DIAG speed trouble / gridbuilder
hpd14thu
#1 Unread post by hpd14thu »
I'm trying to run ROMs by bulk forcing,and initial condition, but it blows up.
Because my area is near the coast and my blow-up point is in the shallow water area(~10m), I try to decrease my dt from 300s to 10s and decrease my N from 36 to 25.
It does work but it just delay the time of blow-up, not solve the problem.
So I think maybe there are some problems in my grid.file, and I generate my grid.nc by Gridbuilder, here is my result.out and grid.nc:
Thanks!!
 Model Input Parameters:  ROMS/TOMS version 3.7
                          Wednesday - September 11, 2019 -  6:00:18 PM
 mab
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : gfortran
 Compiler command : /usr/bin/mpif90
 Compiler flags   : -frepack-arrays -O3 -ffast-math -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian
 Input Script  :
 SVN Root URL  : https:://myroms.org/svn/src
 SVN Revision  : 65M
 Local Root    : /home/ubuntu/app/COAWST_V3.2
 Header Dir    : /home/ubuntu/app/COAWST_V3.2/Projects/mab
 Header file   : mab.h
 Analytical Dir: /home/ubuntu/app/COAWST_V3.2/Projects/mab
 Resolution, Grid 01: 0166x0198x030,  Parallel Nodes:   1,  Tiling: 001x001
     138240  ntimes            Number of timesteps for 3-D equations.
     10.000  dt                Timestep size (s) for 3-D equations.
         30  ndtfast           Number of timesteps for 2-D equations between
          1  ERstr             Starting ensemble/perturbation run number.
          1  ERend             Ending ensemble/perturbation run number.
          0  nrrec             Number of restart records to read from disk.
          T  LcycleRST         Switch to recycle time-records in restart file.
        120  nRST              Number of timesteps between the writing of data
                                 into restart fields.
          1  ninfo             Number of timesteps between print of information
                                 to standard output.
          T  ldefout           Switch to create a new output NetCDF file(s).
          1  nHIS              Number of timesteps between the writing fields
                                 into history file.
          1  ntsAVG            Starting timestep for the accumulation of output
                                 time-averaged data.
        360  nAVG              Number of timesteps between the writing of
 2.0000E-01  nl_tnu2(01)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 01: temp
 2.0000E-01  nl_tnu2(02)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 02: salt
 1.0000E-01  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          F  LuvSponge         Turning OFF sponge on horizontal momentum.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: salt
 1.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 1.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak           Background vertical mixing coefficient (m2/s)
                                 for turbulent energy.
 5.0000E-06  Akp_bak           Background vertical mixing coefficient (m2/s)
      3.000  gls_p             GLS stability exponent.
      1.500  gls_m             GLS turbulent kinetic energy exponent.
     -1.000  gls_n             GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin          GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin          GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0          GLS stability coefficient.
 1.4400E+00  gls_c1            GLS shear production coefficient.
 1.9200E+00  gls_c2            GLS dissipation coefficient.
-4.0000E-01  gls_c3m           GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p           GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk          GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp          GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha     Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha    Factor for Zos calculation using Hsig(Awave).
      0.250  sz_alpha          Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw         Factor for Craig/Banner surface tke flux.
      0.000  wec_alpha         WEC factor for roller/breaking energy distribution.
 3.0000E-04  rdrg              Linear bottom drag coefficient (m/s).
 2.5000E-02  rdrg2             Quadratic bottom drag coefficient.
 2.0000E-02  Zob               Bottom roughness (m).
 2.0000E-02  Zos               Surface roughness (m).
 2.0000E+00  blk_ZQ            Height (m) of surface air humidity measurement.
 2.0000E+00  blk_ZT            Height (m) of surface air temperature measurement.
 1.0000E+01  blk_ZW            Height (m) of surface winds measurement.
          1  lmd_Jwt           Jerlov water type.
          2  Vtransform        S-coordinate transformation equation.
          4  Vstretching       S-coordinate stretching function.
 5.0000E+00  theta_s           S-coordinate surface control parameter.
 4.0000E-01  theta_b           S-coordinate bottom  control parameter.
     50.000  Tcline            S-coordinate surface/bottom layer width (m) used
   1025.000  rho0              Mean density (kg/m3) for Boussinesq approximation.
      0.000  dstart            Time-stamp assigned to model initialization (days).
       0.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)         Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 0.0000E+00  Tnudg_SSS         Nudging/relaxation time scale (days)
                                 for sea surface salinity.
 0.0000E+00  Znudg             Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 0.0000E+00  obcfac            Factor between passive and active
          F  VolCons(1)        NLM western  edge boundary volume conservation.
          F  VolCons(2)        NLM southern edge boundary volume conservation.
          F  VolCons(3)        NLM eastern  edge boundary volume conservation.
          F  VolCons(4)        NLM northern edge boundary volume conservation.
     10.000  T0                Background potential temperature (C) constant.
     30.000  S0                Background salinity (PSU) constant.
      1.000  gamma2            Slipperiness variable: free-slip (1.0) or
          F  LuvSrc            Turning OFF momentum point Sources/Sinks.
          F  LwSrc             Turning OFF volume influx point Sources/Sinks.
          F  LtracerSrc(01)    Turning OFF point Sources/Sinks on tracer 01: temp
          F  LtracerSrc(02)    Turning OFF point Sources/Sinks on tracer 02: salt
          F  LsshCLM           Turning OFF processing of SSH climatology.
          F  Lm2CLM            Turning OFF processing of 2D momentum climatology.
          F  Lm3CLM            Turning OFF processing of 3D momentum climatology.
          F  LtracerCLM(01)    Turning OFF processing of climatology tracer 01: temp
          F  LtracerCLM(02)    Turning OFF processing of climatology tracer 02: salt
          F  LnudgeM2CLM       Turning OFF nudging of 2D momentum climatology.
          F  LnudgeM3CLM       Turning OFF nudging of 3D momentum climatology.
          F  LnudgeTCLM(01)    Turning OFF nudging of climatology tracer 01: temp
          F  LnudgeTCLM(02)    Turning OFF nudging of climatology tracer 02: salt
          T  Hout(idUvel)      Write out 3D U-momentum component.
          T  Hout(idVvel)      Write out 3D V-momentum component.
          T  Hout(idWvel)      Write out W-momentum component.
          T  Hout(idTvar)      Write out tracer 01: temp
          T  Hout(idTvar)      Write out tracer 02: salt
          T  Aout(idSdif)      Write out averaged vertical diffusion: AKt(isalt).
             Output Restart File:  mab_rst.nc
             Output History File:  mab_his.nc
            Output Averages File:  mab_avg.nc
                 Input Grid File:  /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_grid.nc
    Input Nonlinear Initial File:  /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_init.nc
           Input Forcing File 01:  /home/ubuntu/app/COAWST_V3.2/Projects/mab/mab_wind.nc
 Tile partition information for Grid 01:  0166x0198x0030  tiling: 001x001
 Number of tracers:            2
        0        1      166        1      198   986040
   (interior points only)
        0     0.50   166.50     0.50   198.50  RHO-points
        0     1.00   166.00     0.50   198.50    U-points
        0     0.50   166.50     1.00   198.00    V-points
               HaloSizeI(1) =     354
               HaloSizeJ(1) =     418
                TileSide(1) =     203
                TileSize(1) =   34713
 zeta                     1   Chapman Imp  Chapman Imp  Chapman Imp  Chapman Imp
 ubar                     1   Gradient     Gradient     Gradient     Gradient
 vbar                     1   Gradient     Gradient     Gradient     Gradient
 u                        1   Gradient     Gradient     Gradient     Gradient
 v                        1   Gradient     Gradient     Gradient     Gradient
 temp                     1   Gradient     Gradient     Gradient     Gradient
 salt                     1   Gradient     Gradient     Gradient     Gradient
 tke                      1   Gradient     Gradient     Gradient     Gradient
 MAB                 mab
 ATM_PRESS           Impose atmospheric pressure onto sea surface.
 BULK_FLUXES         Surface bulk fluxes parameterization.
 CHARNOK             Charnok surface roughness from wind stress.
 EMINUSP             Compute Salt Flux using E-P.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 K_GSCHEME           Third-order upstream advection of TKE fields.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 SOLAR_SOURCE        Solar Radiation Source Term.
 TS_U3HADVECTION     Third-order upstream horizontal advection of tracers.
 TS_DIF2             Harmonic mixing of tracers.
 UV_LOGDRAG          Logarithmic bottom stress.
 Process Information:
 Node #  0 (pid=    9629) is active.
 level   S-coord     Cs-curve   Z   at hmin       at hc    half way     at hmax
    30   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    29  -0.0333333  -0.0002307       -0.064      -0.839      -2.262      -2.912
    28  -0.0666667  -0.0009291       -0.128      -1.690      -5.791      -8.380
    27  -0.1000000  -0.0021144       -0.192      -2.553     -10.638     -16.508
    26  -0.1333333  -0.0038189       -0.257      -3.429     -16.892     -27.473
    25  -0.1666667  -0.0060892       -0.321      -4.319     -24.678     -41.529
    24  -0.2000000  -0.0089871       -0.385      -5.225     -34.164     -59.014
    23  -0.2333333  -0.0125913       -0.450      -6.148     -45.564     -80.359
    22  -0.2666667  -0.0169996       -0.514      -7.092     -59.141    -106.097
    21  -0.3000000  -0.0223307       -0.579      -8.058     -75.218    -136.878
    20  -0.3333333  -0.0287278       -0.643      -9.052     -94.182    -173.482
    19  -0.3666667  -0.0363614       -0.708     -10.076    -116.496    -216.843
    18  -0.4000000  -0.0454338       -0.773     -11.136    -142.706    -268.066
    17  -0.4333333  -0.0561830       -0.838     -12.238    -173.459    -328.450
    16  -0.4666667  -0.0688882       -0.903     -13.389    -209.509    -399.521
    15  -0.5000000  -0.0838752       -0.968     -14.597    -251.740    -483.061
    14  -0.5333333  -0.1015226       -1.033     -15.871    -301.177    -581.136
    13  -0.5666667  -0.1222681       -1.099     -17.223    -359.006    -696.139
    12  -0.6000000  -0.1466152       -1.165     -18.665    -426.590    -830.820
    11  -0.6333333  -0.1751391       -1.231     -20.212    -505.487    -988.324
    10  -0.6666667  -0.2084930       -1.298     -21.879    -597.467   -1172.218
     9  -0.7000000  -0.2474113       -1.365     -23.685    -704.518   -1386.515
     8  -0.7333333  -0.2927113       -1.433     -25.651    -828.855   -1635.681
     7  -0.7666667  -0.3452901       -1.501     -27.799    -972.908   -1924.618
     6  -0.8000000  -0.4061157       -1.570     -30.153   -1139.298   -2258.614
     5  -0.8333333  -0.4762095       -1.639     -32.739   -1330.792   -2643.251
     4  -0.8666667  -0.5566161       -1.709     -35.582   -1550.219   -3084.236
     3  -0.9000000  -0.6483588       -1.781     -38.709   -1800.352   -3587.160
     2  -0.9333333  -0.7523753       -1.853     -42.143   -2083.729   -4157.147
     1  -0.9666667  -0.8694298       -1.926     -45.902   -2402.422   -4798.372
     0  -1.0000000  -1.0000000       -2.000     -50.000   -2757.723   -5513.446
 Time Splitting Weights for Grid 01:    ndtfast =  30    nfast =  42
 12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
 13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
 15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
 16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
 17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
 18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
 19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
 20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
 21 0.0256737146312910 0.0297153720153352 0.1342125541712341 0.6900486906129490
 22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
 23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421600
 24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
 25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
 26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
 27 0.0432936737565711 0.0230872677537126 0.3506756411451922 0.8468812641730054
 28 0.0458596469320356 0.0216441452951603 0.3965352880772278 0.8685254094681656
 29 0.0481720587108284 0.0201154903974257 0.4447073467880562 0.8886408998655914
 30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
 31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
 32 0.0528456577069106 0.0151128305891453 0.5994607400325517 0.9391012217603267
 33 0.0533610761022577 0.0133513086655816 0.6528218161348094 0.9524525304259084
 34 0.0531891349131379 0.0115726061288397 0.7060109510479473 0.9640251365547481
 35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
 36 0.0503158038019031 0.0080591141492892 0.8085423793232265 0.9818838856691057
 37 0.0473537721847153 0.0063819206892258 0.8558961515079418 0.9882658063583315
 38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
 39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
 40 0.0305543017255206 0.0021094083123694 0.9672720523544377 0.9985427438187775
 41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
 42 0.0109897377911119 0.0003663245930371 1.0000000000000000 1.0000000000000000
 ndtfast, nfast =   30  42   nfast/ndtfast =  1.40000
 Power filter parameters, Fgamma, gamma =  0.28400   0.18933
 Minimum X-grid spacing, DXmin =  4.68165556E+00 km
 Maximum X-grid spacing, DXmax =  5.28701590E+00 km
 Minimum Y-grid spacing, DYmin =  5.03543630E+00 km
 Maximum Y-grid spacing, DYmax =  5.03543631E+00 km
 Minimum Z-grid spacing, DZmin =  6.41203105E-02 m
 Maximum Z-grid spacing, DZmax =  7.15073607E+02 m
 Minimum barotropic Courant Number =  4.08021179E-04
 Maximum barotropic Courant Number =  2.13261516E-02
 Maximum Coriolis   Courant Number =  9.78217235E-04
 NLM: GET_STATE - Read state initial conditions,             t =     0 00:00:00
                   (Grid 01, File: mab_init.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min = -1.41334683E-01 Max =  3.04189892E+01)
                - salinity
                   (Min =  0.00000000E+00 Max =  3.67799568E+01)
    GET_2DFLD   - surface u-wind component,                  t =     0 00:00:00
                   (Rec=0000001, Index=1, File: mab_wind.nc)
                   (Tmin=          0.0000 Tmax=         16.0000)
                   (Min = -2.48879018E+00 Max =  9.48846082E+00)
    GET_2DFLD   - surface v-wind component,                  t =     0 00:00:00
                   (Min = -3.85694262E+00 Max =  8.27674899E+00)
    GET_2DFLD   - surface air pressure,                      t =     0 00:00:00
                   (Min =  9.41213884E+02 Max =  1.02045113E+03)
    GET_2DFLD   - surface air temperature,                   t =     0 00:00:00
                   (Min =  1.99932619E+01 Max =  2.83775444E+01)
    GET_2DFLD   - surface air relative humidity,             t =     0 00:00:00
                   (Min =  6.49802349E-01 Max =  9.73909050E-01)
    GET_2DFLD   - solar shortwave radiation flux,            t =     0 00:00:00
                   (Min =  5.84608824E-05 Max =  1.85498452E-04)
    GET_2DFLD   - net longwave radiation flux,               t =     0 00:00:00
                   (Min = -3.63744317E-05 Max =  8.11468262E-07)
    GET_2DFLD   - rain fall rate,                            t =     0 00:00:00
                   (Min = -7.73038670E-05 Max =  6.48162364E-04)
 Maximum grid stiffness ratios:  rx0 =   1.000000E-01 (Beckmann and Haidvogel)
                                 rx1 =   5.221597E+00 (Haney)
 Initial basin volumes: TotVolume =  1.5937623726E+15 m3
                        MinVolume =  1.5137425177E+06 m3
                        MaxVolume =  1.8977905830E+10 m3
                          Max/Min =  1.2537076556E+04
 NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00138240)
    GET_2DFLD   - surface u-wind component,                  t =     0 00:30:00
                   (Rec=0000002, Index=2, File: mab_wind.nc)
                   (Min = -2.67755614E+00 Max =  9.68387638E+00)
    GET_2DFLD   - surface v-wind component,                  t =     0 00:30:00
                   (Min = -3.95093540E+00 Max =  7.99857274E+00)
    GET_2DFLD   - surface air pressure,                      t =     0 00:30:00
                   (Min =  9.41149331E+02 Max =  1.02057863E+03)
    GET_2DFLD   - surface air temperature,                   t =     0 00:30:00
                   (Min =  2.01950278E+01 Max =  2.84300235E+01)
    GET_2DFLD   - surface air relative humidity,             t =     0 00:30:00
                   (Min =  5.93761673E-01 Max =  9.72107867E-01)
    GET_2DFLD   - solar shortwave radiation flux,            t =     0 00:30:00
                   (Min =  6.46495803E-05 Max =  1.92980171E-04)
    GET_2DFLD   - net longwave radiation flux,               t =     0 00:30:00
                   (Min = -3.78018656E-05 Max =  3.42369378E-07)
    GET_2DFLD   - rain fall rate,                            t =     0 00:30:00
                   (Min = -6.36967807E-05 Max =  6.65809200E-04)
       0     0 00:00:00  0.000000E+00  2.106255E+04  2.106255E+04  1.594152E+15
          (000,000,00)  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00
      DEF_HIS   - creating history file, Grid 01: mab_his.nc
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000001
      DEF_AVG   - creating average file, Grid 01: mab_avg.nc
       1     0 00:00:10  1.474962E-05  2.106255E+04  2.106255E+04  1.594152E+15
          (067,045,01)  2.081455E-04  2.226696E-04  0.000000E+00  1.570205E-01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000002
       2     0 00:00:20  5.726974E-05  2.106180E+04  2.106180E+04  1.594152E+15
          (159,118,30)  4.118950E-06  2.986013E-06  8.557346E-02  3.124298E-01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000003
       3     0 00:00:30  1.130670E-04  2.106142E+04  2.106142E+04  1.594152E+15
          (070,050,30)  4.464227E-07  4.262684E-06  1.164615E-01  2.710172E-01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000004
       4     0 00:00:40  1.969253E-04  2.106127E+04  2.106127E+04  1.594152E+15
          (164,122,30)  2.158154E-05  1.606934E-05  1.272829E-01  3.175687E-01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000005
       5     0 00:00:50  3.167680E-04  2.106114E+04  2.106114E+04  1.594152E+15
          (074,045,30)  3.780017E-05  8.853016E-06  1.371968E-01  3.978551E-01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000006
       6     0 00:01:00  4.717874E-04  2.106102E+04  2.106102E+04  1.594152E+15
          (132,105,30)  2.712113E-05  2.219168E-05  1.241226E-01  4.806186E-01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000007
       7     0 00:01:10  6.546889E-04  2.106090E+04  2.106090E+04  1.594152E+15
          (157,118,30)  8.165194E-07  6.964529E-05  1.233353E-01  5.604440E-01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000008
       8     0 00:01:20  8.636625E-04  2.106078E+04  2.106078E+04  1.594152E+15
          (068,048,30)  4.686715E-05  1.408874E-05  1.115997E-01  6.374340E-01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000009
       9     0 00:01:30  1.098067E-03  2.106067E+04  2.106067E+04  1.594152E+15
          (069,050,30)  4.513706E-05  3.924901E-05  1.225895E-01  7.098138E-01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000010
      10     0 00:01:40  1.357416E-03  2.106055E+04  2.106055E+04  1.594152E+15
          (069,050,30)  5.004504E-05  4.354835E-05  1.199431E-01  7.764920E-01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000011
      11     0 00:01:50  1.641256E-03  2.106044E+04  2.106045E+04  1.594152E+15
          (159,118,30)  3.209828E-04  1.929475E-04  1.272818E-01  8.377186E-01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000012
     619     0 01:43:10  1.658293E+00  2.107103E+04  2.107269E+04  1.596544E+15
          (140,167,30)  3.801504E-04  1.139325E-03  2.546639E-01  1.852424E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000620
     620     0 01:43:20  1.661794E+00  2.107107E+04  2.107273E+04  1.596555E+15
          (140,167,30)  4.120010E-04  1.009199E-03  2.572201E-01  1.858495E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000621
     621     0 01:43:30  1.665306E+00  2.107112E+04  2.107278E+04  1.596566E+15
          (140,167,30)  4.441568E-04  8.789347E-04  2.589819E-01  1.864356E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000622
     622     0 01:43:40  1.668829E+00  2.107116E+04  2.107283E+04  1.596577E+15
          (140,167,30)  4.765161E-04  7.488287E-04  2.599243E-01  1.869997E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000623
     623     0 01:43:50  1.672362E+00  2.107120E+04  2.107287E+04  1.596588E+15
          (140,167,30)  5.089691E-04  6.191760E-04  2.600256E-01  1.875406E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000624
     624     0 01:44:00  1.675906E+00  2.107125E+04  2.107292E+04  1.596599E+15
          (140,167,30)  5.413992E-04  4.902709E-04  2.592699E-01  1.880570E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000625
     625     0 01:44:10  1.679460E+00  2.107129E+04  2.107297E+04  1.596609E+15
          (140,167,30)  5.736834E-04  3.624010E-04  2.576449E-01  1.885473E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000626
     626     0 01:44:20  1.683026E+00  2.107133E+04  2.107302E+04  1.596620E+15
          (140,167,30)  6.056935E-04  2.358515E-04  2.551452E-01  1.890101E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000627
     627     0 01:44:30  1.686602E+00  2.107137E+04  2.107306E+04  1.596631E+15
          (140,167,30)  6.372968E-04  1.109013E-04  2.517701E-01  1.894441E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000628
     628     0 01:44:40  1.690190E+00  2.107142E+04  2.107311E+04  1.596642E+15
          (140,167,30)  6.683570E-04  1.217988E-05  2.475228E-01  1.898484E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000629
     629     0 01:44:50  1.693789E+00  2.107146E+04  2.107315E+04  1.596653E+15
          (140,167,30)  6.987361E-04  1.331444E-04  2.424144E-01  1.902216E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000630
     630     0 01:45:00  1.697399E+00  2.107150E+04  2.107320E+04  1.596664E+15
          (139,167,30)  4.156946E-04  1.642476E-04  2.380592E-01  1.905627E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000631
     631     0 01:45:10  1.701021E+00  2.107154E+04  2.107324E+04  1.596675E+15
          (139,167,30)  4.480066E-04  3.630090E-05  2.353832E-01  1.908706E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000632
     632     0 01:45:20  1.704655E+00  2.107158E+04  2.107329E+04  1.596686E+15
          (139,167,30)  4.802085E-04  9.003822E-05  2.319888E-01  1.911437E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000633
     633     0 01:45:30  1.708300E+00  2.107162E+04  2.107333E+04  1.596697E+15
          (139,167,30)  5.121477E-04  2.145089E-04  2.278763E-01  1.913807E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000634
     634     0 01:45:40  1.711957E+00  2.107166E+04  2.107338E+04  1.596708E+15
          (138,167,30)  3.037492E-04  5.003511E-05  2.240180E-01  1.915798E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000635
     635     0 01:45:50  1.715625E+00  2.107170E+04  2.107342E+04  1.596719E+15
          (138,167,30)  3.360824E-04  7.797287E-05  2.224510E-01  1.917396E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000636
     636     0 01:46:00  1.719306E+00  2.107174E+04  2.107346E+04  1.596730E+15
          (141,168,30)  4.681722E-04  1.569754E-03  2.204796E-01  1.918581E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000637
     637     0 01:46:10  1.722999E+00  2.107178E+04  2.107351E+04  1.596741E+15
          (141,168,30)  5.114005E-04  1.448164E-03  2.270326E-01  1.919337E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000638
     638     0 01:46:20  1.726705E+00  2.107182E+04  2.107355E+04  1.596752E+15
          (141,168,30)  5.545455E-04  1.325004E-03  2.330064E-01  1.919646E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000639
     639     0 01:46:30  1.730423E+00  2.107186E+04  2.107359E+04  1.596763E+15
          (141,168,30)  5.974899E-04  1.200562E-03  2.383535E-01  1.919491E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000640
     640     0 01:46:40  1.734153E+00  2.107190E+04  2.107363E+04  1.596774E+15
          (141,168,30)  6.401129E-04  1.075132E-03  2.430289E-01  1.918855E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000641
     641     0 01:46:50  1.737897E+00  2.107194E+04  2.107367E+04  1.596785E+15
          (141,168,30)  6.822854E-04  9.490107E-04  2.469923E-01  1.917722E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000642
     642     0 01:47:00  1.741653E+00  2.107197E+04  2.107372E+04  1.596797E+15
          (141,168,30)  7.238744E-04  8.224959E-04  2.502056E-01  1.916079E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000643
     643     0 01:47:10  1.745423E+00  2.107201E+04  2.107376E+04  1.596808E+15
          (141,168,30)  7.647434E-04  6.958907E-04  2.526361E-01  1.913909E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000644
     644     0 01:47:20  1.749206E+00  2.107205E+04  2.107380E+04  1.596819E+15
          (141,168,30)  8.047537E-04  5.694942E-04  2.542537E-01  1.911200E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000645
     645     0 01:47:30  1.753002E+00  2.107209E+04  2.107384E+04  1.596830E+15
          (140,168,30)  4.262115E-04  1.029449E-03  2.573854E-01  1.907935E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000646
     646     0 01:47:40  1.756812E+00  2.107212E+04  2.107388E+04  1.596841E+15
          (140,168,30)  4.607835E-04  8.916500E-04  2.605302E-01  1.904100E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000647
     647     0 01:47:50  1.760636E+00  2.107216E+04  2.107392E+04  1.596853E+15
          (140,168,30)  4.955185E-04  7.537136E-04  2.629026E-01  1.899628E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000648
     648     0 01:48:00  1.764474E+00  2.107220E+04  2.107396E+04  1.596864E+15
          (140,168,30)  5.303083E-04  6.159594E-04  2.644709E-01  1.894445E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000649
     649     0 01:48:10  1.768327E+00  2.107224E+04  2.107400E+04  1.596875E+15
          (140,168,30)  5.650380E-04  4.787081E-04  2.652086E-01  1.888488E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000650
     650     0 01:48:20  1.772193E+00  2.107227E+04  2.107405E+04  1.596886E+15
          (140,168,30)  5.995872E-04  3.422804E-04  2.650944E-01  1.895415E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000651
     651     0 01:48:30  1.776074E+00  2.107231E+04  2.107409E+04  1.596898E+15
          (139,168,30)  3.477611E-04  7.265965E-04  2.640069E-01  1.912164E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000652
     652     0 01:48:40  1.779969E+00  2.107235E+04  2.107413E+04  1.596909E+15
          (139,168,30)  3.785930E-04  5.851489E-04  2.652985E-01  1.928908E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000653
     653     0 01:48:50  1.783880E+00  2.107238E+04  2.107417E+04  1.596920E+15
          (139,168,30)  4.098338E-04  4.441161E-04  2.658315E-01  1.945642E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000654
     654     0 01:49:00  1.787804E+00  2.107242E+04  2.107421E+04  1.596932E+15
          (139,168,30)  4.413740E-04  3.038135E-04  2.655815E-01  1.962355E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000655
     655     0 01:49:10  1.791745E+00  2.107246E+04  2.107425E+04  1.596943E+15
          (139,168,30)  4.730971E-04  1.645623E-04  2.645303E-01  1.979045E+01
      WRT_HIS   - wrote history  fields (Index=1,2) into time record = 0000656
     656     0 01:49:20  1.795702E+00  2.107249E+04  2.107429E+04  1.596955E+15
          (139,168,30)  5.048801E-04  2.667614E-05  2.626610E-01  1.995709E+01
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000657
     657     0 01:49:30  1.799675E+00  2.107253E+04  2.107433E+04  1.596966E+15
          (139,168,30)  5.365946E-04  1.095268E-04  2.599640E-01  2.012343E+01
 DIAG speed trouble    20.123425742763210
      WRT_RST   - wrote re-start fields (Index=1,2) into time record = 0000003
 Elapsed CPU time (seconds):
 Node   #  0 CPU:     660.815
 Total:               660.815
 Nonlinear ocean model elapsed time profile, Grid: 01
  Allocation and array initialization ..............         0.100  ( 0.0152 %)
  Ocean state initialization .......................         0.012  ( 0.0018 %)
  Reading of input data ............................         0.040  ( 0.0061 %)
  Processing of input data .........................         0.274  ( 0.0414 %)
  Processing of output time averaged data ..........         0.848  ( 0.1284 %)
  Computation of vertical boundary conditions ......         0.655  ( 0.0991 %)
  Computation of global information integrals ......         3.277  ( 0.4959 %)
  Writing of output data ...........................       128.570  (19.4562 %)
  Model 2D kernel ..................................        85.940  (13.0052 %)
  2D/3D coupling, vertical metrics .................         3.385  ( 0.5123 %)
  Omega vertical velocity ..........................         2.972  ( 0.4497 %)
  Equation of state for seawater ...................        10.297  ( 1.5583 %)
  Atmosphere-Ocean bulk flux parameterization ......        38.018  ( 5.7533 %)
  GLS vertical mixing parameterization .............       257.001  (38.8916 %)
  3D equations right-side terms ....................        15.098  ( 2.2848 %)
  3D equations predictor step ......................        51.076  ( 7.7292 %)
  Pressure gradient ................................         8.158  ( 1.2346 %)
  Harmonic mixing of tracers, geopotentials ........        13.345  ( 2.0195 %)
  Harmonic stress tensor, S-surfaces ...............         6.764  ( 1.0236 %)
  Corrector time-step for 3D momentum ..............        13.868  ( 2.0986 %)
  Corrector time-step for tracers ..................        17.487  ( 2.6463 %)
                                              Total:       657.187   99.4509
  Message Passage: 2D halo exchanges ...............         0.310  ( 0.0468 %)
  Message Passage: 3D halo exchanges ...............         0.018  ( 0.0028 %)
  Message Passage: 4D halo exchanges ...............         0.005  ( 0.0008 %)
  Message Passage: data broadcast ..................         0.013  ( 0.0020 %)
  Message Passage: data reduction ..................         0.004  ( 0.0007 %)
  Message Passage: data gathering ..................        25.447  ( 3.8508 %)
  Message Passage: data scattering..................         0.020  ( 0.0030 %)
                                              Total:        25.817    3.9068
 All percentages are with respect to total time =          660.815
             number of time records written in HISTORY file = 00000657
             number of time records written in RESTART file = 00000006
             number of time records written in AVERAGE file = 00000001
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
 ROMS/TOMS: DONE... Wednesday - September 11, 2019 -  6:11:30 PM
Thank you!
mab_grid.nc
(5.11 MiB) Downloaded 484 times
mab_grid.nc
(5.11 MiB) Downloaded 530 times
Re: DIAG speed trouble / gridbuilder
You might still need to reduce the timestep. You ran long enough that you should be getting close.
#3 Unread post by wilkin »
With a minimum grid cell size of ~4 km you should be well within CFL stability with such a small time step, so that's not your problem.
The log indicates a 3rd record was written to the restart file on blow-up, so you should plot what's in there and look for a location that is causing trouble. It could be the boundary, or the interior, deep, or shallow, but it will give you some guidance.
Your choice of open boundary conditions is unconventional - gradient on all but zeta. If the blow-up is near a boundary you might experiment further there.
You have negative rainfall rates in your forcing file - what's that?
hpd14thu
#4 Unread post by hpd14thu »
wilkin wrote:With a minimum grid cell size of ~4 km you should be well within CFL stability with such a small time step, so that's not your problem.
The log indicates a 3rd record was written to the restart file on blow-up, so you should plot what's in there and look for a location that is causes trouble. It could be the boundary, or the interior, deep, or shallow, but it will give you some guidance.
Your choice of open boundary conditions is unconventional - gradient on all but zeta. It the blow-up is near a boundary you might experiment further there.
Thank for your reply, Kate and Wilkin! I have modified my model, but there are still some problems
The blow-point is near the boudary, and if I change the boudary condition, it appears in the shallow water area, as shown in the picture below:
1)As for the boundary condition, because I don't have the boundary data and I just want to run a little case, I set GRA on all but zeta. Now I have change it into
Gra Clo Gra Clo, but it is still a little strange in my left-down corner, as shown in the picture below, which I think results from the boundary conditon;
2)As for the shallow water area, because my water depth varies from 2m to 4000m, I change hmin from 2m to 20m and turn on WET_DRY. But there is still wierd in right side of my result, as shown in the picture below;
3)As for the negative rainfall rates, that was my fault and I have modified it.
