Index '282' of dimension 2 of array 'finp' above upper bound of 281
zhangtianhao
#1 Unread post by zhangtianhao »
Hi there,
I met some problems when I ran a simple case:Index '282' of dimension 2 of array 'finp' above upper bound of 281. I checked interpolate.f90 and considered ‘finp’ may be related to grid file. Then I check my grid file, but the dimensions of the whole varibales are 281, no 282 appeared(my dimension is 179*281).
I can't figure out what happened to my grid file or other input files.
Maybe it's stupid to you but thanks.
Here is the result and grid file:
(Grid 01, File: palu_init.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 1.00000000E+01 Max = 1.00000000E+01)
- salinity
(Min = 3.50000000E+01 Max = 3.50000000E+01)
At line 117 of file interpolate.f90
Fortran runtime error: Index '282' of dimension 2 of array 'finp' above upper bound of 281
Error termination. Backtrace:
#0 0x7fd5338322da in ???
#1 0x7fd533832ec5 in ???
#2 0x7fd533833297 in ???
#3 0x557ab0b8c343 in __interpolate_mod_MOD_linterp2d
at /home/ubuntu/app/COAWST_V3.2/Build/interpolate.f90:117
#4 0x557ab0b26fb6 in regrid_
at /home/ubuntu/app/COAWST_V3.2/Build/regrid.f90:180
#5 0x557ab0b1726b in __nf_fread2d_mod_MOD_nf_fread2d
at /home/ubuntu/app/COAWST_V3.2/Build/nf_fread2d.f90:310
#6 0x557ab0925c32 in get_2dfld_
at /home/ubuntu/app/COAWST_V3.2/Build/get_2dfld.f90:198
#7 0x557ab0533c01 in get_data_
at /home/ubuntu/app/COAWST_V3.2/Build/get_data.f90:104
#8 0x557ab0530791 in initial_
at /home/ubuntu/app/COAWST_V3.2/Build/initial.f90:296
#9 0x557ab034fbbd in __ocean_control_mod_MOD_roms_initialize
at /home/ubuntu/app/COAWST_V3.2/Build/ocean_control.f90:131
#10 0x557ab034ec15 in ocean
at /home/ubuntu/app/COAWST_V3.2/Build/master.f90:95
#11 0x557ab034ede1 in main
at /home/ubuntu/app/COAWST_V3.2/Build/master.f90:50
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[4580,1],0]
Exit code: 2
simple_grid.nc
(7.61 MiB) Downloaded 840 times
Re: Index '282' of dimension 2 of array 'finp' above upper bound of 281
I suspect you are reading an atmospheric field here? The model wouldn't try to interpolate from your grid file, assuming all those fields are already on your grid. So, what atmospheric fields are you reading and are you expecting ROMS to do the interpolations? What grid are they on?
zhangtianhao
#3 Unread post by zhangtianhao »
kate wrote: Wed Jan 08, 2020 11:40 am
Thank you, I input uv-stress by stressTEST.nc file. But I have also checked this nc file, and the dimension of uv-stress is 178*281*time, not 282.
Attached is stressTEST.nc file. I turn off ana_smflx and input it by nc file containing my group's data.
I am still confused of it. :cry:
stressTEST.zip
(842.37 KiB) Downloaded 818 times
So you think you have already remapped the thing to your grid. You have to have the dimensions *exactly* right or else ROMS will decide to remap for you.
Some words on grid sizes. If you want powers of two or three in the grid for your decompositions without needing leftovers, you need Lm, Mm to have factors of two or three - something like 280 is good. Then the rho grid with halos would have say eta_rho=282. The v-stress is on the v-points of the grid, therefore dimensioned 281. Search the wiki for Arakawa C-grid to see the staggering used - not all variables are dimensioned the same.
zhangtianhao
#5 Unread post by zhangtianhao »
kate wrote: Wed Jan 08, 2020 12:53 pm So you think you have already remapped the thing to your grid. You have to have the dimensions *exactly* right or else ROMS will decide to remap for you.
Kate,
Thanks for your suggestion.
Maybe I am not clear about the exact meaning of my input forcing file. I set uv-stress on rho grid.(rho dimension is 178*281), but it seems that uv-stress should set on u-grid (dimension: 177*281) and v-grid (dimension: 178*280), I misunderstood it.
Thanks again.
zhangtianhao
#6 Unread post by zhangtianhao »
Sorry,
I have changed dimension of uv-stress, but I met another problem:Fortran runtime error: Index '1' of dimension 2 of array 'bry' above upper bound of 0.
It seems that there are some problems with my bry, but my forcing file only contains the information of sustrs, svstrs, lon_u, lon_v, lat_u, lat_v. I don't know it's relationship with bry.
(Grid 01, File: init.nc, Rec=0001, Index=1)
- free-surface
- salinity
GET_2DFLD - surface u-momentum stress, t = 0 00:00:00
(Rec=0000001, Index=1, File: stressTEST.nc)
(Tmin= 0.0000 Tmax= 0.0347)
At line 139 of file get_data.f90
GET_2DFLD - surface v-momentum stress, t = 0 00:00:00
#0 0x7f162ca952da in ???
#1 0x7f162ca95ec5 in ???
#2 0x7f162ca96297 in ???
#3 0x55d9a7b3a288 in get_data_
at /home/ubuntu/app/COAWST_V3.2/Build/get_data.f90:139
#4 0x55d9a7b35791 in initial_
#5 0x55d9a7954bbd in __ocean_control_mod_MOD_roms_initialize
#6 0x55d9a7953c15 in ocean
#7 0x55d9a7953de1 in main
Process name: [[29868,1],0]
Exit code: 2
stressTEST.zip
(1.03 MiB) Downloaded 978 times
#7 Unread post by kate »
Since you are using COAWST, you need to set the number of boundary and climatology files, not just the number of forcing files. See the coawst roms.in for an example. Same for the river inputs.
zhangtianhao
#8 Unread post by zhangtianhao »
Attached is my bry condition
#9 Unread post by kate »
The Flather condition requires values from outside the domain for both ubar/vbar and zeta. You can provide them via ANA_xxx options or you can specify a file:
    NBCFILES == 1                          ! number of boundary files
     BRYNAME == /center1/AKWATERS/kshedstrom/Arctic/Files/Arctic4_bdry_1980_SODA3.3.1.nc |
                /center1/AKWATERS/kshedstrom/Arctic/Files/Arctic4_bdry_1981_SODA3.3.1.nc |
                /center1/AKWATERS/kshedstrom/Arctic/Files/Arctic4_bdry_1982_SODA3.3.1.nc
zhangtianhao
#10 Unread post by zhangtianhao »
kate wrote: Thu Jan 09, 2020 3:04 am The Flather condition requires values from outside the domain for both ubar/vbar and zeta. You can provide them via ANA_xxx options or you can specify a file:
Thanks for your reply, I use our group's server and I only use the part of ROMS. I will go to learn the input of COAWST.
Thanks again
zhangtianhao
#11 Unread post by zhangtianhao »
Now I can run this case but it blows up after several steps.
And it's weird that: usually results become large and model blows up, but this time results suddenly become NaN.
So I checked my forcing file, but there are no NaN in it.
One thing I noticed:
I turn on WET_DRY, and I set depth of land area < 0.
I find that before model blows up, zeta in land area changed bigger(changed up tp 20m). (Why land-mask has zeta value??)
I wonder if this matters? (!!!!I CHECKED U V W BEFORE BLOW-UP, they are fine! all=zero )
Thanks!!
Maximum grid stiffness ratios: rx0 = 1.500000E-01 (Beckmann and Haidvogel)
rx1 = 5.728206E+00 (Haney)
Initial basin volumes: TotVolume = 6.3638374556E+10 m3
MinVolume = 2.5571097553E+02 m3
MaxVolume = 1.4785505052E+06 m3
Max/Min = 5.7821159305E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00029000)
GET_2DFLD - surface u-momentum stress, t = 0 02:24:00
(Rec=0000002, Index=2, File: stressTEST.nc)
(Tmin= 0.0000 Tmax= 3001.0000)
GET_2DFLD - surface v-momentum stress, t = 0 02:24:00
0 0 00:00:00 0.000000E+00 9.300949E+03 9.300949E+03 6.367420E+10
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: simplecase_his.nc
DEF_AVG - creating average file, Grid 01: simplecase_avg.nc
1 0 00:00:00 7.403984E-35 9.301714E+03 9.301714E+03 6.366897E+10
(073,204,01) 2.838148E-20 3.182801E-20 0.000000E+00 7.471913E-17
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000002
2 0 00:00:00 2.892330E-34 9.301714E+03 9.301714E+03 6.366897E+10
(058,226,25) 6.956945E-23 4.667068E-22 1.367662E-16 1.488681E-16
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000003
3 0 00:00:00 6.180541E-34 9.301714E+03 9.301714E+03 6.366897E+10
(058,226,25) 2.184770E-22 1.522074E-21 2.705075E-16 2.451863E-16
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000004
4 0 00:00:00 1.027599E-33 9.301714E+03 9.301714E+03 6.366897E+10
(048,263,25) 3.982611E-22 6.445907E-21 3.350156E-16 4.986654E-16
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000005
5 0 00:00:00 1.477361E-33 9.301714E+03 9.301714E+03 6.366897E+10
(057,240,25) 2.241456E-21 7.977925E-21 4.357218E-16 7.637114E-16
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000006
6 0 00:00:00 1.952023E-33 9.301714E+03 9.301714E+03 6.366897E+10
(086,192,25) 3.322778E-21 3.886765E-21 4.632618E-16 1.028624E-15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000007
7 0 00:00:00 2.444697E-33 9.301714E+03 9.301714E+03 6.366897E+10
(086,192,25) 4.586721E-21 2.804571E-21 5.329079E-16 1.293538E-15
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000008
8 0 00:00:00 3.007035E-33 9.301714E+03 9.301714E+03 6.366897E+10
(047,269,25) 5.364246E-21 2.059773E-20 5.409963E-16 1.558241E-15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000009
9 0 00:00:00 3.690863E-33 9.301714E+03 9.301714E+03 6.366897E+10
(059,225,25) 1.215610E-20 3.419549E-21 6.021904E-16 1.822926E-15
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000010
10 0 00:00:00 4.620259E-33 9.301714E+03 9.301714E+03 6.366897E+10
(058,238,25) 3.370067E-20 1.212422E-20 8.214504E-16 2.087500E-15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000011
11 0 00:00:01 5.830281E-33 9.301714E+03 9.301714E+03 6.366897E+10
(052,249,25) 2.251131E-21 7.650399E-21 1.012366E-15 2.351966E-15
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000012
12 0 00:00:01 7.741074E-33 9.301714E+03 9.301714E+03 6.366897E+10
(057,270,25) 2.112356E-21 3.158259E-20 1.175885E-15 2.616385E-15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000013
13 0 00:00:01 1.033973E-32 9.301714E+03 9.301714E+03 6.366897E+10
(057,270,25) 2.272178E-21 3.745048E-20 1.355493E-15 2.880627E-15
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000014
14 0 00:00:01 1.377428E-32 9.301714E+03 9.301714E+03 6.366897E+10
(055,247,25) 2.595464E-20 5.314083E-20 1.593740E-15 3.144802E-15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000015
15 0 00:00:01 1.782040E-32 9.301714E+03 9.301714E+03 6.366897E+10
(055,247,25) 2.649002E-20 4.711058E-20 1.979339E-15 3.408829E-15
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000016
16 0 00:00:01 2.255626E-32 9.301714E+03 9.301714E+03 6.366897E+10
(055,247,25) 3.381972E-20 6.569763E-20 2.318928E-15 3.672661E-15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000017
17 0 00:00:01 2.762860E-32 9.301714E+03 9.301714E+03 6.366897E+10
(063,217,25) 1.388260E-19 1.283977E-19 2.858346E-15 3.936374E-15
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000018
18 0 00:00:01 3.298347E-32 9.301714E+03 9.301714E+03 6.366897E+10
(063,217,25) 1.484557E-19 1.637055E-19 3.103611E-15 4.199973E-15
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000019
19 0 00:00:01 NaN NaN NaN 6.366897E+10
(063,217,25) 1.554516E-19 1.820026E-19 3.170670E-15 1.839072E-15
WRT_RST - wrote re-start fields (Index=2,2) into time record = 0000001
Elapsed CPU time (seconds):
Node # 0 CPU: 21.440
Total: 21.440
Nonlinear ocean model elapsed time profile, Grid: 01
Allocation and array initialization .............. 0.119 ( 0.5533 %)
Ocean state initialization ....................... 0.015 ( 0.0717 %)
Reading of input data ............................ 0.006 ( 0.0274 %)
Processing of input data ......................... 0.006 ( 0.0264 %)
Processing of output time averaged data .......... 0.011 ( 0.0502 %)
Computation of vertical boundary conditions ...... 0.031 ( 0.1456 %)
Computation of global information integrals ...... 0.135 ( 0.6315 %)
Writing of output data ........................... 2.427 (11.3187 %)
Model 2D kernel .................................. 3.937 (18.3644 %)
2D/3D coupling, vertical metrics ................. 0.145 ( 0.6742 %)
Omega vertical velocity .......................... 0.113 ( 0.5256 %)
Equation of state for seawater ................... 0.125 ( 0.5815 %)
GLS vertical mixing parameterization ............. 9.713 (45.3013 %)
3D equations right-side terms .................... 0.700 ( 3.2662 %)
3D equations predictor step ...................... 0.729 ( 3.4019 %)
Pressure gradient ................................ 0.358 ( 1.6705 %)
Harmonic mixing of tracers, geopotentials ........ 0.812 ( 3.7854 %)
Harmonic stress tensor, S-surfaces ............... 0.304 ( 1.4182 %)
Corrector time-step for 3D momentum .............. 0.555 ( 2.5868 %)
Corrector time-step for tracers .................. 0.628 ( 2.9313 %)
Total: 20.868 97.3319
Message Passage: 2D halo exchanges ............... 0.011 ( 0.0507 %)
Message Passage: 3D halo exchanges ............... 0.001 ( 0.0032 %)
Message Passage: 4D halo exchanges ............... 0.000 ( 0.0007 %)
Message Passage: data broadcast .................. 0.001 ( 0.0060 %)
Message Passage: data reduction .................. 0.000 ( 0.0008 %)
Message Passage: data gathering .................. 0.310 ( 1.4437 %)
Message Passage: data scattering.................. 0.020 ( 0.0942 %)
Message Passage: boundary data gathering ......... 0.000 ( 0.0006 %)
Total: 0.343 1.5999
All percentages are with respect to total time = 21.440
number of time records written in HISTORY file = 00000019
Analytical header files used:
ROMS/Functionals/ana_btflux.h
/home/ubuntu/app/COAWST_V3.2/Projects/simplecase/ana_fsobc.h
/home/ubuntu/app/COAWST_V3.2/Projects/simplecase/ana_m2obc.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Thursday - January 9, 2020 - 6:57:05 PM
#12 Unread post by kate »
With WET_DRY, zeta in the land area is always some DCRIT above the land, nothing to worry about. It should not be changing in time.
Have you tried fussing with your timestep?
zhangtianhao
#13 Unread post by zhangtianhao »
kate wrote: Thu Jan 09, 2020 11:48 am With WET_DRY, zeta in the land area is always some DCRIT above the land, nothing to worry about. It should not be changing in time.
I changed dt from 0.1 to 0.05, and it delays the blow-up time from 1.9s to 44s. I am keeping trying.
Here is the complete result.out.
And btw , my zeta in the land area seems too big, it nearly equals to height of land ~ sevral hundreds?(My forcing file cover the area of land, I doubt if it matters)
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian
Input Script :
SVN Root URL : https:://myroms.org/svn/src
SVN Revision : 65M
Local Root : /home/ubuntu/app/COAWST_V3.2
Header Dir : /home/ubuntu/app/COAWST_V3.2/Projects/simplecase
Header file : palu.h
Analytical Dir: /home/ubuntu/app/COAWST_V3.2/Projects/simplecase
Resolution, Grid 01: 0176x0279x025, Parallel Nodes: 1, Tiling: 001x001
29000 ntimes Number of timesteps for 3-D equations.
0.100 dt Timestep size (s) for 3-D equations.
120 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
360 nAVG Number of timesteps between the writing of
2.0000E-01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.0000E-01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E-01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
0.000 wec_alpha WEC factor for roller/breaking energy distribution.
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
1 levsfrc Deepest level to apply surface stress as a
bodyforce.
1 levbfrc Shallowest level to apply bottom stress as a
bodyforce.
6.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E-01 theta_b S-coordinate bottom control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
0.0000E+00 Tnudg_SSS Nudging/relaxation time scale (days)
for sea surface salinity.
for 3D momentum.
1025.000 R0 Background density (kg/m3) used in linear Equation
of State.
Output Restart File: simplecase_rst.nc
Output History File: simplecase_his.nc
Output Averages File: simplecase_avg.nc
Input Grid File: /home/ubuntu/app/COAWST_V3.2/Projects/simplecase/grid.nc
Input Nonlinear Initial File: /home/ubuntu/app/COAWST_V3.2/Projects/simplecase/init.nc
Input Forcing File 01: /home/ubuntu/app/COAWST_V3.2/Projects/simplecase/stressTEST.nc
Tile partition information for Grid 01: 0176x0279x0025 tiling: 001x001
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 176 1 279 1227600
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 176.50 0.50 279.50 RHO-points
0 1.00 176.00 0.50 279.50 U-points
0 0.50 176.50 1.00 279.00 V-points
HaloSizeI(1) = 374
HaloSizeJ(1) = 578
TileSide(1) = 283
TileSize(1) = 51223
ubar 1 Closed Flather Closed Flather
vbar 1 Closed Flather Closed Flather
u 1 Closed Gradient Closed Gradient
v 1 Closed Gradient Closed Gradient
temp 1 Closed Closed Closed Closed
salt 1 Closed Closed Closed Closed
tke 1 Closed Gradient Closed Gradient
PALU palu
BODYFORCE Momentum stresses as body-forces.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
WET_DRY Wetting and drying activated.
Process Information:
Node # 0 (pid= 27497) is active.
25 0.0000000 0.0000000 0.000 0.000 0.000 0.000
24 -0.0400000 -0.0001749 -0.060 -0.201 -0.308 -0.538
23 -0.0800000 -0.0007098 0.582 -0.404 -0.410 -1.368
22 -0.1200000 -0.0016353 1.988 -0.608 -0.290 -2.516
21 -0.1600000 -0.0030046 4.260 -0.815 0.084 -4.025
20 -0.2000000 -0.0048963 7.553 -1.024 0.755 -5.960
19 -0.2400000 -0.0074189 12.079 -1.237 1.785 -8.407
18 -0.2800000 -0.0107165 18.118 -1.454 3.258 -11.485
17 -0.3200000 -0.0149770 26.037 -1.675 5.279 -15.347
16 -0.3600000 -0.0204424 36.311 -1.902 7.988 -20.189
15 -0.4000000 -0.0274214 49.540 -2.137 11.559 -26.262
14 -0.4400000 -0.0363057 66.492 -2.382 16.216 -33.886
13 -0.4800000 -0.0475899 88.131 -2.638 22.241 -43.462
12 -0.5200000 -0.0618955 115.671 -2.909 29.988 -55.497
11 -0.5600000 -0.0799996 150.631 -3.200 39.901 -70.622
10 -0.6000000 -0.1028685 194.898 -3.514 52.530 -89.623
9 -0.6400000 -0.1316956 250.803 -3.858 68.555 -113.473
8 -0.6800000 -0.1679410 321.197 -4.240 88.809 -143.358
7 -0.7200000 -0.2133714 409.533 -4.667 114.299 -180.716
6 -0.7600000 -0.2700910 519.919 -5.150 146.224 -227.259
5 -0.8000000 -0.3405555 657.152 -5.703 185.984 -284.985
4 -0.8400000 -0.4275481 826.669 -6.338 235.166 -356.158
3 -0.8800000 -0.5340940 1034.379 -7.070 295.494 -443.241
2 -0.9200000 -0.6632759 1286.303 -7.916 368.726 -548.740
1 -0.9600000 -0.8179050 1587.932 -8.890 456.463 -674.944
0 -1.0000000 -1.0000000 1943.209 -10.000 559.857 -823.494
Time Splitting Weights for Grid 01: ndtfast = 20 nfast = 29
3-0.0011514592651644 0.0501156998674241-0.0034654566136460 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792859
6 0.0029141799764308 0.0501428056118168 0.0000580677400949 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865133 0.0497264335364439 0.0139401130576348 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767398 0.4496985103876601
10 0.0161716623600090 0.0486998273761630 0.0421751148367488 0.4983983377638231
11 0.0207585511322367 0.0478912442581626 0.0629336659689855 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430846 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924699 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366961 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873358 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240974 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194839 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038023 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834592 0.9445203630883545
23 0.0746596950216179 0.0177785909158270 0.7190878767050771 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669231 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836255 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321975 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447905
28 0.0292219798521905 0.0017718319739095 0.9937853403740003 0.9996892670187000
29 0.0062146596259993 0.0003107329813000 0.9999999999999997 1.0000000000000000
Minimum X-grid spacing, DXmin = 1.00256452E-01 km
Maximum X-grid spacing, DXmax = 1.00262565E-01 km
Minimum Y-grid spacing, DYmin = 9.95247380E-02 km
Maximum Y-grid spacing, DYmax = 9.95366015E-02 km
Minimum Z-grid spacing, DZmin = -7.95450909E+03 m
Maximum Z-grid spacing, DZmax = 3.92962302E+03 m
Minimum barotropic Courant Number = 1.83413880E-04
Maximum barotropic Courant Number = 6.36202595E-03
Maximum Coriolis Courant Number = 2.26677842E-07
- free-surface
- salinity
DEF_HIS - creating history file, Grid 01: palu_his.nc
DEF_AVG - creating average file, Grid 01: palu_avg.nc
Total: 21.440
Total: 0.343 1.5999
