Radiation temporal resolution and overheating problem.
LeaF_7
#1 Unread post by LeaF_7 »
I am implementing a high resolution model(1km horizontally) with 40 vertical levels in the Yellowsea and Bohai sea. The model was developed by somebody else in the beginning and I am trying to optimize and validate the model. As I am kind of new to ocean modelling, so I need to seek advice on the problems I've encountered.
The model was running on a rotated grid, we have one open boundary on the east side. The initial and boundary conditions was interpolated from HYCOM analysis 1/12 degree global model. And the model was forced with the tidal forcing from TPXO7.2 on the open boundary. We use BULK_FLUXES with atmospheric forcing from ERA-interim. The solar and thermal radiation was computed from the 12 hour accumulated values, which we only use the 12 and 00 value in the heat flux for ROMS to do the interpolation. The vertical mixing scheme was Mellor-Yamada 2.5 in the model run.
By compare with the HYCOM file and our measurement, the model was overheated a lot in summer near the coast. And also the vertical temperature profile was not realistic compare to our observation.
The comparison of the surface temperature is shown in the figure below.
We also have some CTD measurement near the coast and the stations and result for station 1 and station 9 was shown below as well. the coastal water is being overheated a lot and there seem to be too much vertical mixing.
CTD stations.jpg (59.58 KiB) Viewed 4694 times
I wonder whether the low resolution of the radiations would be a reason why the coastal water is being overheated. If we use the 3-hourly forcast value there would be some improvement?
Our measurement was taken in July, and the region should be in the tidal mixing front in the Yellowsea, it seemed that the model did not perform very well in this region with the MY2.5 scheme. Are there any suggestions or experience for setup models in similar places?
Thanks very much for your patient and time for looking at this long post.
Some of the log files are attached below.
Yellow Sea
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : ftn
 Compiler command : /opt/cray/craype/2.4.2/bin/ftn
 Compiler flags   :  -O3 -free
 Input Script  :
 SVN Root URL  : https:://myroms.org/svn/src
 SVN Revision  : exported
 Local Root    : /work/users/fanlin/roms_kate_ser
 Header Dir    : /work/fanlin/roms_kate_ser/Apps/Arctic
 Header file   : yellowsea.h
 Analytical Dir: /work/fanlin/roms_kate_ser/Apps/Arctic
 Resolution, Grid 01: 0824x0785x040,  Parallel Nodes: 256,  Tiling: 016x016
     172800  ntimes            Number of timesteps for 3-D equations.
     60.000  dt                Timestep size (s) for 3-D equations.
         10  ndtfast           Number of timesteps for 2-D equations between
          1  ERstr             Starting ensemble/perturbation run number.
          1  ERend             Ending ensemble/perturbation run number.
         -1  nrrec             Number of restart records to read from disk.
          T  LcycleRST         Switch to recycle time-records in restart file.
       1440  nRST              Number of timesteps between the writing of data
                                 into restart fields.
          1  ninfo             Number of timesteps between print of information
                                 to standard output.
          T  ldefout           Switch to create a new output NetCDF file(s).
        240  nHIS              Number of timesteps between the writing fields
                                 into history file.
       1440  ndefHIS           Number of timesteps between creation of new
                                 history files.
          1  ntsAVG            Starting timestep for the accumulation of output
                                 time-averaged data.
       2880  nAVG              Number of timesteps between the writing of
       2880  ndefAVG           Number of timesteps between creation of new
                                 time-averaged file.
 1.0000E+01  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          F  LuvSponge         Turning OFF sponge on horizontal momentum.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: salt
 1.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 1.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak           Background vertical mixing coefficient (m2/s)
                                 for turbulent energy.
 5.0000E-06  Akp_bak           Background vertical mixing coefficient (m2/s)
 3.0000E-04  rdrg              Linear bottom drag coefficient (m/s).
 2.0000E-03  rdrg2             Quadratic bottom drag coefficient.
 2.0000E-02  Zob               Bottom roughness (m).
 2.0000E+00  blk_ZQ            Height (m) of surface air humidity measurement.
 2.0000E+00  blk_ZT            Height (m) of surface air temperature measurement.
 1.0000E+01  blk_ZW            Height (m) of surface winds measurement.
          1  lmd_Jwt           Jerlov water type.
          2  Vtransform        S-coordinate transformation equation.
          4  Vstretching       S-coordinate stretching function.
 7.0000E+00  theta_s           S-coordinate surface control parameter.
 2.0000E+00  theta_b           S-coordinate bottom  control parameter.
     10.000  Tcline            S-coordinate surface/bottom layer width (m) used
   1025.000  rho0              Mean density (kg/m3) for Boussinesq approximation.
  42124.000  dstart            Time-stamp assigned to model initialization (days).
  41273.000  tide_start        Reference time origin for tidal forcing (days).
19000101.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 3.6000E+02  Tnudg(01)         Nudging/relaxation time scale (days)
 3.6000E+02  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 3.6000E+02  Znudg             Nudging/relaxation time scale (days)
 3.6000E+02  M2nudg            Nudging/relaxation time scale (days)
 3.6000E+02  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 1.2000E+02  obcfac            Factor between passive and active
 zeta                     1   Closed       Closed       Chapman Imp  Closed
 ubar                     1   Closed       Closed       Shchepetkin  Closed
 vbar                     1   Closed       Closed       Shchepetkin  Closed
 u                        1   Closed       Closed       Rad + Nud    Closed
 v                        1   Closed       Closed       Rad + Nud    Closed
 temp                     1   Closed       Closed       Rad + Nud    Closed
 salt                     1   Closed       Closed       Rad + Nud    Closed
 tke                      1   Closed       Closed       Closed       Closed
 uice                     1   Closed       Closed       Gradient     Closed
 vice                     1   Closed       Closed       Gradient     Closed
 aice                     1   Closed       Closed       Mixed        Closed
 hice                     1   Closed       Closed       Mixed        Closed
 tisrf                    1   Closed       Closed       Mixed        Closed
 snow_thick               1   Closed       Closed       Mixed        Closed
 sfwat                    1   Closed       Closed       Mixed        Closed
 YELLOWSEA           Yellow Sea
 ADD_FSOBC           Adding tidal elevation to processed OBC data.
 ADD_M2OBC           Adding tidal currents to processed OBC data.
 ALBEDO_CURVE        Shortwave radiation adjusted by albedo curve.
 ANA_NUDGCOEF        Analytical spatially varying nudging time-scales.
 BULK_FLUXES         Surface bulk fluxes parameterization.
 CORE_FORCING        Humidity from CORE forcing files.
 EMINUSP             Compute Salt Flux using E-P.
 ICE_ADVECT          Advection of ice tracers.
 ICE_ALB_EC92        Ebert and Curry albedo formula.
 ICE_BULK_FLUXES     Ice bulk fluxes from the atmosphere.
 ICE_EVP             Elastic-viscous-plastic ice rheology.
 ICE_MK              Mellor-Kantha ice thermodynamics.
 ICE_MODEL           Include sea ice model.
 ICE_MOMENTUM        Compute ice momentum equations.
 ICE_SMOLAR          Advect ice tracers with MPDATA scheme.
 ICE_THERMO          Include ice thermodynamics.
 LIMIT_BSTRESS       Limit bottom stress to maintain bottom velocity direction.
 LONGWAVE_OUT        Compute outgoing longwave radiation internally.
 MY25_MIXING         Mellor/Yamada Level-2.5 mixing closure.
 NO_SCORRECTION_ICE  Not including SCORRECTION under the ice.
 NO_WRITE_GRID       Not Writing grid arrays into NetCDF ouput files.
 K_GSCHEME           Third-order upstream advection of TKE fields.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 RAMP_TIDES          Ramping tidal forcing for one day.
 RST_SINGLE          Single precision fields in restart NetCDF file.
 SOLAR_SOURCE        Solar Radiation Source Term.
 SSH_TIDES           Add tidal elevation to SSH climatology.
 TS_U3HADVECTION     Third-order upstream horizontal advection of tracers.
 UV_TIDES            Add tidal currents to 2D momentum climatologies.
 UV_SMAGORINSKY      Smagorinksy-like time-dependent viscosity coefficients.
 VISC_3DCOEF         Horizontal, time-dependent 3D viscosity coefficient.
Re: Radiation temporal resolution and overheating problem.
#2 Unread post by wilkin »
Be careful working with "accumulated" values in that data set. They are an integral over time. Plot some time series and make sure you don't have a sawtooth pattern between the 0000 and 1200 values.
Also, if you use solar radiation sampled only two hours per day you are going to alias the diurnal cycle. You might be better off getting the best daily average you can, and then #define DIURNAL_SRFLUX to introduce the local solar angle into the time variation.
zhaoyun
#3 Unread post by zhaoyun »
Try to change vertical mixing scheme from MY-2.5 to GLS Mixing, then, the abnormal high SST in the shallow region may disappear. Good luck.
