Boundary condition type definition at river point sources
Eugen
#1 Unread post by Eugen »
I have a problem with tidal forcing on my domain. The tidal amplitudes are too big in semi-closed bays.
How to define a boundary condition type at river point sources (like we have to do for open boundaries), to make the tides propagate?
The image below is a bias in [m]: M2 tidal amplitudes from ROMS results minus the corresponding TPXO focring.
Evgeny Ivanov
PostDoc,
MAST, University of Liege, Belgium
Re: Boundary condition type definition at river point source
Tides are only forced at the open boundaries, not at rivers. You'll probably have to do something like increase the bottom drag in those bays. We have a bottom drag that's a function of depth for just such cases.
jivica
#3 Unread post by jivica »
Seems to me that tidal forcing doesn't match :?: :!: at your northern region either, this is where your BC are.
You can have amplification in the the bays, like resonance, and if you are having say 10% wrong BC than that can result with large errors elsewhere, even more in bays like that, sensitive to those periods.
I would check my BC and analysis if were you, then worry about river inlets..
Good luck!
Cheers
Ivica
