WET_DRY compilation problem
Hi there,
I'm having trouble compiling with the WET_DRY option on the latest source code. I get the following error:
get_wetdry.f90(142): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idPwet)=Vindex
get_wetdry.f90(151): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idRwet)=Vindex
get_wetdry.f90(160): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idUwet)=Vindex
get_wetdry.f90(169): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idVwet)=Vindex
get_wetdry.f90(186): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idPwet), INI(ng)Vid(idPwet), &
get_wetdry.f90(209): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idRwet), INI(ng)Vid(idRwet), &
get_wetdry.f90(232): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idUwet), INI(ng)Vid(idUwet), &
get_wetdry.f90(255): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idVwet), INI(ng)Vid(idVwet), &
get_wetdry.f90(31): error #6404: This name does not have a type, and must have an explicit type. [GET_GRID]
PUBLIC :: get_grid
get_wetdry.f90(32): error #6404: This name does not have a type, and must have an explicit type. [GET_GRID_NF90]
PRIVATE :: get_grid_nf90
get_wetdry.f90(186): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(185): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
status=nf_fread2d(ng, model, ncname, INI(ng)%ncid, &
get_wetdry.f90(209): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(208): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
get_wetdry.f90(232): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(231): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
get_wetdry.f90(255): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(254): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
compilation aborted for get_wetdry.f90 (code 1)
make: *** [/mnt/beegfs/home/abrereton/SF_NESTED_ROMS/Build_roms/get_wetdry.o] Error 1
Here is my header file:
** svn $Id: pulley.h 719 2014-03-13 22:25:13Z arango $
** Copyright (c) 2002-2014 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for North East North America Application.
** Application flag: PULLEY
** Input script: ocean_pulley.in
#define UV_U3HADVECTION
#define UV_C4VADVECTION
#undef TS_U3HADVECTION
#undef TS_C4VADVECTION
#define TS_MPDATA
#undef TS_A4HADVECTION
#undef TS_A4VADVECTION
#undef TS_DIF4
#define QCORRECTION
#define SCORRECTION
#define BULK_FLUXES
#define EMINUSP
#define LONGWAVE
#define SOLAR_SOURCE
#undef PJ_GRADPQ4
#undef BODYFORCE
#undef DIAGNOSTICS_UV
#undef SPLINES
#undef PERFECT_RESTART
#undef RADIATION_2D
#define MIX_GEO_UV
#define MIX_GEO_TS
#define MY25_MIXING
#ifdef MY25_MIXING
# define K_C4ADVECTION
# define CANTON_A
#undef LMD_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# undef LMD_SKPP
# undef LMD_BKPP
# define LMD_NONLOCAL
#undef GLS_MIXING
#ifdef GLS_MIXING
# define RI_HORAVG
# define RI_VERAVG
# define SSH_TIDES
# define UV_TIDES
# define RAMP_TIDES
# define ADD_M2OBC
# define ADD_FSOBC
#define WET_DRY
#undef BIO_FENNEL
#ifdef BIO_FENNEL
# define ANA_SPFLUX
# define ANA_BPFLUX
# undef ANA_SRFLUX
# define CARBON
# define DENITRIFICATION
# undef BIO_SEDIMENT
#define DIAGNOSTICS
#define DIAGNOSTICS_BIO
#undef FLOATS
#undef FLOAT_VWALK
Any help would be greatly appreciated!
All the best,
Ash
PUBLIC :: get_grid
#define TS_MPDATA
#undef TS_DIF4
#define QCORRECTION
#define SCORRECTION
#define BULK_FLUXES
#define EMINUSP
#define LONGWAVE
#undef PJ_GRADPQ4
#undef BODYFORCE
#undef SPLINES
#undef RADIATION_2D
#define MIX_GEO_UV
#define MIX_GEO_TS
#define MY25_MIXING
#ifdef MY25_MIXING
# define CANTON_A
#undef LMD_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# undef LMD_SKPP
# undef LMD_BKPP
#undef GLS_MIXING
#ifdef GLS_MIXING
# define RI_HORAVG
# define RI_VERAVG
# define SSH_TIDES
# define UV_TIDES
# define RAMP_TIDES
# define ADD_M2OBC
# define ADD_FSOBC
#define WET_DRY
#undef BIO_FENNEL
#ifdef BIO_FENNEL
# define ANA_SPFLUX
# define ANA_BPFLUX
# undef ANA_SRFLUX
# define CARBON
#define DIAGNOSTICS
#undef FLOATS
#undef FLOAT_VWALK
All the best,
Ash
Re: WET_DRY compilation problem
I would look for idRwet and friends in your varinfo.dat. They need to be there.
Thanks for the quick reply!
They are all there, does the compilation interact with varinfo.dat?
All the best,
Ash
All the best,
Ash
Actually, it looks like some bugs have been introduced. This:
is not the proper syntax, as the compiler notes. Try
instead.
INI(ng)%Vid(idVwet)=Vindex
Is your code up to date? I'm not seeing that syntax error in my code.
Hi there,
I ran a svn update this morning and the get_wetdry.f90 code updated and now most of the errors are gone (rev 1067). I'm just left with the following:
PUBLIC :: get_grid
Thanks for getting back to me so quickly as usual!
Ash
PUBLIC :: get_grid
Ash
Yes, thank you for reporting this bug. It is already fixed. Please check the following
trac ticket. Please update your code. I will have to check what your other error is. It looks weird. Those routines are private inside the get_grid_mod (get_grid.F). Have you made changes to get_grid.F? I checked the code and I don't see anything wrong. It compiles for me.
Okay, I see it now. It is fixed. Please update again. Thank you!
Thanks! One more ...
initial.f90(174): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface. [INIREC]
CALL get_wetdry (ng, iNLM, IniRec(ng))
compilation aborted for initial.f90 (code 1)
Okay, thanks. I am getting annoyed with this routine. It needed to be modified because of PIO. I rarely use WET_DRY. Please update again.
Works perfectly! Thanks for the quick fix, it's much appreciated!
