I want to force my model using surface flux directly, so I turn off BULK_FLUXES. And I also turn on SRELAXATION, SOLAR_SOURCE. The model read sustr, svstr, swrad and shflux but does not read swflux which I also provided.
According to the get_data.F, swflux should be read after definding SRELAXATION:
# if defined NL_BULK_FLUXES && !defined BULK_FLUXES
(read EminusP)
# elif !(defined ANA_SSFLUX || defined FRC_COUPLING || \
defined EMINUSP || defined SRELAXATION)
(read swflux)
Kind Regards,
yj7054
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine.
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine.
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
MASKING Land/Sea masking.
MIX_ISO_TS Mixing of tracers along isopycnal surfaces.
MIX_GEO_UV Mixing of momentum along geopotential surfaces.
MY25_MIXING Mellor/Yamada Level-2.5 mixing closure.
NONLINEAR Nonlinear Model.
PERFECT_RESTART Processing perfect restart variables.
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine.
SALINITY Using salinity.
SRELAXATION Surface salinity relaxation as surface flux.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
