Why ROMS does not read the provided swflux?
yj7054
#1 Unread post by yj7054 »
I want to force my model using surface flux directly, so I turn off BULK_FLUXES. And I also turn on SRELAXATION, SOLAR_SOURCE. The model read sustr, svstr, swrad and shflux but does not read swflux which I also provided.
According to the get_data.F, swflux should be read after definding SRELAXATION:
#  if defined NL_BULK_FLUXES && !defined BULK_FLUXES
         (read EminusP)
#  elif !(defined ANA_SSFLUX || defined FRC_COUPLING || \
          defined EMINUSP    || defined SRELAXATION)
         (read swflux)
#  endif
I am confused why the model doesn't read swflux and keep running. Did I forget to turn on (or off) some CPP? (all the CPP I used are listed below)
Kind Regards,
yj7054
 !BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine.
 !COLLECT_ALL...     Using mpi_isend/mpi_recv in mp_collect routine.
 DOUBLE_PRECISION    Double precision arithmetic numerical kernel.
 MIX_ISO_TS          Mixing of tracers along isopycnal surfaces.
 MIX_GEO_UV          Mixing of momentum along geopotential surfaces.
 MY25_MIXING         Mellor/Yamada Level-2.5 mixing closure.
 PERFECT_RESTART     Processing perfect restart variables.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 REDUCE_ALLGATHER    Using mpi_allgather in mp_reduce routine.
 SRELAXATION         Surface salinity relaxation as surface flux.
 SOLAR_SOURCE        Solar Radiation Source Term.
Re: Why ROMS does not read the provided swflux?
#2 Unread post by wilkin »
         (read EminusP)
         (read swflux)
#  endif
|| is a logical "OR", and since defined SRELAXATION is "TRUE" the expression in () is TRUE, and the "!" is a logical "NOT", so the expression after elif is FALSE.
SRELAXTION says set the surface salt flux by relaxation to a defined salinity field, therefore ROMS has no need of swflux for the surface salt/freshwater flux. That's why it is not read.
yj7054
#3 Unread post by yj7054 »
Thank you very much!
I misunderstood the logic. It is a stupid question, sorry.
