When i run the mdoel, i have some problem from output file.
However, i can't understand the problem.
Which one can i change to slove the problem.
Here i uploaded *.in
Hello
Re: Hello
I also have the same problem, I make several boundary forcing files like you two. But when I run the model, the running stopped at the first step and I got the log file as the attachment file.
Did you ever solve this problem?
Could you please give me some information on this? Many thanks!
Best,
Meng
Best,
Meng
- logfile.txt
- (139.96 KiB) Downloaded 240 times
Re: Hello
You are using PARALLEL_IO which is a very new option recently added to ROMS. If this is not essential to achieving the performance you need, disable that option.
I also notice that ROMS is unable to format DSTART and TIDE_START in the log file:
which likely means you have used the wrong syntax in roms.in.
*********** dstart Time-stamp assigned to model initialization (days).
*********** tide_start Reference time origin for tidal forcing (days).
