Can't run my IS4D-Var case Gnorm = NaN
Discussion about tangent linear and adjoint models, variational data assimilation, and other related issues.
Arvin_Yin
#1 Unread post by Arvin_Yin »
Hi, everyone!
When I run my IS4D-Var model, it blows up at the beginning of the first inner loop. The log file shows:
<< Descent Algorithm >
(001,000): Initial gradient norm, Gnorm = NaN
< 4D Variational Data Assimilation, Outer = 001, Inner = 001 >
STEP KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME
0 NaN NaN NaN 1.287561E+16
The initial gradient norm is NaN and I think this is why the model blows up. But I don’t know why the model outputs initial gradient norms of NaN.
My ocean.in and s4dvar.in file are like those in WC13 case. At first I ran the forward model for one year. Then I computed the standard deviations using this forward model output data and wrote them into the initial STD files(use the ROMS matlab script d_std.m). The normalization coefficients were computed using the exact method. The observation data are AVISO SLA data and NOAA OISST data. I added the mean sea surface, which are calculated from the one year forward model, to the AVISO SLA data, then wrote them into the observation file(use ROMS matlab script d_ssh_obs.m, d_sst_obs.m and obs_merge.m).
Also, I noticed that, when the model only includes the SLA data or the SST data in the observation file, the model rejected most of them, but if the model includes both the SLA data and the SST data, all the observation data can be accepted by the model.
I attached my log file for your convenience.
Thank you for your help.
ocean_nscs_i4dvar.log
(644.04 KiB) Downloaded 1023 times
susonic
Re: Can't run my IS4D-Var case Gnorm = NaN
#2 Unread post by susonic »
Does your domain include equator?
If it's ok for you, I want to see your model domain.
-JH
Joonho Lee
Arvin_Yin
#3 Unread post by Arvin_Yin »
susonic wrote:Hi,
-JH
Hi, JH
Thanks.
My domain doesn't include equator.It's 16N - 24N, 105E - 132E, in north South China Sea.
And I have another question while I compile with SANITY_CHECK, the error goes:
cd /mnt/volume04/yinpeng/Projects/nSCS/Build; /usr/local/mpich2-1.2.1p1/bin/mpif90 -c -frepack-arrays -O3 -ffast-math ocean_control.f90
ocean_control.f90:394.58:
CALL mp_collect (ng, iTLM, 4, IniVal, val(1,ng))
1
Error: There is no specific subroutine for the generic 'mp_collect' at (1)
make: *** [/mnt/volume04/yinpeng/Projects/nSCS/Build/ocean_control.o] Error 1
In fact I'm not quite clear ahout what deos SANITY_CHECK do.But have you ever met this error?
Thank you again for your help.
susonic
#4 Unread post by susonic »
I've never done SANITY_CHECK before. But I compiled with SANITY_CHECK and faced with same error message as you noted above(with gfortran).
Maybe code developer can helped this out to solve the problem.
I saw the log file you attached and found TLM increments are zero even though ROMS continuing the intergration. I was wondering why this value is appearing.
Would you give same value to nHIS and nOBC, nSFF(say nHIS=240, nOBC=240, NSFF=240) and run the model again?
Joonho Lee
susonic
#5 Unread post by susonic »
For above situation, try to use super observation file instead.
Joonho Lee
Arvin_Yin
#6 Unread post by Arvin_Yin »
Many thanks.
Yes, it works!
I tried NHIS=NOBC=NSFF=240(120), but the results remained the same.
susonic
#7 Unread post by susonic »
I checked out the log file you attached several times but it is difficult to diagnose the causes of NaN value.
By the way, your Haney(rfactor) and Beckman & Haidvogel number is quiet high compare with known value(say, rfactor < 0.2) which means you did not smooth the bottom topography much.
Joonho Lee
wavewatch
#8 Unread post by wavewatch »
I wonder if you have solved this problem?
Now I have the similar error like you in my IS4D-Var run, my initial gradient norm (Gnorm) is NaN.
<<<< Descent Algorithm >>>>
TLM: GET_STATE - Read state initial conditions, t = 1 00:00:00
(Grid 01, File: wc13_itl.nc, Rec=0001, Index=1)
- free-surface
(Min = NaN Max = NaN )
- free-surface, open boundaries
- vertically integrated u-momentum component, open boundaries
- vertically integrated v-momentum component, open boundaries
- surface u-momentum stress, adjusted tl_ustr
0 1 00:00:00 NaN NaN NaN 1.159856E+16
Could you tell me more about this error and how you solved it?
Thank you very much.
ckerry
#9 Unread post by ckerry »
I'm also wondering if you solved this problem and I am having the same problem.
TLM: GET_STATE - Read state initial conditions, t = 4367 00:00:00
(File: ocean_itl.nc, Rec=0001, Index=1)
- free-surface
- surface v-momentum stress, adjusted tl_vstr
- u-momentum component
- u-momentum component, open boundaries
- v-momentum component
- v-momentum component, open boundaries
- potential temperature
- salinity
- potential temperature, open boundaries
- salinity, open boundaries
- surface net heat flux, adjusted tl_tflux
- surface net salt flux, (E-P)*SALT, adjusted tl_tflux
0 4367 00:00:00 NaN NaN NaN 1.188685E+14
