Hello
kobl1201
Hello
#1 Unread post by kobl1201 »
When i run the mdoel, i have some problem from output file.
However, i can't understand the problem.
Which one can i change to slove the problem.
Here i uploaded *.in
stdout_new_V2.txt
(87.15 KiB) Downloaded 658 times
test.in
(129.37 KiB) Downloaded 747 times
Re: Hello
DEF_VAR - unable to define variable: Tobc_in
in NetCDF file: ../Projects/Output/UB_ocean_his_9_1k_linear_new.nc
Did you create the ../Projects/Output directory? Is there anything in it?
ljyouc
Re: Hello
#3 Unread post by ljyouc »
I have the same problem when i run the model:
I make several boundary and climatology files just like you.
Did you ever solve this problem?
Please help me~
ZhaoTH
Re: Hello
#4 Unread post by ZhaoTH »
I also have the same problem, I make several boundary forcing files like you two. But when I run the model, the running stopped at the first step and I got the log file as the attachment file.
Could you please give me some information on this? Many thanks!
Best,
Meng
logfile.txt
(139.96 KiB) Downloaded 600 times
Re: Hello
#5 Unread post by wilkin »
You are using PARALLEL_IO which is a very new option recently added to ROMS. If this is not essential to achieving the performance you need, disable that option.
I also notice that ROMS is unable to format DSTART and TIDE_START in the log file:
***********  dstart            Time-stamp assigned to model initialization (days).
***********  tide_start        Reference time origin for tidal forcing (days).
which likely means you have used the wrong syntax in roms.in.
