the defination of density rho
- zhangtianhao
Hi there,
I have a problem and maybe it's easy to you: I want to modify the code and use the density of seawater in fourmula, should I use rho(:,:,:)+1000 or just rho? I wonder that if the rho is the density anomaly I don't find the defination of in forum.
BTW, I want to use the density to represent the mass but not use it in pressure terms.
Re: the defination of density rho
The variable "rho" in the model is insitu density anomaly. You add rho0 to it to get full density. Note that rho0 may or may not be 1000.
- zhangtianhao
Thanks, Kate, rho0 equals 1025 in my case, but I find in rho_eos.F file:
den(i,k)=den1(i,k)*bulk(i,k)*cff
den(i,k)=den(i,k)-1000.0_r8
It seems that in this code file, they do not use den-rho0 but den-1000..
- rho_eos.F
- (32.98 KiB) Downloaded 515 times
OK, but I'm surprised.
- zhangtianhao
I found that when I set a (rho+1000)*acceleration term in the equation, ROMS showed rho speed trouble, I wonder that how to check this problem.
Are you trying to change ROMS equation of state? The definition of in situ density anomaly or potential density anomaly is that a1000 kg m-3 value is subtracted to the density. The in situ density anomaly, as a field, is only used in ROMS in the pressure gradient algorithm where its value is not essential. We are only interested in its horizontal gradient! But, you cannot change the ROMS equation of state without looking at how the pressure gradient algorithm is formulated. Also, the potential density is used in the isopycnic diffusion along neutral surfaces in the Redi tensor.
It is well known from the beggigning of oceanography that we cannot measure the seawater density directly with a sufficient level of accuracy to determine its horizontal gradient. That's the reason that we measure temperature and salinity as a function of depth and compute density with the equation of state for seawater.
If you need the density without the pressure terms (secant bulk modulus) use pden, which is the density anomaly at standard one-atmosphere pressure.
The parameter rho0 is a different density value (not an anomaly value) that it is used in the Boussinesq approximation of the governing equations. The density gradients are ignored except when multiplied by gravity. Rho0 is also used when activating the linear equation of state (NONLIN_EOS is off). Its value is set-up in ROMS standard input file roms.in. If you preffer a rho0 value of 1000 kg m-3, do so. It is a user tunable parameter!
- zhangtianhao
Thank you very much for your detailed answer,arango wrote: ↑Mon Jun 08, 2020 3:48 pm Are you trying to change ROMS equation of state? The definition of in situ density anomaly or potential density anomaly is that a1000 kg m-3 value is subtracted to the density. The in situ density anomaly, as a field, is only used in ROMS in the pressure gradient algorithm where its value is not essential. We are only interested in its horizontal gradient! But, you cannot change the ROMS equation of state without looking at how the pressure gradient algorithm is formulated. Also, the potential density is used in the isopycnic diffusion along neutral surfaces in the Redi tensor.
I want to modify momentum equation in rhs3d by adding an forcing term (a constant horizental acceleration a), and density is required in this term. According to this, should I use (pden+1000) in this term, or should I use rho0 because the acceleration is a body force, like g (Boussinesq approximation)?
Thanks again
Hoty
Where ROMS expresses anything in kinematic units (per unit mass), such as converting stress to friction velocity (tau/rho0), or heat flux (W/m2) to degrees meters/s (Hf/(Cp*rho0) in the surface temperature boundary condition, it always uses the constant parameter rho0. Likewise, to calculate Brunt-Väisälä frequency the factor g/rho0 is used.
If you are trying to add a "horizontal acceleration", are you aware of the existing BODYFORCE option?
- zhangtianhao
Thanks for your reply, I checked BODYFORCE by your guidence, I found the code in rhs3d.F about BODYFORCE:wilkin wrote: ↑Tue Jun 09, 2020 4:20 pm Where ROMS expresses anything in kinematic units (per unit mass), such as converting stress to friction velocity (tau/rho0), or heat flux (W/m2) to degrees meters/s (Hf/(Cp*rho0) in the surface temperature boundary condition, it always uses the constant parameter rho0. Likewise, to calculate Brunt-Väisälä frequency the factor g/rho0 is used.
# ifdef BODYFORCE
DO j=JstrV-1,Jend
DO i=IstrU-1,Iend
wrk(i,j)=0.0_r8
DO k=N(ng),levsfrc(ng),-1
DO j=JstrV-1,Jend
DO i=IstrU-1,Iend
wrk(i,j)=wrk(i,j)+Hz(i,j,k)
DO j=Jstr,Jend
DO i=IstrU,Iend
cff=0.25_r8*(pm(i-1,j)+pm(i,j))*(pn(i-1,j)+pn(i,j))
cff1=1.0_r8/(cff*(wrk(i-1,j)+wrk(i,j)))
Uwrk(i,j)=sustr(i,j)*cff1
DO k=levsfrc(ng),N(ng)
DO j=Jstr,Jend
DO i=IstrU,Iend
cff=Uwrk(i,j)*(Hz(i ,j,k)+Hz(i-1,j,k))
ru(i,j,k,nrhs)=ru(i,j,k,nrhs)+cff
As for me, BODYFORCE requirs surface stress and transforms it to body force, BUT I input acceleration a(m/s2) (because I just have horizontal acceleration data, I let sustr=au and svstr=ay mandatorily ), not stress in smflux.F, and I modify the code in order to satisfy the dimensional homogeneity: NOTICE the second line from the bottom, ru= rho0*acceleration*A*Wrk*Hz/Wrk
# ifdef BODYFORCE
DO j=JstrV-1,Jend
DO i=IstrU-1,Iend
wrk(i,j)=0.0_r8
DO j=JstrV-1,Jend
DO i=IstrU-1,Iend
DO j=Jstr,Jend
DO i=IstrU,Iend
Uwrk(i,j)=sustr(i,j)*cff1[/b]
DO j=Jstr,Jend
DO i=IstrU,Iend
cff=Uwrk(i,j)*(Hz(i ,j,k)+Hz(i-1,j,k))*rho0*(wrk(i-1,j)+wrk(i,j))*0.5_r8 !!!!!!!!!!!!NOTICE THIS MODIFICATION
Hoty
No, at this point in the code sustr is a kinematic stress tao/rho0 and has units m2/s2. It is not Pascals.It seems that the forcing term ru on the right hand side of the equation euqals τ*A*Hz/Wrk,which has a force (N) dimension (Pa*m2*m/m).
See in bulk_flux.F and ana_smflux.h that Tau gets divided by rho0 to carry kinematic stress internally in ROMS.
- zhangtianhao
Thanks for all of your advice,
I use BODYFORCE now, and I correct the τ unit. But ROMS still blowed up.
In smflx.h, I set sustr=a*h, (a means acceleration, h means depth, unit=m/s2*m), so the sustr has kinetic unit, as shown below:
Thus I don't need to modify BODYFORCE sustr code, (But I modify sbstr code, I don't want to transform it to bodyforce, it is still used in 2d equation), as shown below:
!!!!!!!!!NOTICE THAT I DONT ADD CFF TO RHS
But DIAG speed problem happened again. I wonder that if ther are something I still misunderstood. Maybe there are something wrong when I transform acceleration to τ.
open(55,file='/ubuntu/COAWST/Projects/acceleration/EW01.txt',status='old')
read(55,*)(ax(i),i=1,40001)
close(55)
DO j=JstrT,JendT
DO i=IstrP,IendT
DO k=1,40001
kk = REAL(k)
IF(iic(ng).eq.kk) THEN
sustr(i,j)=0.5_r8*(h(i-1,j)+h(i,j))*ax(k)
! Apply bottom stress as a bodyforce: determine the thickness (m)
! of the bottom layer; then add in bottom stress as a bodyfoce.
DO j=JstrV-1,Jend
DO i=IstrU-1,Iend
wrk(i,j)=0.0_r8
DO k=1,levbfrc(ng)
DO j=JstrV-1,Jend
DO i=IstrU-1,Iend
DO j=Jstr,Jend
DO i=IstrU,Iend
cff=0.25_r8*(pm (i-1,j)+pm (i,j))* &
& (pn (i-1,j)+pn (i,j))
Uwrk(i,j)=bustr(i,j)*cff1
DO k=1,levbfrc(ng)
DO j=Jstr,Jend
DO i=IstrU,Iend
cff=Uwrk(i,j)*(Hz(i ,j,k)+ &
& Hz(i-1,j,k))
! hoty modified at 2020-06-11!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
All you need to do to prevent the bottom stress also being applied as a bodyforce is make LEVBFRC = 0 in roms.in:(But I modify sbstr code, I don't want to transform it to bodyforce, it is still used in 2d equation), as shown below:
! Body-force parameters. Used when CPP option BODYFORCE is activated.
! LEVBFRC Shallowest level to apply bottom momentum stress as a body-force.
- zhangtianhao
Thanks for your suggestions, it is really helpful!wilkin wrote: ↑Thu Jun 11, 2020 1:52 pmAll you need to do to prevent the bottom stress also being applied as a bodyforce is make LEVBFRC = 0 in roms.in:(But I modify sbstr code, I don't want to transform it to bodyforce, it is still used in 2d equation), as shown below:
!------------------------------------------------------------------------------ ! Body-force parameters. Used when CPP option BODYFORCE is activated. !------------------------------------------------------------------------------ ! ! LEVBFRC Shallowest level to apply bottom momentum stress as a body-force.
But I still have two problems.
Firstly, it seems that when set LEVBFRC = 0 in roms.in, the bottom stress is still not activated in 2d momenten equation, in rhs3d.F( cff2= 0.0_r8):
# ifdef BODYFORCE
DO i=Istr,Iend
cff=om_v(i,j)*on_v(i,j)
cff1= 0.0_r8
cff2= 0.0_r8
rufrc(i,j)=rufrc(i,j)+cff1+cff2
open(55,file='ubuntu/COAWST/Projects/EW/EW01.txt',status='old')
close(55)
DO j=JstrT,JendT
DO i=IstrP,IendT
DO k=1,40001
kk = REAL(k)
Hoty
cff1= 0.0_r8
cff2= 0.0_r8
- zhangtianhao
Sorry, I don't make myself clear,wilkin wrote: ↑Sat Jun 13, 2020 2:14 pmI can't find that code anywhere in my version of rhs3d.F.Code: Select all
cff1= 0.0_r8 cff2= 0.0_r8 rufrc(i,j)=rufrc(i,j)+cff1+cff2
Firstly , it seems that the miximun value of levbfrc is 1 but not 0,
Secondly, Line 2170 in rhs3d.F:
# ifndef BODYFORCE
DO i=Istr,Iend
cff1= svstr(i,j)*cff
cff2=-bvstr(i,j)*cff
rvfrc(i,j)=rvfrc(i,j)+cff1+cff2
That means if I define BODYFORCE, bottem stress will not be added in rhs of 2d eq, but added in the lowest layer in 3d euqation.
I wonder that if these two method are equivalent (add in 2d eq or the lowest layer in 3d eq)
I see your point. Then you might have to code some workaround, like ...
But before you do that think it through carefully. Applying the bottom stress as a bodyforce in the bottom layer (LEVBFRC=1) will be extremely close to, if not identical to, having a stress on the z=-h face of the lowest layer. Isn't that what you want?
# if !defined BODYFORCE
! the original code ...
DO i=Istr,Iend
#else
! the code you want, whatever that is
- zhangtianhao
Thanks, I will take a try and have a look at the difference between the two methods.wilkin wrote: ↑Sun Jun 14, 2020 4:27 pm I see your point. Then you might have to code some workaround, like ...
But before you do that think it through carefully. Applying the bottom stress as a bodyforce in the bottom layer (LEVBFRC=1) will be extremely close to, if not identical to, having a stress on the z=-h face of the lowest layer. Isn't that what you want?Code: Select all
# if !defined BODYFORCE ! the original code ... DO i=Istr,Iend cff=om_v(i,j)*on_v(i,j) cff1= svstr(i,j)*cff cff2=-bvstr(i,j)*cff rvfrc(i,j)=rvfrc(i,j)+cff1+cff2 ... #else ! the code you want, whatever that is ...
Thanks agian
Hoty
