Very cold water forming at boundaries
JDTilley
#1 Unread post by JDTilley »
I am still a novice at ocean modeling, and I am having an issue with cold water (< 5º in shallow water) forming at my boundaries during August in the Gulf of Mexico. I have checked and double checked my climatology, boundary, and forcing files, but can't see anything that should cause this. I have my boundary conditions sets as:
   LBC(isFsur) ==   Che     Che     Che     Che         ! free-surface
   LBC(isUbar) ==   Shc     Shc     Shc     Shc         ! 2D U-momentum
   LBC(isVbar) ==   Shc     Shc     Shc     Shc         ! 2D V-momentum
   LBC(isUvel) ==   Rad     Rad     Rad     Rad         ! 3D U-momentum
   LBC(isVvel) ==   Rad     Rad     Rad     Rad         ! 3D V-momentum
   LBC(isMtke) ==   Per     Per     Per     Per         ! mixing TKE
   LBC(isTvar) ==   RadNud  RadNud  RadNud  RadNud \       ! temperature
                    RadNud  RadNud  RadNud  RadNud         ! salinity
The problem begins right at the beginning of the model run. Does anyone know what might cause this? Any help would be greatly appreciated. I would attach some short mp4 animations, but it doesn't seem that I am allowed.
upwelling.h
(2.98 KiB) Downloaded 535 times
ocean_upwelling.in
(117.49 KiB) Downloaded 559 times
Re: Very cold water forming at boundaries
is the cold water forming at the boundaries of the model grid, or the land/sea boundary?
what are the Tnudg values at those locations? The climatology temp values may be = 0 because you have a finer grid than the clim data (just a guess).
JDTilley
#3 Unread post by JDTilley »
The cold water is forming at the ocean boundaries, not at the land/sea boundaries. I have TNUDG set to 2*0.0d0, which now that I look at it, seems to imply zero. Could that be my problem? As far as my grid goes, it is the same resolution as my climatology and boundary files, although finer than my forcing file.
JDTilley
#4 Unread post by JDTilley »
So I figured out you can upload animated gifs, so I am attaching a couple here. I am only doing short model runs at this point. It is the bottom layer that the cold is creeping in, and the surface has the opposite problem. I did try setting my nudging timescales, but the problem still remains:
! internally, [1:Ngrids].
       TNUDG == 2*10.0d0                    ! days
       ZNUDG == 0.0d0                      ! days
      M2NUDG == 0.0d0                      ! days
      M3NUDG == 10.0d0                      ! days
      OBCFAC == 1.0d0                      ! nondimensional
I'm hoping this equates to an inflow timescale of 1 day and outflow timescale of 10 days, as in Fennel et al. (2009), but I might be wrong.
#5 Unread post by kate »
Actually, you have them both set to 10 days. How are you setting the boundary values?
JDTilley
#6 Unread post by JDTilley »
My boundaries were derived from my climatology file using SeaPy. I created an animation of the cross-section of the southern boundary and everything looked reasonable. So how would I set my inflow/outflow to 1 and 10 days? Thanks.
#7 Unread post by kate »
Just set OBCFAC to ten to get what you want. It's the ratio of the outflow and inflow time scales.
JDTilley
#8 Unread post by JDTilley »
Thanks. I set my nudging coefficients as:
      M3NUDG == 0.0d0                      ! days
      OBCFAC == 10.0d0                      ! nondimensional
I also realized I didn't have
#define TCLM_NUDGING
set in my header file. However, I am still having problems. Any ideas how I can fix my problem?
JDTilley
#9 Unread post by JDTilley »
Actually, looking over my ocean.in file it seems that the TCLM_NUDGING macro (among others) is obsolete. So I will try to turn on the logical switches for LTracerCLM and LnudgeTCLM and defining ANA_NUDGCOEF in the header file.
EDIT: scratch that, now it gives an error:
 NETCDF_GET_FVAR_1D - error while inquiring ID for variable:  temp_time
                      in input file:  my_clim_ms_sound.nc
                      call from:  get_cycle.F
JDTilley
#10 Unread post by JDTilley »
Well the error above was cause by me not having set temp:time in my climatology file. So I managed to get the model running again, but I still have the same problem. Any insights would be greatly appreciated.
JDTilley
#11 Unread post by JDTilley »
I think I've figured out my problem. I think the data arrays in my boundary files are backward. At first I thought the lines at the edges of my animations were artifacts of my laziness. But that is the actually output in my _his file. It seems the script I used to create my boundary file was expecting the climatology data in the inverse order. I guess there's only one way to find out at this point. At least I learned a lot about nudging :)
