the defination of density rho
zhangtianhao
#1 Unread post by zhangtianhao »
Hi there,
I have a problem and maybe it's easy to you: I want to modify the code and use the density of seawater in fourmula, should I use rho(:,:,:)+1000 or just rho? I wonder that if the rho is the density anomaly :D I don't find the defination of in forum.
BTW, I want to use the density to represent the mass but not use it in pressure terms.
Thanks :D
Re: the defination of density rho
The variable "rho" in the model is insitu density anomaly. You add rho0 to it to get full density. Note that rho0 may or may not be 1000.
zhangtianhao
#3 Unread post by zhangtianhao »
kate wrote: Fri Jun 05, 2020 4:15 am The variable "rho" in the model is insitu density anomaly. You add rho0 to it to get full density. Note that rho0 may or may not be 1000.
Thanks, Kate, rho0 equals 1025 in my case, but I find in rho_eos.F file:
den(i,k)=den1(i,k)*bulk(i,k)*cff
den(i,k)=den(i,k)-1000.0_r8
It seems that in this code file, they do not use den-rho0 but den-1000..
rho_eos.F
(32.98 KiB) Downloaded 493 times
OK, but I'm surprised.
zhangtianhao
#5 Unread post by zhangtianhao »
I found that when I set a (rho+1000)*acceleration term in the equation, ROMS showed rho speed trouble, I wonder that how to check this problem.
#6 Unread post by arango »
Are you trying to change ROMS equation of state? The definition of in situ density anomaly or potential density anomaly is that a1000 kg m-3 value is subtracted to the density. The in situ density anomaly, as a field, is only used in ROMS in the pressure gradient algorithm where its value is not essential. We are only interested in its horizontal gradient! But, you cannot change the ROMS equation of state without looking at how the pressure gradient algorithm is formulated. Also, the potential density is used in the isopycnic diffusion along neutral surfaces in the Redi tensor.
It is well known from the beggigning of oceanography that we cannot measure the seawater density directly with a sufficient level of accuracy to determine its horizontal gradient. That's the reason that we measure temperature and salinity as a function of depth and compute density with the equation of state for seawater.
If you need the density without the pressure terms (secant bulk modulus) use pden, which is the density anomaly at standard one-atmosphere pressure.
The parameter rho0 is a different density value (not an anomaly value) that it is used in the Boussinesq approximation of the governing equations. The density gradients are ignored except when multiplied by gravity. Rho0 is also used when activating the linear equation of state (NONLIN_EOS is off). Its value is set-up in ROMS standard input file roms.in. If you preffer a rho0 value of 1000 kg m-3, do so. It is a user tunable parameter!
zhangtianhao
#7 Unread post by zhangtianhao »
arango wrote: Mon Jun 08, 2020 3:48 pm Are you trying to change ROMS equation of state? The definition of in situ density anomaly or potential density anomaly is that a1000 kg m-3 value is subtracted to the density. The in situ density anomaly, as a field, is only used in ROMS in the pressure gradient algorithm where its value is not essential. We are only interested in its horizontal gradient! But, you cannot change the ROMS equation of state without looking at how the pressure gradient algorithm is formulated. Also, the potential density is used in the isopycnic diffusion along neutral surfaces in the Redi tensor.
Thank you very much for your detailed answer,
I want to modify momentum equation in rhs3d by adding an forcing term (a constant horizental acceleration a), and density is required in this term. According to this, should I use (pden+1000) in this term, or should I use rho0 because the acceleration is a body force, like g (Boussinesq approximation)?
Thanks again
Hoty
#8 Unread post by wilkin »
Where ROMS expresses anything in kinematic units (per unit mass), such as converting stress to friction velocity (tau/rho0), or heat flux (W/m2) to degrees meters/s (Hf/(Cp*rho0) in the surface temperature boundary condition, it always uses the constant parameter rho0. Likewise, to calculate Brunt-Väisälä frequency the factor g/rho0 is used.
If you are trying to add a "horizontal acceleration", are you aware of the existing BODYFORCE option?
zhangtianhao
#9 Unread post by zhangtianhao »
wilkin wrote: Tue Jun 09, 2020 4:20 pm Where ROMS expresses anything in kinematic units (per unit mass), such as converting stress to friction velocity (tau/rho0), or heat flux (W/m2) to degrees meters/s (Hf/(Cp*rho0) in the surface temperature boundary condition, it always uses the constant parameter rho0. Likewise, to calculate Brunt-Väisälä frequency the factor g/rho0 is used.
Thanks for your reply, I checked BODYFORCE by your guidence, I found the code in rhs3d.F about BODYFORCE:
# ifdef BODYFORCE
      DO j=JstrV-1,Jend
        DO i=IstrU-1,Iend
          wrk(i,j)=0.0_r8
      DO k=N(ng),levsfrc(ng),-1
        DO j=JstrV-1,Jend
          DO i=IstrU-1,Iend
            wrk(i,j)=wrk(i,j)+Hz(i,j,k)
      DO j=Jstr,Jend
        DO i=IstrU,Iend
          cff=0.25_r8*(pm(i-1,j)+pm(i,j))*(pn(i-1,j)+pn(i,j))
          cff1=1.0_r8/(cff*(wrk(i-1,j)+wrk(i,j)))
          Uwrk(i,j)=sustr(i,j)*cff1
      DO k=levsfrc(ng),N(ng)
        DO j=Jstr,Jend
          DO i=IstrU,Iend
            cff=Uwrk(i,j)*(Hz(i  ,j,k)+Hz(i-1,j,k))
            ru(i,j,k,nrhs)=ru(i,j,k,nrhs)+cff
It seems that the forcing term ru on the right hand side of the equation euqals τ*A*Hz/Wrkwhich has a force (N) dimension (Pa*m2*m/m).
As for me, BODYFORCE requirs surface stress and transforms it to body force, BUT I input acceleration a(m/s2) (because I just have horizontal acceleration data, I let sustr=au and svstr=ay mandatorily ), not stress in smflux.F, and I modify the code in order to satisfy the dimensional homogeneity: NOTICE the second line from the bottom, ru= rho0*acceleration*A*Wrk*Hz/Wrk
# ifdef BODYFORCE
      DO j=JstrV-1,Jend
        DO i=IstrU-1,Iend
          wrk(i,j)=0.0_r8
        DO j=JstrV-1,Jend
          DO i=IstrU-1,Iend
      DO j=Jstr,Jend
        DO i=IstrU,Iend
          Uwrk(i,j)=sustr(i,j)*cff1[/b]
        DO j=Jstr,Jend
          DO i=IstrU,Iend
            cff=Uwrk(i,j)*(Hz(i  ,j,k)+Hz(i-1,j,k))*rho0*(wrk(i-1,j)+wrk(i,j))*0.5_r8   !!!!!!!!!!!!NOTICE THIS MODIFICATION
But, ROMS showed rho speed trouble. I wonder that if there is anything I misunderstood.
Hoty
#10 Unread post by wilkin »
It seems that the forcing term ru on the right hand side of the equation euqals τ*A*Hz/Wrk,which has a force (N) dimension (Pa*m2*m/m).
No, at this point in the code sustr is a kinematic stress tao/rho0 and has units m2/s2. It is not Pascals.
See in bulk_flux.F and ana_smflux.h that Tau gets divided by rho0 to carry kinematic stress internally in ROMS.
zhangtianhao
#11 Unread post by zhangtianhao »
Thanks for all of your advice,
I use BODYFORCE now, and I correct the τ unit. But ROMS still blowed up.
In smflx.h, I set sustr=a*h, (a means acceleration, h means depth, unit=m/s2*m), so the sustr has kinetic unit, as shown below:
      open(55,file='/ubuntu/COAWST/Projects/acceleration/EW01.txt',status='old')
      read(55,*)(ax(i),i=1,40001)
      close(55)
      DO j=JstrT,JendT
        DO i=IstrP,IendT
	  DO k=1,40001
	    kk = REAL(k)
	    IF(iic(ng).eq.kk) THEN
              sustr(i,j)=0.5_r8*(h(i-1,j)+h(i,j))*ax(k)
Thus I don't need to modify BODYFORCE sustr code, (But I modify sbstr code, I don't want to transform it to bodyforce, it is still used in 2d equation), as shown below:
!  Apply bottom stress as a bodyforce: determine the thickness (m)
!  of the bottom layer; then add in bottom stress as a bodyfoce.
      DO j=JstrV-1,Jend
        DO i=IstrU-1,Iend
          wrk(i,j)=0.0_r8
      DO k=1,levbfrc(ng)
        DO j=JstrV-1,Jend
          DO i=IstrU-1,Iend
      DO j=Jstr,Jend
        DO i=IstrU,Iend
          cff=0.25_r8*(pm (i-1,j)+pm (i,j))*                            &
     &                (pn (i-1,j)+pn (i,j))
          Uwrk(i,j)=bustr(i,j)*cff1
      DO k=1,levbfrc(ng)
        DO j=Jstr,Jend
          DO i=IstrU,Iend
            cff=Uwrk(i,j)*(Hz(i  ,j,k)+                                 &
     &                     Hz(i-1,j,k))
!  hoty modified at 2020-06-11!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!NOTICE THAT I DONT ADD CFF TO RHS
But DIAG speed problem happened again. I wonder that if ther are something I still misunderstood. Maybe there are something wrong when I transform acceleration to τ.
#12 Unread post by wilkin »
All you need to do to prevent the bottom stress also being applied as a bodyforce is make LEVBFRC = 0 in roms.in:
! Body-force parameters. Used when CPP option BODYFORCE is activated.
! LEVBFRC      Shallowest level to apply bottom momentum stress as a body-force.
zhangtianhao
#13 Unread post by zhangtianhao »
wilkin wrote: Thu Jun 11, 2020 1:52 pm
Thanks for your suggestions, it is really helpful!
But I still have two problems.
Firstly, it seems that when set LEVBFRC = 0 in roms.in, the bottom stress is still not activated in 2d momenten equation, in rhs3d.F( cff2= 0.0_r8):
# ifdef BODYFORCE
          DO i=Istr,Iend
            cff=om_v(i,j)*on_v(i,j)
            cff1= 0.0_r8
            cff2= 0.0_r8
            rufrc(i,j)=rufrc(i,j)+cff1+cff2
Secondly, I still don't figure out the speed trouble problems. I think maybe there are some problems with my input stress in smflux.h (sustr=a*h), or this term:0.5_r8*(h(i-1,j)+h(i,j)) is not right? The code is shown below. I really wonder that how do you transform acceleration to sustr. :D
      open(55,file='ubuntu/COAWST/Projects/EW/EW01.txt',status='old')
      close(55)
      DO j=JstrT,JendT
        DO i=IstrP,IendT
	  DO k=1,40001
	    kk = REAL(k)
Thanks again,
Hoty
#14 Unread post by wilkin »
    cff1= 0.0_r8
    cff2= 0.0_r8
I can't find that code anywhere in my version of rhs3d.F.
zhangtianhao
#15 Unread post by zhangtianhao »
wilkin wrote: Sat Jun 13, 2020 2:14 pm
    cff1= 0.0_r8
    cff2= 0.0_r8
Sorry, I don't make myself clear,
Firstly , it seems that the miximun value of levbfrc is 1 but not 0,
Secondly, Line 2170 in rhs3d.F:
# ifndef BODYFORCE
          DO i=Istr,Iend
            cff1= svstr(i,j)*cff
            cff2=-bvstr(i,j)*cff
            rvfrc(i,j)=rvfrc(i,j)+cff1+cff2
It seems that when undefine BODYFORCE cff2(bottem stress) is introduced into right hand side of 2d equation.
That means if I define BODYFORCE, bottem stress will not be added in rhs of 2d eq, but added in the lowest layer in 3d euqation.
I wonder that if these two method are equivalent (add in 2d eq or the lowest layer in 3d eq)
#16 Unread post by wilkin »
I see your point. Then you might have to code some workaround, like ...
# if !defined BODYFORCE
! the original code ...
          DO i=Istr,Iend
#else
! the code you want, whatever that is
But before you do that think it through carefully. Applying the bottom stress as a bodyforce in the bottom layer (LEVBFRC=1) will be extremely close to, if not identical to, having a stress on the z=-h face of the lowest layer. Isn't that what you want?
zhangtianhao
#17 Unread post by zhangtianhao »
wilkin wrote: Sun Jun 14, 2020 4:27 pm I see your point. Then you might have to code some workaround, like ...
          DO i=Istr,Iend
#else
Thanks, I will take a try and have a look at the difference between the two methods.
Thanks agian :D
Hoty
