WET_DRY compilation problem
ashbre
#1 Unread post by ashbre »
Hi there,
I'm having trouble compiling with the WET_DRY option on the latest source code. I get the following error:
get_wetdry.f90(142): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idPwet)=Vindex
get_wetdry.f90(151): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idRwet)=Vindex
get_wetdry.f90(160): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idUwet)=Vindex
get_wetdry.f90(169): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: ) ( , : <END-OF-STATEMENT> ; % [ . = / =>
INI(ng)Vid(idVwet)=Vindex
get_wetdry.f90(186): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idPwet), INI(ng)Vid(idPwet), &
get_wetdry.f90(209): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idRwet), INI(ng)Vid(idRwet), &
get_wetdry.f90(232): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idUwet), INI(ng)Vid(idUwet), &
get_wetdry.f90(255): error #5082: Syntax error, found IDENTIFIER 'VID' when expecting one of: :: ) ( , : * <END-OF-STATEMENT> ; . % (/ + - [ ] /) . = ' ** > ...
& Vname(1,idVwet), INI(ng)Vid(idVwet), &
get_wetdry.f90(31): error #6404: This name does not have a type, and must have an explicit type. [GET_GRID]
PUBLIC :: get_grid
get_wetdry.f90(32): error #6404: This name does not have a type, and must have an explicit type. [GET_GRID_NF90]
PRIVATE :: get_grid_nf90
get_wetdry.f90(186): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(185): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
status=nf_fread2d(ng, model, ncname, INI(ng)%ncid, &
get_wetdry.f90(209): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(208): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
get_wetdry.f90(232): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(231): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
get_wetdry.f90(255): error #6200: A colon (:) is not valid in this context.
get_wetdry.f90(254): error #6284: There is no matching specific function for this generic function reference. [NF_FREAD2D]
compilation aborted for get_wetdry.f90 (code 1)
make: *** [/mnt/beegfs/home/abrereton/SF_NESTED_ROMS/Build_roms/get_wetdry.o] Error 1
Here is my header file:
** svn $Id: pulley.h 719 2014-03-13 22:25:13Z arango $
** Copyright (c) 2002-2014 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for North East North America Application.
** Application flag: PULLEY
** Input script: ocean_pulley.in
#define UV_U3HADVECTION
#define UV_C4VADVECTION
#undef TS_U3HADVECTION
#undef TS_C4VADVECTION
#define TS_MPDATA
#undef TS_A4HADVECTION
#undef TS_A4VADVECTION
#undef TS_DIF4
#define QCORRECTION
#define SCORRECTION
#define BULK_FLUXES
#define EMINUSP
#define LONGWAVE
#define SOLAR_SOURCE
#undef PJ_GRADPQ4
#undef BODYFORCE
#undef DIAGNOSTICS_UV
#undef SPLINES
#undef PERFECT_RESTART
#undef RADIATION_2D
#define MIX_GEO_UV
#define MIX_GEO_TS
#define MY25_MIXING
#ifdef MY25_MIXING
# define K_C4ADVECTION
# define CANTON_A
#undef LMD_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# undef LMD_SKPP
# undef LMD_BKPP
# define LMD_NONLOCAL
#undef GLS_MIXING
#ifdef GLS_MIXING
# define RI_HORAVG
# define RI_VERAVG
# define SSH_TIDES
# define UV_TIDES
# define RAMP_TIDES
# define ADD_M2OBC
# define ADD_FSOBC
#define WET_DRY
#undef BIO_FENNEL
#ifdef BIO_FENNEL
# define ANA_SPFLUX
# define ANA_BPFLUX
# undef ANA_SRFLUX
# define CARBON
# define DENITRIFICATION
# undef BIO_SEDIMENT
#define DIAGNOSTICS
#define DIAGNOSTICS_BIO
#undef FLOATS
#undef FLOAT_VWALK
Any help would be greatly appreciated!
All the best,
Ash
Re: WET_DRY compilation problem
I would look for idRwet and friends in your varinfo.dat. They need to be there.
ashbre
#3 Unread post by ashbre »
Thanks for the quick reply!
They are all there, does the compilation interact with varinfo.dat?
All the best,
Ash
Actually, it looks like some bugs have been introduced. This:
is not the proper syntax, as the compiler notes. Try
INI(ng)%Vid(idVwet)=Vindex
instead.
#5 Unread post by wilkin »
Is your code up to date? I'm not seeing that syntax error in my code.
ashbre
#6 Unread post by ashbre »
Hi there,
I ran a svn update this morning and the get_wetdry.f90 code updated and now most of the errors are gone (rev 1067). I'm just left with the following:
PUBLIC :: get_grid
Thanks for getting back to me so quickly as usual!
Ash
#7 Unread post by arango »
Yes, thank you for reporting this bug. It is already fixed. Please check the following :arrow: trac ticket. Please update your code. I will have to check what your other error is. It looks weird. Those routines are private inside the get_grid_mod (get_grid.F). Have you made changes to get_grid.F? I checked the code and I don't see anything wrong. It compiles for me.
#8 Unread post by arango »
Okay, I see it now. It is fixed. Please update again. Thank you!
ashbre
#9 Unread post by ashbre »
Thanks! One more ...
initial.f90(174): error #6631: A non-optional actual argument must be present when invoking a procedure with an explicit interface. [INIREC]
CALL get_wetdry (ng, iNLM, IniRec(ng))
compilation aborted for initial.f90 (code 1)
#10 Unread post by arango »
Okay, thanks. I am getting annoyed with this routine. It needed to be modified because of PIO. I rarely use WET_DRY. Please update again.
ashbre
#11 Unread post by ashbre »
Works perfectly! Thanks for the quick fix, it's much appreciated!
