLD - rain fall rate, 2013-02-28 13:30:00.00
(Grid=01, Rec=469, Index=1, File: gom_rain_era1.nc)
(Min = -6.10111224E-12 Max = 1.87287573E-05) regrid = T
SET_2DFLD - current model time exceeds ending value for variable: lwrad_down
TDAYS = 27.3148
Data Tmin = -31.1875 Data Tmax = 333.8125
Data Tstr = -0.1875 Data Tend = 0.3125
TINTRP1 = 27.3125 TINTRP2 = -0.0625
FAC1 = -27.3773 FAC2 = 0.0023
Found Error: 02 Line: 319 Source: ROMS/Nonlinear/set_data.F, set_data_tile
Found Error: 02 Line: 222 Source: ROMS/Nonlinear/main3d.F
Found Error: 02 Line: 302 Source: ROMS/Drivers/nl_ocean.h, ROMS_run
#9 Unread post by kate »
You have only one month of forcing per file? You can string them together in the roms.in file. I have my forcing files with one year each and string them together from one year to the next:
NFFILES == 14 ! number of forcing files
FRCNAME == /center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Pair_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Pair_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Qair_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Qair_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Tair_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Tair_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_rain_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_rain_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_snow_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_snow_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_swrad_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_swrad_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_lwrad_down_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_lwrad_down_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Uwind_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Uwind_2016.nc \
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Vwind_2015.nc |
/center1/AKWATERS/kate/JRA55-do/JRA55DO_1.4_Vwind_2016.nc \
/center1/AKWATERS/kshedstrom/CORE2/sss_fill_2004.nc \
/center1/AKWATERS/kshedstrom/Arctic/Files/iron_sediment_ARCTIC4.nc \
/center1/AKWATERS/kshedstrom/Chukchi/Files/Mineral_Fe_Flux_PI_ROMS.nc \
/center1/AKWATERS/kshedstrom/Chukchi/Files/Soluble_Fe_Flux_PI_ROMS.nc \
/center1/AKWATERS/kshedstrom/Arctic/Files/atm_CO2_Arctic.nc
javadi
#10 Unread post by javadi »
No. I think that this is ok. I have downloaded from ECMWF and merge months. Like this, is it ok? maybe, the time is a problem?
NFFILES == 13 ! number of unique forcing files
FRCNAME == /media/java/G/2013/gom_cloud_era1.nc |
/media/java/G/2014/gom_cloud_era2.nc |
/media/java/G/2015/gom_cloud_era_3.nc |
/media/java/G/2016/gom_cloud_era_4.nc |
/media/java/G/2017/gom_cloud_era_5.nc |
/media/java/G/2018/gom_cloud_era_6.nc \
/media/java/G/2013/gom_latent_era1.nc |
/media/java/G/2014/gom_latent_era2.nc |
/media/java/G/2015/gom_latent_era_3.nc |
/media/java/G/2016/gom_latent_era_4.nc |
/media/java/G/2017/gom_latent_era_5.nc |
/media/java/G/2018/gom_latent_era_6.nc \
/media/java/G/2013/gom_lwrad_era1.nc |
/media/java/G/2014/gom_lwrad_era2.nc |
/media/java/G/2015/gom_lwrad_era_3.nc |
/media/java/G/2016/gom_lwrad_era_4.nc |
/media/java/G/2017/gom_lwrad_era_5.nc |
/media/java/G/2018/gom_lwrad_era_6.nc \
/media/java/G/2013/gom_Pair_era1.nc |
/media/java/G/2014/gom_Pair_era2.nc |
/media/java/G/2015/gom_Pair_era_3.nc |
/media/java/G/2016/gom_Pair_era_4.nc |
/media/java/G/2017/gom_Pair_era_5.nc |
/media/java/G/2018/gom_Pair_era_6.nc \
/media/java/G/2013/gom_Qair_era1.nc |
/media/java/G/2014/gom_Qair_era2.nc |
/media/java/G/2015/gom_Qair_era_3.nc |
/media/java/G/2016/gom_Qair_era_4.nc |
/media/java/G/2017/gom_Qair_era_5.nc |
/media/java/G/2018/gom_Qair_era_6.nc \
/media/java/G/2013/gom_rain_era1.nc |
/media/java/G/2014/gom_rain_era2.nc |
/media/java/G/2015/gom_rain_era_3.nc |
/media/java/G/2016/gom_rain_era_4.nc |
/media/java/G/2017/gom_rain_era_5.nc |
/media/java/G/2018/gom_rain_era_6.nc \
/media/java/G/2013/gom_sensible_era1.nc |
/media/java/G/2014/gom_sensible_era2.nc |
/media/java/G/2015/gom_sensible_era_3.nc |
/media/java/G/2016/gom_sensible_era_4.nc |
/media/java/G/2017/gom_sensible_era_5.nc |
/media/java/G/2018/gom_sensible_era_6.nc \
/media/java/G/2013/gom_shflux_era1.nc |
/media/java/G/2014/gom_shflux_era2.nc |
/media/java/G/2015/gom_shflux_era_3.nc |
/media/java/G/2016/gom_shflux_era_4.nc |
/media/java/G/2017/gom_shflux_era_5.nc |
/media/java/G/2018/gom_shflux_era_6.nc \
/media/java/G/2013/gom_sms_era1.nc |
/media/java/G/2014/gom_sms_era2.nc |
/media/java/G/2015/gom_sms_era_3.nc |
/media/java/G/2016/gom_sms_era_4.nc |
/media/java/G/2017/gom_sms_era_5.nc |
/media/java/G/2018/gom_sms_era_6.nc \
/media/java/G/2013/gom_swflux_era1.nc |
/media/java/G/2014/gom_swflux_era2.nc |
/media/java/G/2015/gom_swflux_era_3.nc |
/media/java/G/2016/gom_swflux_era_4.nc |
/media/java/G/2017/gom_swflux_era_5.nc |
/media/java/G/2018/gom_swflux_era_6.nc \
/media/java/G/2013/gom_swrad_era1.nc |
/media/java/G/2014/gom_swrad_era2.nc |
/media/java/G/2015/gom_swrad_era_3.nc |
/media/java/G/2016/gom_swrad_era_4.nc |
/media/java/G/2017/gom_swrad_era_5.nc |
/media/java/G/2018/gom_swrad_era_6.nc \
/media/java/G/2013/gom_Tair_era1.nc |
/media/java/G/2014/gom_Tair_era2.nc |
/media/java/G/2015/gom_Tair_era_3.nc |
/media/java/G/2016/gom_Tair_era_4.nc |
/media/java/G/2017/gom_Tair_era_5.nc |
/media/java/G/2018/gom_Tair_era_6.nc \
/media/java/G/2013/gom_wind_era1.nc |
/media/java/G/2014/gom_wind_era2.nc |
/media/java/G/2015/gom_wind_era_3.nc |
/media/java/G/2016/gom_wind_era_4.nc |
/media/java/G/2017/gom_wind_era_5.nc |
/media/java/G/2018/gom_wind_era_6.nc
#11 Unread post by kate »
What is the time variable like in one of these things? You need one common time origin for *everything*.
javadi
#12 Unread post by javadi »
I use ecmwf2roms Matlab manuscript to make forcing. I use
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 20130101.5d0 ! yyyymmdd.dd
I do not know but we have different times for each variable.
GET_2DFLD - solar shortwave radiation flux, 2013-01-31 13:30:00.00
(Grid=01, Rec=245, Index=2, File: gom_swrad_era1.nc)
(Tmin= -0.4375 Tmax= 364.4375) t = 30.0625
(Min = 3.14134142E-06 Max = 1.27237242E-05) regrid = T
GET_2DFLD - downwelling longwave radiation flux, 2013-01-01 01:30:00.00
(Grid=01, Rec=63, Index=2, File: gom_lwrad_era1.nc)
(Tmin= -0.5625 Tmax= 364.4375) t = -0.4375
(Min = 4.50244663E-05 Max = 7.58182375E-05) regrid = T
GET_2DFLD - rain fall rate, 2013-01-31 13:30:00.00
(Grid=01, Rec=245, Index=2, File: gom_rain_era1.nc)
(Min = -4.18313908E-12 Max = 1.64248631E-04) regrid = T
GET_2DFLD - surface air temperature, 2013-01-31 12:00:00.00
(Grid=01, Rec=62, Index=2, File: gom_Tair_era1.nc)
(Tmin= -0.5000 Tmax= 364.5000) t = 30.0000
(Min = 4.37862444E+00 Max = 1.65629877E+01) regrid = T
GET_2DFLD - surface air relative humidity, 2013-01-31 12:00:00.00
(Grid=01, Rec=62, Index=2, File: gom_Qair_era1.nc)
(Min = 3.99281480E-01 Max = 9.57515600E-01) regrid = T
#13 Unread post by kate »
What about trying "ncdump -h" on one of these things? I get:
netcdf JRA55DO_1.5_rain_2020 {
dimensions:
	lon = 640 ;
	lat = 320 ;
	time = UNLIMITED ; // (2928 currently)
variables:
	double lon(lon) ;
		lon:units = "degrees_east" ;
		lon:valid_min = 0. ;
		lon:valid_max = 359.4375 ;
		lon:long_name = "longitude" ;
	double lat(lat) ;
		lat:units = "degrees_north" ;
		lat:valid_min = -89.5700895506066 ;
		lat:valid_max = 89.5700895506066 ;
		lat:long_name = "latitude" ;
	double time(time) ;
		time:units = "days since 1900-01-01 00:00:00" ;
		time:valid_min = 43829.0625 ;
		time:valid_max = 44194.9375 ;
		time:calendar = "LEAP" ;
	float rain(time, lat, lon) ;
		rain:long_name = "Rainfall Flux" ;
		rain:units = "kg m-2 s-1" ;
		rain:coordinates = "lon lat" ;
		rain:time = "time" ;
		rain:_FillValue = 1.e+15f ;
		rain:missing_value = 1.e+15f ;
		rain:valid_range = -0.0003254949f, 0.003580443f ;
// global attributes:
		:About = "File created by SOSIE interpolation environement, Laurent Brodeau, 2010, (brodeau@gmail.com)" ;
You can see my time origin of "days since 1900-01-01 00:00:00" with values all in the 43000+ range. You can check that for sure with "ncdump -v time" of the thing. My values do indeed go linearly from time:valid_min to time:valid_max.
javadi
#14 Unread post by javadi »
This is ok. I have checked it.I am surprised as in the previous flags the model ran without any problems. But, with this .h we have this problem
cloud_time:long_name = "cloud fraction time" ;
cloud_time:units = "days since 2000-01-01 00:00:00" ;
cloud_time:calendar = "gregorian" ;
float cloud(cloud_time, lat, lon) ;
cloud:long_name = "cloud fraction" ;
cloud:time = "cloud_time" ;
cloud:coordinates = "lon lat cloud_time" ;
double lhf_time(lhf_time) ;
lhf_time:long_name = "latent heat flux time" ;
lhf_time:units = "days since 2000-01-01 00:00:00" ;
lhf_time:calendar = "gregorian" ;
float latent(lhf_time, lat, lon) ;
latent:long_name = "net latent heat flux" ;
latent:units = "Watt meter-2" ;
latent:positive_value = "downward flux, heating" ;
latent:negative_value = "upward flux, cooling" ;
latent:time = "lhf_time" ;
latent:coordinates = "lon lat lhf_time" ;
double pair_time(pair_time) ;
pair_time:long_name = "surface air pressure time" ;
pair_time:units = "days since 2000-01-01 00:00:00" ;
pair_time:calendar = "gregorian" ;
float Pair(pair_time, lat, lon) ;
Pair:long_name = "surface air pressure" ;
Pair:units = "millibar" ;
Pair:time = "pair_time" ;
Pair:coordinates = "lon lat pair_time" ;
double qair_time(qair_time) ;
qair_time:long_name = "surface air humidity time" ;
qair_time:units = "days since 2000-01-01 00:00:00" ;
qair_time:calendar = "gregorian" ;
#15 Unread post by kate »
So, do you know what to do next? You need to change your TIME_REF to match that of your forcing files. I have:
!     DSTART =  29226.5d0                  ! days (1980)
      DSTART =  42003.5d0                  ! days (2015)
  TIDE_START =  -1.0d0                     ! days
    TIME_REF =  19000101.0d0               ! yyyymmdd.dd
javadi
#16 Unread post by javadi »
Excuse me!
I am a little confused about how you estimate the time to start.
Now, I have defined
DSTART = 662214.4375 ! days
TIME_REF = 2000101.0d0
But I have faced this error
TDAYS = 662215.4398
Data Tmin = 662184.9375 Data Tmax = 662549.9375
Data Tstr = 662212.9375 Data Tend = 662213.4375
TINTRP1 = 662215.4375 TINTRP2 = 662185.0625
FAC1 = -30.3773 FAC2 = 0.0023
#17 Unread post by kate »
Woah! Where did you get that DSTART? It should be the number of days between your time origin (2000) and your starting time (2013?). That would make 13*365 plus the number of leap days in there, so 4749 days.
javadi
#18 Unread post by javadi »
Dear Kate
Thank you so much for your points.
I have changed the time based on your sugestions but I have faced the same error.
DSTART = 4749 ! days
(Grid=01, Rec=245, Index=1, File: gom_swrad_era1.nc)
(Tmin= 662185.0625 Tmax= 662549.9375) t = 662215.5625
(Grid=01, Rec=63, Index=1, File: gom_lwrad_era1.nc)
(Tmin= 662184.9375 Tmax= 662549.9375) t = 662185.0625
(Grid=01, Rec=245, Index=1, File: gom_rain_era1.nc)
TDAYS = 662215.4398
#19 Unread post by kate »
I think it thinks you have year 200 instead of year 2000. Try adding another 0.
javadi
#20 Unread post by javadi »
No, this is not matter. I have corrected it. I think that i have different variables with different tmin. It creates problmes.For this reason٫ at the end of each month there is less input forcing٫leading issue. This problem is as a resualt of new .h. I ran the model for 6 years without any problem with the previous .h which is at the bottom of this page.
javadi
#21 Unread post by javadi »
Dear kate
I ask you one question. Based on your suggestion, I use this cpp (bulk fluxes)for my model. Does this work correctly in the trunk branch? or should I use your branch to use this option?
#ifdef SOLVE3D
# define EMINUSP
# undef ANA_SRFLUX
# undef LONGWAVE
#22 Unread post by kate »
The trunk code does not have CCSM_FLUX, nor does it have all those albedo options. You should use the .h file consistent with your code.
javadi
#23 Unread post by javadi »
It was my problem. How should I change my .h file for trunk code to be compatible with trunk codes. Now my .h is:
#define UV_LDRAG
#undef MIX_GEO_UV
#undef TS_DIF4
#undef MIX_GEO_TS
#define MIX_S_TS
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_SMFLUX
# define LMD_MIXING
# ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# undef LMD_BKPP
# define LMD_DDMIX
# undef GLS_MIXING
# undef MY25_MIXING
#ifdef SOLVE3D
# define EMINUSP
# undef ANA_SRFLUX
# undef LONGWAVE
#undef ANA_PSOURCE
# undef AVERAGES
#24 Unread post by kate »
Why don't you look through the trunk code examples to see what they use?
#undef MIX_GEO_TS
#define MIX_S_TS
I would swap these.
This is not in the trunk.
