Scarlett
#1 Unread post by Scarlett »
Hi modelers:
I'm working with roms-3.7 and when I run my model,it blow up at seven time steps. If I change the passage of time, I only get a blow up delayed.
I will add my out.txt, my ocean.in and my .h file.
If somebody can help me I will be so gratefull for ever :D
Thanks in advance.
Mar.Mo.
out_teh.txt
(32.56 KiB) Downloaded 689 times
tehuantepec.h
(25.22 KiB) Downloaded 686 times
ocean_tehuantepec.in
(129.77 KiB) Downloaded 770 times
Re: Blowing-up: Saving latest model state into RESTART file
I've written the generic response here. Perhaps you should tell us what you are trying to achieve with a periodic channel and wetting and drying - but look to see how it's going bad first.
lalvarez
#3 Unread post by lalvarez »
Hello Scarlett
You should also take a look at this
Maximum grid stiffness ratios: rx0 = 9.963796E-01 (Beckmann and Haidvogel)
rx1 = 1.931157E+01 (Haney)
It is greater than 0.4, perhaps you need to smooth your grid
Can you share a map or figure of your area?
Saluditos
Scarlett
#4 Unread post by Scarlett »
Hi!
Many thanks to both for your help.
I had smoothing the grid ... step by step to the extent that I smoothing at 2000m deep, because I only have interesting in the first 200 m of the surface, but I still have the same problem ...
My Beckmann value still been 9.943090e-1 although the grid is so smoothing
Output Restart File: /home/ahumada/Roms_tools/Run/SCRATCH/ocean_rst.nc
Output History File: /home/ahumada/Roms_tools/Run/SCRATCH/ocean_his.nc
Output Diagnostics File: /home/ahumada/Roms_tools/Run/SCRATCH/ocean_dia.nc
Input Grid File: /home/ahumada/roms-3.7/ROMS/External/tehua4srp5_roms_grd.nc
Tile partition information for Grid 01: 0088x0088x0032 tiling: 002x012
tile Istr Iend Jstr Jend Npts
0 1 44 1 4 5632
1 45 88 1 4 5632
2 1 44 5 12 11264
3 45 88 5 12 11264
4 1 44 13 20 11264
5 45 88 13 20 11264
6 1 44 21 28 11264
7 45 88 21 28 11264
8 1 44 29 36 11264
9 45 88 29 36 11264
10 1 44 37 44 11264
11 45 88 37 44 11264
12 1 44 45 52 11264
13 45 88 45 52 11264
14 1 44 53 60 11264
15 45 88 53 60 11264
16 1 44 61 68 11264
17 45 88 61 68 11264
18 1 44 69 76 11264
19 45 88 69 76 11264
20 1 44 77 84 11264
21 45 88 77 84 11264
22 1 44 85 88 5632
23 45 88 85 88 5632
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -1.50 91.50 0.50 90.50 RHO-points
1 -2.50 90.50 0.50 90.50 RHO-points
2 -1.50 91.50 -0.50 90.50 RHO-points
3 -2.50 90.50 -0.50 90.50 RHO-points
4 -1.50 91.50 -0.50 90.50 RHO-points
5 -2.50 90.50 -0.50 90.50 RHO-points
6 -1.50 91.50 -0.50 90.50 RHO-points
7 -2.50 90.50 -0.50 90.50 RHO-points
8 -1.50 91.50 -0.50 90.50 RHO-points
9 -2.50 90.50 -0.50 90.50 RHO-points
10 -1.50 91.50 -0.50 90.50 RHO-points
11 -2.50 90.50 -0.50 90.50 RHO-points
12 -1.50 91.50 -0.50 90.50 RHO-points
13 -2.50 90.50 -0.50 90.50 RHO-points
14 -1.50 91.50 -0.50 90.50 RHO-points
15 -2.50 90.50 -0.50 90.50 RHO-points
16 -1.50 91.50 -0.50 90.50 RHO-points
17 -2.50 90.50 -0.50 90.50 RHO-points
18 -1.50 91.50 -0.50 90.50 RHO-points
19 -2.50 90.50 -0.50 90.50 RHO-points
20 -1.50 91.50 -0.50 90.50 RHO-points
21 -2.50 90.50 -0.50 90.50 RHO-points
22 -1.50 91.50 -0.50 89.50 RHO-points
23 -2.50 90.50 -0.50 89.50 RHO-points
0 -2.00 91.50 0.50 90.50 U-points
1 -2.50 90.00 0.50 90.50 U-points
2 -2.00 91.50 -0.50 90.50 U-points
3 -2.50 90.00 -0.50 90.50 U-points
4 -2.00 91.50 -0.50 90.50 U-points
5 -2.50 90.00 -0.50 90.50 U-points
6 -2.00 91.50 -0.50 90.50 U-points
7 -2.50 90.00 -0.50 90.50 U-points
8 -2.00 91.50 -0.50 90.50 U-points
9 -2.50 90.00 -0.50 90.50 U-points
10 -2.00 91.50 -0.50 90.50 U-points
11 -2.50 90.00 -0.50 90.50 U-points
12 -2.00 91.50 -0.50 90.50 U-points
13 -2.50 90.00 -0.50 90.50 U-points
14 -2.00 91.50 -0.50 90.50 U-points
15 -2.50 90.00 -0.50 90.50 U-points
16 -2.00 91.50 -0.50 90.50 U-points
17 -2.50 90.00 -0.50 90.50 U-points
18 -2.00 91.50 -0.50 90.50 U-points
19 -2.50 90.00 -0.50 90.50 U-points
20 -2.00 91.50 -0.50 90.50 U-points
21 -2.50 90.00 -0.50 90.50 U-points
22 -2.00 91.50 -0.50 89.50 U-points
23 -2.50 90.00 -0.50 89.50 U-points
0 -1.50 91.50 0.00 90.50 V-points
1 -2.50 90.50 0.00 90.50 V-points
2 -1.50 91.50 -0.50 90.50 V-points
3 -2.50 90.50 -0.50 90.50 V-points
4 -1.50 91.50 -0.50 90.50 V-points
5 -2.50 90.50 -0.50 90.50 V-points
6 -1.50 91.50 -0.50 90.50 V-points
7 -2.50 90.50 -0.50 90.50 V-points
8 -1.50 91.50 -0.50 90.50 V-points
9 -2.50 90.50 -0.50 90.50 V-points
10 -1.50 91.50 -0.50 90.50 V-points
11 -2.50 90.50 -0.50 90.50 V-points
12 -1.50 91.50 -0.50 90.50 V-points
13 -2.50 90.50 -0.50 90.50 V-points
14 -1.50 91.50 -0.50 90.50 V-points
15 -2.50 90.50 -0.50 90.50 V-points
16 -1.50 91.50 -0.50 90.50 V-points
17 -2.50 90.50 -0.50 90.50 V-points
18 -1.50 91.50 -0.50 90.50 V-points
19 -2.50 90.50 -0.50 90.50 V-points
20 -1.50 91.50 -0.50 90.50 V-points
21 -2.50 90.50 -0.50 90.50 V-points
22 -1.50 91.50 -0.50 89.00 V-points
23 -2.50 90.50 -0.50 89.00 V-points
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
tke 1 Periodic Closed Periodic Closed
tehuantepec
ANA_SRFLUX Analytical kinematic shortwave radiation flux.
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
OUT_DOUBLE Double precision output fields in NetCDF files.
_OPENMP OpenMP parallel shared-memory directives.
PERFECT_RESTART Processing perfect restart variables.
SALINITY Using salinity.
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion.
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_LDRAG Linear bottom stress.
WET_DRY Wetting and drying activated.
Process Information:
Thread # 11 (pid= 5394) is active.
Thread # 18 (pid= 5394) is active.
Thread # 7 (pid= 5394) is active.
Thread # 0 (pid= 5394) is active.
Thread # 20 (pid= 5394) is active.
Thread # 15 (pid= 5394) is active.
Thread # 5 (pid= 5394) is active.
Thread # 17 (pid= 5394) is active.
Thread # 9 (pid= 5394) is active.
Thread # 22 (pid= 5394) is active.
Thread # 13 (pid= 5394) is active.
Thread # 1 (pid= 5394) is active.
Thread # 3 (pid= 5394) is active.
Thread # 23 (pid= 5394) is active.
Thread # 16 (pid= 5394) is active.
Thread # 6 (pid= 5394) is active.
Thread # 4 (pid= 5394) is active.
Thread # 12 (pid= 5394) is active.
Thread # 14 (pid= 5394) is active.
Thread # 8 (pid= 5394) is active.
Thread # 10 (pid= 5394) is active.
Thread # 21 (pid= 5394) is active.
Thread # 19 (pid= 5394) is active.
Thread # 2 (pid= 5394) is active.
32 0.0000000 0.0000000 0.000 0.000 0.000 0.000
31 -0.0312500 -0.0002027 -0.157 -0.157 -0.511 -0.714
30 -0.0625000 -0.0008157 -0.317 -0.317 -1.431 -2.245
29 -0.0937500 -0.0018538 -0.478 -0.478 -2.773 -4.622
28 -0.1250000 -0.0033418 -0.642 -0.642 -4.563 -7.894
27 -0.1562500 -0.0053155 -0.808 -0.808 -6.837 -12.133
26 -0.1875000 -0.0078222 -0.977 -0.977 -9.640 -17.432
25 -0.2187500 -0.0109217 -1.148 -1.148 -13.034 -23.911
24 -0.2500000 -0.0146880 -1.323 -1.323 -17.091 -31.717
23 -0.2812500 -0.0192105 -1.502 -1.502 -21.901 -41.028
22 -0.3125000 -0.0245961 -1.685 -1.685 -27.570 -52.057
21 -0.3437500 -0.0309716 -1.874 -1.874 -34.223 -65.055
20 -0.3750000 -0.0384860 -2.067 -2.067 -42.010 -80.320
19 -0.4062500 -0.0473137 -2.268 -2.268 -51.104 -98.199
18 -0.4375000 -0.0576579 -2.476 -2.476 -61.707 -119.095
17 -0.4687500 -0.0697544 -2.693 -2.693 -74.054 -143.479
16 -0.5000000 -0.0838752 -2.919 -2.919 -88.415 -171.891
15 -0.5312500 -0.1003338 -3.158 -3.158 -105.102 -204.955
14 -0.5625000 -0.1194890 -3.410 -3.410 -124.473 -243.386
13 -0.5937500 -0.1417503 -3.678 -3.678 -146.935 -287.998
12 -0.6250000 -0.1675822 -3.963 -3.963 -172.949 -339.716
11 -0.6562500 -0.1975084 -4.269 -4.269 -203.038 -399.581
10 -0.6875000 -0.2321148 -4.598 -4.598 -237.784 -468.761
9 -0.7187500 -0.2720516 -4.954 -4.954 -277.835 -548.548
8 -0.7500000 -0.3180318 -5.340 -5.340 -323.899 -640.362
7 -0.7812500 -0.3708273 -5.760 -5.760 -376.745 -745.738
6 -0.8125000 -0.4312588 -6.219 -6.219 -437.190 -866.311
5 -0.8437500 -0.5001797 -6.720 -6.720 -506.082 -1003.778
4 -0.8750000 -0.5784503 -7.267 -7.267 -584.279 -1159.851
3 -0.9062500 -0.6669010 -7.866 -7.866 -672.605 -1336.184
2 -0.9375000 -0.7662811 -8.519 -8.519 -771.808 -1534.266
1 -0.9687500 -0.8771915 -9.230 -9.230 -882.484 -1755.294
0 -1.0000000 -1.0000000 -10.000 -10.000 -1005.000 -2000.000
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312910 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
27 0.0432936737565711 0.0230872677537126 0.3506756411451922 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772278 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880562 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325517 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348094 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479473 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
36 0.0503158038019031 0.0080591141492892 0.8085423793232265 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079418 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
40 0.0305543017255206 0.0021094083123694 0.9672720523544377 0.9985427438187775
41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
42 0.0109897377911119 0.0003663245930371 1.0000000000000000 1.0000000000000000
Minimum X-grid spacing, DXmin = 0.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.24434963E+01 km
Minimum Y-grid spacing, DYmin = 0.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.10642938E+01 km
Minimum Z-grid spacing, DZmin = 0.00000000E+00 m
Maximum Z-grid spacing, DZmax = 2.44706031E+02 m
Minimum barotropic Courant Number = 1.41636580E-02
Maximum barotropic Courant Number = 1.70393192E-01
Maximum Coriolis Courant Number = 1.27838438E-02
Maximum grid stiffness ratios: rx0 = 9.900498E-01 (Beckmann and Haidvogel)
rx1 = 1.521965E+01 (Haney)
Initial basin volumes: TotVolume = 1.6884675908E+15 m3
MinVolume = 2.5425025520E+07 m3
MaxVolume = 3.5401977069E+10 m3
Max/Min = 1.3924067467E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00000864)
0 0001-01-01 00:00:00.00 0.000000E+00 9.721168E+03 9.721168E+03 1.690551E+15
DEF_HIS - creating history file, Grid 01: /home/ahumada/Roms_tools/Run/SCRATCH/ocean_his.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
DEF_DIAGS - creating diagnostics file, Grid 01: /home/ahumada/Roms_tools/Run/SCRATCH/ocean_dia.nc
1 0001-01-01 00:05:00.00 1.134897E-03 9.732794E+03 9.732795E+03 1.688434E+15
(01,56,32) 2.204008E-02 6.220827E-03 0.000000E+00 1.124059E+00
2 0001-01-01 00:10:00.00 2.759096E-02 9.731637E+03 9.731665E+03 1.688210E+15
(88,56,32) 1.494777E-02 0.000000E+00 2.927881E+04 6.782240E+00
3 0001-01-01 00:15:00.00 5.606112E-02 9.730155E+03 9.730211E+03 1.687893E+15
(88,56,32) 2.743207E-02 0.000000E+00 1.056139E+05 8.911713E+00
4 0001-01-01 00:20:00.00 9.784686E-02 9.728696E+03 9.728794E+03 1.687556E+15
(88,56,32) 6.252911E-02 0.000000E+00 1.437877E+05 1.133421E+01
5 0001-01-01 00:25:00.00 1.488974E-01 9.727229E+03 9.727378E+03 1.687204E+15
(88,56,32) 7.666016E-02 0.000000E+00 1.657057E+05 1.452295E+01
6 0001-01-01 00:30:00.00 2.098312E-01 9.725725E+03 9.725934E+03 1.686839E+15
(88,56,32) 1.273641E-02 0.000000E+00 1.805207E+05 2.504551E+01
WRT_RST - wrote re-start fields (Index=1,1) in record = 0000001
Elapsed CPU time (seconds):
Thread # 19 CPU: 1.634
Thread # 20 CPU: 1.635
Thread # 16 CPU: 1.635
Thread # 5 CPU: 1.635
Thread # 7 CPU: 1.635
Thread # 9 CPU: 1.635
Thread # 13 CPU: 1.635
Thread # 1 CPU: 1.635
Thread # 10 CPU: 1.634
Thread # 22 CPU: 1.635
Thread # 21 CPU: 1.634
Thread # 15 CPU: 1.635
Thread # 3 CPU: 1.635
Thread # 23 CPU: 1.635
Thread # 0 CPU: 1.635
Thread # 18 CPU: 1.635
Thread # 6 CPU: 1.635
Thread # 4 CPU: 1.635
Thread # 11 CPU: 1.635
Thread # 8 CPU: 1.635
Thread # 14 CPU: 1.635
Thread # 2 CPU: 1.633
Thread # 17 CPU: 1.635
Thread # 12 CPU: 1.635
Total: 39.229
Nonlinear model elapsed time profile, Grid: 01
Allocation and array initialization .............. 26.134 (66.6193 %)
Ocean state initialization ....................... 2.067 ( 5.2697 %)
Reading of input data ............................ 0.000 ( 0.0000 %)
Processing of input data ......................... 0.005 ( 0.0122 %)
Processing of output time averaged data .......... 0.599 ( 1.5270 %)
Computation of vertical boundary conditions ...... 0.003 ( 0.0064 %)
Computation of global information integrals ...... 0.042 ( 0.1072 %)
Writing of output data ........................... 0.085 ( 0.2171 %)
Model 2D kernel .................................. 3.614 ( 9.2137 %)
2D/3D coupling, vertical metrics ................. 0.122 ( 0.3108 %)
Omega vertical velocity .......................... 0.064 ( 0.1640 %)
Equation of state for seawater ................... 0.130 ( 0.3311 %)
GLS vertical mixing parameterization ............. 1.224 ( 3.1214 %)
3D equations right-side terms .................... 0.287 ( 0.7310 %)
3D equations predictor step ...................... 0.742 ( 1.8919 %)
Pressure gradient ................................ 0.123 ( 0.3133 %)
Harmonic mixing of tracers, S-surfaces ........... 0.088 ( 0.2240 %)
Harmonic stress tensor, S-surfaces ............... 0.099 ( 0.2525 %)
Corrector time-step for 3D momentum .............. 0.499 ( 1.2710 %)
Corrector time-step for tracers .................. 0.379 ( 0.9672 %)
Total: 36.307 92.5510
All percentages are with respect to total time = 39.229
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_srflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Wednesday - June 14, 2017 - 5:17:35 PM
I have no idea why the problem continue... Do you think can help me with this problem?
Thanks in advance =)
Mar.Mo.
#5 Unread post by kate »
Your bathymetry is still very cliff-like and also inconsistent with this:
I would start with a finite minimum depth (20m??) and turn off wetting and drying to see if you can get that running first.
Scarlett
#6 Unread post by Scarlett »
Hi Kate:
So many thanks for your help, it was so useful, it run at 20 m deep!
I've been doing some sensitive test, and It's run at 180m maximum deep. But, What would happen if I want to considered a realistic bathymetry?How can I avoid this inconsistency, without smoothing so much the bathymetry? What do I need to considered?
I want to use 500 m deep
I'm working with:
r=0.5
n_filter_deep_topo=2
n_filter_final=2
theta_s=5
theta_b=.4
Tcline=10
N=32
Vtransform == 2
Vstretching == 4
Could you help me? Annex figure with real bathymetry
Thanks in advance.
Mar.Mo.
#7 Unread post by kate »
Did you change the boundary conditions?
The way to model a steeper bathymetry is more horizontal resolution. With bathymetry smoothing there are trade-offs between realistic geometry and good model behavior. You just have to think about what you are resolving and what you need to resolve to get the answers you want. Plus try it and see.
