From 1st to 9th step, the model seems to run without any problem, but on the 10th step, the potential energy witnessed a burst to NaN, but there is no hint what went wrong before the last step (shown in the logs).
I do have WET_DRY enabled in the macros (shown below).
The zeta is obviously too big in the negative direction (-199 m) at certain continental boundaries, but I don't know what has caused it.
The macros and the log is shown below.
Thanks for any suggestions of what might be going wrong with it
Macros:
#define ROMS_MODEL
#undef SWAN_MODEL
#define WRF_MODEL
#define MCT_LIB
# undef MCT_INTERP_WV2AT
# undef MCT_INTERP_OC2AT
# undef MCT_INTERP_OC2WV
#define PERFECT_RESTART
/* Model configuration */
#define SPLINES
/* momentum equations */
/* tracers equations */
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#define SOLAR_SOURCE
/* pressure gradient algorithm */
#define ATM_PRESS /* use real SLP in pressure gradient equations */
/* Forcing */
# undef ANA_PSOURCE
# undef ATM2OCN_FLUXES /* surface fluxes from ATM model */
#define ANA_SSFLUX
#define EMINUSP /* use evap & rain from ATM model */
# undef CORE_FORCING
#define BULK_FLUXES
# undef CCSM_FLUXES
/* wave roughness formulation
* ** if only in MYJSFC and MYNN now
#undef COARE_TAYLOR_YELLAND
#undef DEEPWATER_WAVES
/* horizontal mixing */
#define VISC_3DCOEF
#define VISC_GRID
#define MIX_GEO_TS
#define DIFF_GRID
/* Turbulence closure */
#define GLS_MIXING
/* Sea ice */
# undef ICE_MODEL
#define CICE_MODEL
/* bottom boundary layer closure */
# undef SSW_BBL
#define RADIATION_2D
/* Wave effort on currents and shallow water */
#define WET_DRY
# undef NEARSHORE_MELLOR /* Nearshore wave driven (radiation stress) momentum terms */
/*** SUB-CONFIGURATIONS ***/
/* Forcing */
#if defined BULK_FLUXES || defined CCSM_FLUXES
# define SHORTWAVE
# define LONGWAVE_OUT
# undef LONGWAVE
# undef LONGWAVE_ICE
# undef DIURNAL_SRFLUX
# define SOLAR_SOURCE
# define EMINUSP
# undef ANA_SRFLUX
# define ALBEDO
# define ALBEDO_CURVE /* for water */
# undef ICE_ALB_EC92 /* for ice */
# undef ALBEDO_CSIM /* for ice */
# undef ALBEDO_FILE /* for both */
# if defined ICE_MODEL || defined CICE_MODEL
# define ALBEDO_ICE
#ifdef GLS_MIXING
# define AKLIMIT
# define CHARNOK
# define CRAIG_BANNER
# undef ZOS_HSIG
# undef TKE_WAVEDISS
/* Sea ice */
#ifdef ICE_MODEL
# undef OUTFLOW_MASK
# undef FASTICE_CLIMATOLOGY
# define ICE_THERMO
# define ICE_MK
# undef ICE_SMOOTH
# define ICE_MOMENTUM
# define ICE_MOM_BULK
# define ICE_EVP
# define ICE_ADVECT
# define ICE_SMOLAR
# define ICE_UPWIND
# define ICE_BULK_FLUXES
# undef ANA_AIOBC
# undef ANA_HIOBC
# undef ANA_HSNOBC
#ifdef CICE_MODEL
#ifdef SSW_BBL
# define SSW_CALC_ZNOT
# define SSW_LOGINT
# define SSW_CALC_UB
# define SSW_ZORIP
(Part of) log file:
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00004320)
GET_NGFLD - free-surface western boundary condition, t = 1 00:00:00
(Rec=0000001, Index=1, File: NWP_bry.nc)
(Tmin= 1.0000 Tmax= 5.0000)
(Min = -2.71132774E-01 Max = 1.76061660E-01)
GET_NGFLD - free-surface southern boundary condition, t = 1 00:00:00
(Min = -5.81257143E-01 Max = -1.21927726E-01)
GET_NGFLD - free-surface northern boundary condition, t = 1 00:00:00
(Min = -1.54453252E-01 Max = 2.08928368E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 1 00:00:00
(Min = -3.91126597E-02 Max = 6.28961389E-02)
GET_NGFLD - 2D v-momentum western boundary condition, t = 1 00:00:00
(Min = -8.56973438E-02 Max = 6.85699264E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -2.82746953E-02 Max = 5.11969330E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -4.25098229E-02 Max = 6.45392620E-02)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 1 00:00:00
(Min = -2.06448997E-02 Max = 6.87771481E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 1 00:00:00
(Min = -1.81647883E-02 Max = 6.91692063E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 1 00:00:00
(Min = -2.67139584E-01 Max = 3.26596573E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 1 00:00:00
(Min = -1.46086866E-01 Max = 3.99452947E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 1 00:00:00
(Min = -2.66644593E-01 Max = 5.03047983E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 1 00:00:00
(Min = -3.61565101E-01 Max = 3.73100026E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 1 00:00:00
(Min = -3.14866441E-01 Max = 3.23681000E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 1 00:00:00
(Min = -2.09041481E-01 Max = 2.32470000E-01)
GET_NGFLD - temperature western boundary condition, t = 1 00:00:00
(Min = 7.46083388E-01 Max = 2.83218757E+01)
GET_NGFLD - salinity western boundary condition, t = 1 00:00:00
(Min = 2.72821343E+01 Max = 3.46800718E+01)
GET_NGFLD - temperature southern boundary condition, t = 1 00:00:00
(Min = 6.17114711E-01 Max = 2.67651677E+01)
GET_NGFLD - salinity southern boundary condition, t = 1 00:00:00
(Min = 2.98698429E+01 Max = 3.62966581E+01)
GET_NGFLD - temperature northern boundary condition, t = 1 00:00:00
(Min = -1.19242220E+00 Max = 2.24956871E+01)
GET_NGFLD - salinity northern boundary condition, t = 1 00:00:00
(Min = 3.00333259E+01 Max = 3.46910734E+01)
0 0 00:00:00 2.696506E-04 1.731806E+04 1.731806E+04 4.967722E+16
(163,023,40) 7.315241E-02 4.513867E-02 0.000000E+00 6.757293E-01
DEF_HIS - creating history file, Grid 01: ocean_joe_tc_coarse_his.nc
1 0 01:00:00 6.220933E-04 1.747035E+04 1.747035E+04 4.924581E+16
(208,036,40) 3.733053E-01 5.822740E-01 5.579508E-04 5.333663E+00
## ROMS grid 1 recv data from WRF grid 1
## ROMS grid 1 sent data to WRF grid 1
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000002
2 0 02:00:00 9.446803E-04 1.747077E+04 1.747077E+04 4.924603E+16
(161,156,40) 2.163557E-03 2.057769E-02 1.055207E+01 2.589992E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000003
3 0 03:00:00 1.177476E-03 1.747094E+04 1.747094E+04 4.924619E+16
(054,154,40) 3.322705E-03 1.532365E-02 1.372957E+01 2.567867E+00
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000004
4 0 04:00:00 1.374695E-03 1.747115E+04 1.747115E+04 4.924631E+16
(122,122,40) 1.712617E-02 8.448593E-03 1.790937E+01 2.451760E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000005
5 0 05:00:00 1.547551E-03 1.747128E+04 1.747128E+04 4.924643E+16
(166,134,40) 2.010454E-02 8.998871E-03 1.833376E+01 1.946859E+00
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000006
6 0 06:00:00 1.645237E-03 1.747125E+04 1.747125E+04 4.924651E+16
(107,127,40) 1.132731E-02 2.080250E-02 1.839183E+01 1.817681E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000007
7 0 07:00:00 1.669672E-03 1.747117E+04 1.747117E+04 4.924653E+16
(166,134,40) 6.423948E-04 1.342048E-02 2.266929E+01 1.828100E+00
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000008
8 0 08:00:00 1.684789E-03 1.747108E+04 1.747108E+04 4.924654E+16
(107,127,40) 6.173031E-03 2.756786E-02 1.689588E+01 2.685525E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000009
9 0 09:00:00 1.688831E-03 1.747094E+04 1.747094E+04 4.924664E+16
(107,127,40) 2.407506E-03 1.043648E-02 1.595644E+01 3.744220E+00
WRT_HIS - wrote history fields (Index=2,2) into time record = 0000010
10 0 10:00:00 1.681953E-03 NaN NaN 4.924684E+16
(150,201,40) 1.269356E-01 1.950973E-02 1.188577E+01 3.961068E+00
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
Elapsed CPU time (seconds):
Node # 0 CPU: 302.568
number of time records written in HISTORY file = 00000010
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_stflux.h
