River bottom salinity too high
WANGQIAN
#1 Unread post by WANGQIAN »
Hi everyone
I make river forcing file and make salinity zero every time in this file.
And in .in file like this
LuvSrc == T ! horizontal momentum transport
LtracerSrc == F T ! temperature, salinity, inert
In .log file ,OceanM reads data correctly, like this
GET_NGFLD - river runoff mass transport, 2013-03-01 00:00:00.00
(Grid= 01, Rec=0000003, Index=2, File: scs_river.nc)
(Tmin= 0.0000 Tmax= 1795.0000) t = 59.0000
(Min = 2.52794889E+02 Max = 2.24987452E+03)
GET_NGFLD - river runoff salinity, 2013-03-01 00:00:00.00
But in avg.nc file, at mouth of river, the bottom salinity is very high, more than 100!
Absolutely , my model has blew up. But I don't know whats wrong with me.
Can anyone help me ?
My river forcing file is monthly ,but my forcing file is 3-hour step.
this picture shows bottom salinity,and the curve shows salinity changing with s_rho.
Re: River bottom salinity too high
I don't know about the salt, but you need to set the temperature tracer on inflow as well. The only time you can skip setting the river tracers is when your rivers all flow outward. If you don't on inflow, the model will go unstable.
WANGQIAN
#3 Unread post by WANGQIAN »
kate wrote:I don't know about the salt, but you need to set the temperature tracer on inflow as well. The only time you can skip setting the river tracers is when your rivers all flow outward. If you don't on inflow, the model will go unstable.
Thank you kate , I will try this.
But in wikiroms/river_runoff, it says:
The introduction of tracer fluxes at point sources/sinks is activated with a second set of logical flags.
LtracerSrc == F T ! temperature, salinity, inert ...
This example says impose salinity but not temperature conditions in the river inflow. This requires that variable "river_salt" is present in the river forcing NetCDF, or is set in ana_psource.h.
So, is it feasible that only setting the salt tracer on?
Yours
WangQian
Yes, ROMS will let you do that. The numerics will not be stable.
m.hadfield
I don't know if this is relevant here, but even with a well-specified river, ROMS tends to generate an estuarine flow (outflow at the surface, inflow at the bottom) at the grid cell the river enters. The advection scheme can then generate hypersaline water at the bottom, which tends to form a plume flowing down the shelf in the bottom layer. There are various things you can do to minimise this: the main one is to use a river mass flow profile (Vshape) that is largest near the surface and zero at the bottom.
And to second Kate, it is highly recommended to specify all tracers in the river flow. If you don't do this, you get the worst sort of instability: one that lies dormant waiting to crop up at the time of maximum inconvenience.
jivica
#6 Unread post by jivica »
Adding my 2c to the topic;
I am running "many rivers scenario" without specifying temperature (only salinity) of the river sources and all is working fine (this option is using ambient ocean temperature for river sources as I don't know exactly temperature and it is shallow and really similar to the ocean values anyway).
As Mark wrote, you have to be careful about specifying vertical flux and usually we define strong inflow at the surface using river_Vshape. If you can upload your river forcing file then we could check and possibly give you advice if it is wrong. On the other hand are you sure you have correct river_Eposition and river_Xposition defined? Long time ago Rich Signell made map_rivers.m that is plotting your grid and river forcing file so you can check it quickly.
Cheers
Ivica
WANGQIAN
#7 Unread post by WANGQIAN »
Thank you kate, mark and Ivica,
I find some error with my river forcing file. When I do my python script, some transport data is positive for outflow :oops: . Now I fix them, the model is stable.
And I only use salt trace with all Vshape equal.
If the model gets unstable, I will adjust them.
Thank you again! :D
Yours
WangQian
m.hadfield
#8 Unread post by m.hadfield »
If you're lucky it will continue to do so. :wink:
dullman
#9 Unread post by dullman »
I have also encountered this problem of hypersaline water at depth near river inflow points. In addition to the suggestion that the inflow be specified (using Vshape) to be stronger at the surface, I have also found that making the water depth uniform in a small area around the inflow point helps to alleviate this problem.
jivica
#10 Unread post by jivica »
Actually the best option would be to dig a uniform depth/width channel inland (a few pixels should be enough) and have mixing processes happening "over the land", so once entering the ocean it is as should be.
Ivica
