very diferent velocitities using GLS,MY25 or LMD
flcastej
Location: Technical University of Cartagena,Murcia, Spain
#1 Unread post by flcastej »
I am running a nested simulation. It have 3 child grids for 3 channels with a resolution about 10 meters. The channels are quite narrow (50/70 m width) and shallow (5 meters). I have used different vertical mixing schemes: MY25, GLS and LMD. If I use GLS or LMD my model is very stable but I get low current velocities compared to the one measured by the ADCP deployed in the area but if I use MY25 my velocities are more realistic but my model get unstable. I have been doing different test but I always get the same results (MY25 more realistic but unstable). I will really appreciated any help or suggestion.
Thanks a lot.
My configuration used are :
#define STATIONS
#undef FLOATS
#undef DIAGNOSTICS_UV
#undef ONE_WAY
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#define MY25_MIXING
# ifdef MY25_MIXING
# undef N2S2_HORAVG
# undef UV_LOGDRAG
# define K_C2ADVECTION
# undef K_C4ADVECTION
#undef GLS_MIXING
#if defined GLS_MIXING
# define CRAIG_BANNER
# define CHARNOK
# undef ZOS_HSIG
# undef TKE_WAVEDISS
#undef LMD_MIXING
#ifdef LMD_MIXING
# define LMD_CONVEC
#define LMD_DDMIX
# define LMD_SKPP
# define LMD_BKPP
# define LMD_NONLOCAL
# define LMD_RIMIX
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
#define BULK_FLUXES
#ifdef BULK_FLUXES
# define CLOUDS
# define ALBEDO
# define DIURNAL_SRFLUX
# define LONGWAVE
# define ANA_RAIN
# undef ANA_PAIR
# define ANA_CLOUD
# define ANA_SST
# undef ANA_TAIR
# undef ANA_HUMID
# define EMINUSP
# undef ANA_DRAG
# define UV_DRAG_GRID
Initial file:
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
LcycleTLM == F
NTLM == 72
NDEFTLM == 0
LcycleADJ == F
NADJ == 72
NDEFADJ == 0
MaxIterGST = 500 ! maximun number of iterations
Ritz_tol = 1.0d-15
TNU2 == 2*0.0d0 2*0.0d0 2*0.0d0 2*0.0d0 ! m2/s
TNU4 == 2*0.0d0 2*0.0d0 2*0.0d0 2*0.0d0 ! m4/s
VISC2 == 4*0.001d0 ! m2/s
VISC4 == 4*0.0d0 ! m4/s
AKT_BAK == 4*1.0d-6 4*5.0d-6 ! m2/s
AKV_BAK == 4*1.0d-2 4*1.0d-2 ! m2/s
AKK_BAK == 4*5.0d-6 ! m2/s
AKP_BAK == 4*5.0d-6 ! m2/s
TKENU2 == 4*0.0d0 ! m2/s
TKENU4 == 4*0.0d0 ! m4/s
GLS_P == 4*3.0d0 ! K-epsilon
GLS_M == 4*1.5d0
GLS_N == 4*-1.0d0
GLS_Kmin == 4*7.6d-6
GLS_Pmin == 4*1.0d-12
GLS_CMU0 == 4*0.5477d0
GLS_C1 == 4*1.44d0
GLS_C2 == 4*1.92d0
GLS_C3M == 4*-0.4d0
GLS_C3P == 4*1.0d0
GLS_SIGK == 4*1.0d0
GLS_SIGP == 4*1.30d0
RDRG == 4*3.0d-04 ! m/s
RDRG2 == 4*0.003d0 ! nondimensional
Zob == 4*0.0d0 ! m
Zos == 4*00.0d0 ! m
BLK_ZQ == 4*10.0d0 ! air humidity
BLK_ZT == 4*10.0d0 ! air temperature
BLK_ZW == 4*5.0d0 ! winds
DCRIT == 4*0.10d0 ! m
WTYPE == 4*1
LEVSFRC == 4*15
LEVBFRC == 4*1
Vtransform == 4*2 ! transformation equation
Vstretching == 4*3 ! stretching function
THETA_S == 4*7.0d0 ! surface stretching parameter
THETA_B == 4*0.8d0 ! bottom stretching parameter
TCLINE == 4*4.0d0 ! critical depth (m)
RHO0 = 1026.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
DSTART = 15622 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 19680523.00 ! yyyymmdd.dd
! TIME_REF = 00010101.00 ! yyyymmdd.dd
! TNUDG == 4*0.0d0 ! days
! ZNUDG == 4*0.01d0 ! days
! M2NUDG == 4*0.01d0 ! days
! M3NUDG == 4*0.01d0 ! days
! OBCFAC == 1.0d0 ! nondimensional
LBC(isFsur) == Clo Gra RadNud RadNud \ ! free-surface, Grid 1
Nes Nes Nes Nes \ ! free-surface, Grid 3
Nes Nes Nes Nes ! free-surface, Grid 4
LBC(isUbar) == Clo FLa Fla Fla \ ! 2D U-momentum, Grid 1
Nes Nes Nes Nes \ ! 2D U-momentum, Grid 3
Nes Nes Nes Nes ! 2D U-momentum, Grid 4
LBC(isVbar) == Clo FLa Fla Fla \ ! 2D V-momentum, Grid 1
Nes Nes Nes Nes \ ! 2D V-momentum, Grid 3
Nes Nes Nes Nes ! 2D V-momentum, Grid 4
LBC(isUvel) == Clo Rad Rad Rad \ ! 3D U-momentum, Grid 1
Nes Nes Nes Nes \ ! 3D U-momentum, Grid 3
Nes Nes Nes Nes ! 3D U-momentum, Grid 4
LBC(isVvel) == Clo Rad Rad Rad \ ! 3D V-momentum, Grid 1
Nes Nes Nes Nes \ ! 3D V-momentum, Grid 3
Nes Nes Nes Nes ! 3D V-momentum, Grid 4
LBC(isMtke) == Clo Rad Rad Rad \ ! mixing TKE, Grid 1
Nes Nes Nes Nes \ ! mixing TKE, Grid 3
Nes Nes Nes Nes ! mixing TKE, Grid 4
LBC(isTvar) == Clo Gra Gra Gra \ ! temperature, Grid 1
Clo Gra Gra Gra \ ! salinity, Grid 1
Nes Nes Nes Nes \ ! salinity, Grid 3
Nes Nes Nes Nes \ ! temperature, Grid 4
Nes Nes Nes Nes ! salinity, Grid 4
R0 == 4*1026.0d0 ! kg/m3
T0 == 4*17.0d0 ! Celsius
S0 == 4*37.0d0 ! nondimensional
TCOEF == 4*1.7d-4 ! 1/Celsius
SCOEF == 4*7.6d-4
GAMMA2 == 4*1.0d0
DstrS == 0.0d0 ! starting day
DendS == 0.0d0
Re: very diferent velocitities using GLS,MY25 or LMD
When it goes unstable, have you tried changing the timestep to something shorter? What is the nature of the instability?
flcastej
#3 Unread post by flcastej »
Dear Kate,
Thanks a lot for your answer and your help. The model get unstable after 4 hours, the wind blowing at this time is not very strong (5 m/s) and the sea level variations quite small. I have tried to use smaller time steps, different values for RDRG2 and several sigma layer distributions but I always get the same results. If I use other vertical schemes (GLS or LMD) my model is stable but the effect of the wind is very small and I don’t get realistic values for the current. I am only able to get them if I use the MY25 scheme. Below you will find two plots: the bathymetry and the u-component where the instability can be seen clearly.
Bathymetry
Bathymetry
lanerolle
#4 Unread post by lanerolle »
Your model bathymetry in general is quite shallow and it blows up in a region where the water depth < 2m. Does the model have tides? If so what is the tidal range? Have you tried switching on the wetting-drying in ROMS?
flcastej
#5 Unread post by flcastej »
Dear Lyon Lanerolle,
Thanks a lot for your answer I am working in a quite shallow area. I have tides but the tidal range is very small (max. 20 cm) so the area never get dry.
Regards,
-Francisco
lanerolle
#6 Unread post by lanerolle »
So the domain of computation is deeper than 20 cm (0.2 m) everywhere and anything shallower is under the permanent dry mask (mask_rho, mask_u, mask_v)? If possible, could you please show us a plot of your permanent dry mask (say mask_rho)?
flcastej
#7 Unread post by flcastej »
The white area in the pictures showed in my post correspond to the mask_rho.
Yes, the minimum depth in my domain is 0.5 meters to ensure that I am not going to have any dry area.
My problem come using the MY25 vertical scheme, if I use other scheme my model is stable but I get low velocities.
Thanks a lot for you help.
lanerolle
#8 Unread post by lanerolle »
I apply my GLS and MY2.5 schemes in ROMS as follows and I find that the GLS & MY2.5 give similar results with the exception that the former provides better stratification and is usually ~40% more expensive computationally.
#if defined MY25_MIXING || defined GLS_MIXING
As you can see, I always use the N2S2_HORAVG option but I do not specify an advection scheme choice for the mixing scheme - I let ROMS pick the default.
flcastej
#9 Unread post by flcastej »
Thanks a lot for your suggestion, I will try to do so.
#10 Unread post by kate »
You do appear to need some more lateral smoothing. Another option would be to increase:
at least for the coarser grids. You don't show us where and how fine each of your four grids are.
flcastej
#11 Unread post by flcastej »
Dear Kate,
Thanks a lot for your help. Attached you will find a plot of the coarser grid and the three nested grids. Two of the nested grids are refined to a scale of 3 and another one to 4. In the plot is showed this values. I have changed the values of VISC2 increasing the value for the coarser grid and re-launch the model.
Dear Lyon,
I have launched the model with your configuration but I am getting the same problem.
lanerolle
#12 Unread post by lanerolle »
If MY2.5 still blows up and GLS does not and gives diminished currents then the only thing I can conclude is that the bottom stress is coming into the two turbulent viscosity formulations differently - see my_corstep.F for example where (bustr, bvstr) and applied at the bottom most layer as a boundary condition. So it appears that the bottom stress which comes into the MY2.5 is less and causes the model to become unstable whereas what comes into the GLS scheme is at a lower level and allows the model to be numerically stable.
Have you tried both the quadratic (e.g. Cd=0.005) and logarithmic (e.g. Zob=0.005) bottom stress formulations? Do they both cause MY2.5 to blow-up?
flcastej
#13 Unread post by flcastej »
Dear Lyon,
Thanks a lot for your advice. I have launched the model following Kate suggestion and changing the value of VISC2 and it seem that it´s working. Once it finished I will follow your suggestion and test to run the model with different bottom stress formulation.
flcastej
#14 Unread post by flcastej »
Dear Kate and Lyon,
Thanks a lot for your help. Finally it seem that I have been able to get rid off the instability trying different values for VISC2 and Zob. Now I have another problem but I think that I am going to be able to handle it by my own.
Thanks !! :D
