i have a question
kobl1201
i have a question
#1 Unread post by kobl1201 »
hello
When i run roms model, i have some errors.
the log file show that like this.
'current model time exceeds ending value for variable : zeta west'
Even if, i check time of zeta west, i could't understand why this error represented.
Re: i have a question
Can you print out the times for zeta_west? Are they in order of increasing time?
kobl1201
#3 Unread post by kobl1201 »
the dimension of this variable, zeta west,is (zeta_time, erho).
And i run the model for 1 year(366 days)
This picture shows that zeta time.
and i use nudging scheme for 3D velocity. This time interval is 1 day.
#4 Unread post by wilkin »
Your times for zeta-_est are between 0.5 and 365.5, but the model time is 0. So model time is not bracketed by the forcing time, hence ROMS won't start.
Either:
(1) Change your initial conditions time to greater than 0.5 days << BEST
(2) Just change the first time in the boundary file to 0 days (instead of 0.5) - this makes the first half day of boundary data not quite right
(3) Add a new time record to the front of the forcing file (e.g. for t = -0.5 days) if you have those data. (If you just copied the data for day 0.5 that would be hold the values constant from t=0 to t=0.5 and then the correct linear interpolation would begin).
m.hadfield
Or if the data are supposed to repeat year on year, you could add a cycle_length attribute to the zeta_west variable.
kobl1201
#6 Unread post by kobl1201 »
When i change initial time like t = 0, will i change the other kind of times?? For example, ocean time, temp time and salt time and so on.
#7 Unread post by wilkin »
The time in the initial conditions file does not have to match the first time in all the boundary conditions, forcing, and other input files.
ROMS is clever enough to take the initial conditions time and figure out which records to read and interpolate from all the others. If it were any other way we would be having to change the forcing files every time we restart run.
So my suggestion ...
is by far the easiest solution for you to get started.
lindandan
#8 Unread post by lindandan »
wilkin wrote:The time in the initial conditions file does not have to match the first time in all the boundary conditions, forcing, and other input files.
I have a similar question.
NLM: GET_STATE - Read state initial conditions,             t =     0 00:00:00
                   (Grid 01, File: ssc12_ini.nc, Rec=0001, Index=1)
                - free-surface
                   (Min = -1.48966948E-01 Max =  3.61947780E-01)
                   (Min = -6.00885394E-01 Max =  4.97978379E-01)
                   (Min = -9.50324788E-01 Max =  3.26700159E-01)
                - u-momentum component
                   (Min = -1.05035297E+00 Max =  8.54699225E-01)
                - v-momentum component
                   (Min = -1.33850665E+00 Max =  1.10605943E+00)
                - potential temperature
                   (Min =  1.14820875E+00 Max =  2.94470631E+01)
                - salinity
                   (Min =  3.24921652E+01 Max =  3.49794372E+01)
    GET_NGFLD   - tidal period
                   (Min =  4.30819210E+04 Max =  9.67262421E+04)
    GET_2DFLD   - tidal elevation amplitude
                   (Min =  1.05619027E-04 Max =  2.04697708E+01)
    GET_2DFLD   - tidal elevation phase angle
                   (Min =  8.09572363E-06 Max =  6.28317033E+00)
    GET_2DFLD   - tidal current inclination angle
                   (Min =  2.46404577E-06 Max =  6.28318082E+00)
    GET_2DFLD   - tidal current phase angle
                   (Min =  1.82233990E-06 Max =  6.28318114E+00)
    GET_2DFLD   - maximum tidal current, ellipse major axis
                   (Min =  3.85134858E-06 Max =  1.81928232E+01)
    GET_2DFLD   - minimum tidal current, ellipse minor axis
                   (Min = -1.04224347E+00 Max =  1.16227576E+00)
forrtl: severe (408): fort: (3): Subscript #1 of the array TVAL has value 0 which is less than the lower bound of 1
Image              PC                Routine            Line        Source
oceanG             0000000001D7107D  Unknown               Unknown  Unknown
oceanG             0000000001D6FB85  Unknown               Unknown  Unknown
oceanG             0000000001D16409  Unknown               Unknown  Unknown
oceanG             0000000001CD4A8F  Unknown               Unknown  Unknown
oceanG             0000000001CD4E92  Unknown               Unknown  Unknown
oceanG             00000000018CBDBF  get_cycle_                224  get_cycle.f90
oceanG             000000000163732F  inquire_                  277  inquire.f90
oceanG             00000000015CA9C0  get_2dfld_                102  get_2dfld.f90
oceanG             00000000012C728B  get_data_                 100  get_data.f90
oceanG             00000000006930BF  initial_                  282  initial.f90
oceanG             00000000004131ED  ocean_control_mod         130  ocean_control.f90
oceanG             000000000041235F  MAIN__                     95  master.f90
oceanG             00000000004121FC  Unknown               Unknown  Unknown
libc.so.6          00002AE0D133CCDD  Unknown               Unknown  Unknown
oceanG             00000000004120F9  Unknown               Unknown  Unknown
I use the BULK_FLUX. and the line 100 of get_data.f90 want to get wind component.I also remove the cycle attribute.But canot run.
wind_time = -2, -1.75, -1.5, -1.25, -1, -0.75, -0.5, -0.25, 0, 0.25, 0.5,
    0.75, 1, 1.25, 1.5, 1.75, 2, 2.25, 2.5, 2.75, 3, 3.25, 3.5, 3.75, 4,
    4.25, 4.5, 4.75, 5, 5.25, 5.5, 5.75, 6, 6.25, 6.5, 6.75, 7, 7.25, 7.5,
    7.75, 8, 8.25, 8.5, 8.75, 9, 9.25, 9.5, 9.75, 10, 10.25, 10.5, 10.75, 11,
    11.25, 11.5, 11.75, 12, 12.25, 12.5, 12.75, 13, 13.25, 13.5, 13.75, 14,
    14.25, 14.5, 14.75, 15, 15.25, 15.5, 15.75, 16, 16.25, 16.5, 16.75, 17,
    17.25, 17.5, 17.75, 18, 18.25, 18.5, 18.75, 19, 19.25, 19.5, 19.75, 20,
    20.25, 20.5, 20.75, 21, 21.25, 21.5, 21.75, 22, 22.25, 22.5, 22.75, 23,
    23.25, 23.5, 23.75, 24, 24.25, 24.5, 24.75, 25, 25.25, 25.5, 25.75, 26,
    26.25, 26.5, 26.75, 27, 27.25, 27.5, 27.75, 28, 28.25, 28.5, 28.75, 29,
    29.25, 29.5, 29.75, 30, 30.25, 30.5, 30.75, 31, 31.25, 31.5, 31.75, 32,
    32.25, 32.5, 32.75 ;
bry_time = -16, 14, 44 ;
ocean_time = 0 ;
and I have no idea , could you help me ?
#9 Unread post by kate »
Can you shift your time origin (DSTART) forward say 30 days so that you have no negative times?
#10 Unread post by wilkin »
You say you removed the cycle_length attribute:
But the traceback indicates that inquire found the attribute and therefore called get_cycle.
So you need to sort out what's wrong with your netcdf file. Perhaps browse the logic in get_data and figure out which variable ROMS was reading when it threw the error.
dooruk
#11 Unread post by dooruk »
I have a similar issue with time steps so decided to ask my question in this topic.
I am trying to read in atm. forcing files for my 2014 run. I have the forcing fields for the whole year and I am only interested in 3 months starting May 23rd (12PM). Hence I changed times in the forcing files as days relative to May 23rd (in the form of ...-0.25,0,0.25...). My issue is before my simulation starts, ROMS reads my forcing files twice (you can see it below) which causes a time shift in the forcing files (3 and 6 hours to be specific). I tried using both TIME_REF=0 and TIME_REF=20140523.5d and same thing happened.
I could cheat and subtract 1 more time step but it is an annoying issue which has to have a simpler solution.
I tried different ROMS versions and I encountered this problem with OBC as well. What am I missing?
                   (Grid 01, File: ini_rsrt.nc, Rec=0001, Index=1)
                - free-surface
                   (Min =  0.00000000E+00 Max =  4.74517411E-01)
                   (Min = -4.75181724E-01 Max =  1.28795831E-01)
                   (Min = -3.13548350E-01 Max =  3.95202656E-01)
                   (Min = -8.25463918E-01 Max =  3.82607522E-01)
                   (Min = -7.25966545E-01 Max =  6.09747377E-01)
                   (Min =  0.00000000E+00 Max =  1.85641359E+01)
                - salinity
                   (Min =  0.00000000E+00 Max =  3.44186987E+01)
                   (Min =  2.19720214E+04 Max =  2.38071336E+06)
                   (Min =  0.00000000E+00 Max =  9.73092002E-01)
                   (Min =  0.00000000E+00 Max =  5.38337522E+00)
                   (Min =  0.00000000E+00 Max =  3.14159257E+00)
                   (Min =  0.00000000E+00 Max =  6.28316856E+00)
                   (Min =  0.00000000E+00 Max =  1.27036483E-01)
                   (Min = -2.26668086E-02 Max =  7.04508832E-02)
    GET_2DFLD   - surface u-wind component,                  t =     0 00:00:00
                   (Rec=0000571, Index=1, File: wind.nc)
                   (Tmin=       -142.5000 Tmax=        222.2500)
                   (Min =  6.16196944E-01 Max =  3.08001225E+00)
    GET_2DFLD   - surface v-wind component,                  t =     0 00:00:00
                   (Min = -3.33173673E-01 Max =  2.05091213E+00)
    GET_2DFLD   - surface air pressure,                      t =     0 00:00:00
                   (Rec=0001140, Index=1, File: pair.nc)
                   (Tmin=       -142.3750 Tmax=        222.5000)
                   (Min =  1.01738097E+03 Max =  1.01870001E+03)
    GET_2DFLD   - surface air temperature,                   t =     0 00:00:00
                   (Rec=0001140, Index=1, File: tair.nc)
                   (Min =  1.28998051E+01 Max =  1.42748051E+01)
    GET_2DFLD   - surface air relative humidity,             t =     0 00:00:00
                   (Rec=0001140, Index=1, File: qair.nc)
                   (Min =  8.90000000E-01 Max =  9.80000000E-01)
    GET_2DFLD   - solar shortwave radiation flux,            t =     0 00:00:00
                   (Rec=0001140, Index=1, File: swrad.nc)
 Maximum grid stiffness ratios:  rx0 =   2.000022E-01 (Beckmann and Haidvogel)
                                 rx1 =   1.294633E+01 (Haney)
 Initial basin volumes: TotVolume =  8.9261530669E+11 m3
                        MinVolume =  1.7694182887E+04 m3
                        MaxVolume =  1.5259540454E+07 m3
                          Max/Min =  8.6240435921E+02
 NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00002700)
    GET_2DFLD   - surface u-wind component,                  t =     0 06:00:00
                   (Rec=0000572, Index=2, File: wind.nc)
                   (Min = -1.75372802E-01 Max =  3.15555706E+00)
    GET_2DFLD   - surface v-wind component,                  t =     0 06:00:00
                   (Min =  1.56416958E+00 Max =  5.38237476E+00)
    GET_2DFLD   - surface air pressure,                      t =     0 03:00:00
                   (Rec=0001141, Index=2, File: pair.nc)
                   (Min =  1.01703815E+03 Max =  1.01945001E+03)
    GET_2DFLD   - surface air temperature,                   t =     0 03:00:00
                   (Rec=0001141, Index=2, File: tair.nc)
                   (Min =  1.30743656E+01 Max =  1.40743656E+01)
    GET_2DFLD   - surface air relative humidity,             t =     0 03:00:00
                   (Rec=0001141, Index=2, File: qair.nc)
                   (Min =  9.60000000E-01 Max =  9.80000000E-01)
    GET_2DFLD   - solar shortwave radiation flux,            t =     0 03:00:00
                   (Rec=0001141, Index=2, File: swrad.nc)
                   (Min =  3.56742872E-06 Max =  3.06048023E-05)
       0     0 00:00:00  5.572512E-03  1.345057E+03  1.345062E+03  9.089321E+11
          (113,119,39)  3.857196E-02  2.753595E-02  0.000000E+00  9.874988E-01
      DEF_HIS   - creating history file, Grid 01: out/roms/ocean_his_00001.nc
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000001
       5     0 00:02:00  5.408521E-03  1.363454E+03  1.363459E+03  8.964269E+11
          (103,121,40)  5.674017E-03  8.682401E-03  7.697877E-01  1.003817E+00
      10     0 00:04:00  5.287900E-03  1.363436E+03  1.363441E+03  8.963257E+11
          (103,122,40)  0.000000E+00  1.914535E-03  8.916389E-01  1.074895E+00
      15     0 00:06:00  5.254022E-03  1.363472E+03  1.363477E+03  8.962258E+11
          (113,008,40)  9.494561E-03  4.083571E-03  1.226500E+00  1.081200E+00
      20     0 00:08:00  5.285353E-03  1.363488E+03  1.363494E+03  8.961248E+11
          (188,112,40)  3.399103E-03  3.832126E-03  6.726246E-01  1.055692E+00
      25     0 00:10:00  5.355226E-03  1.363492E+03  1.363497E+03  8.960253E+11
          (101,122,40)  6.725133E-04  1.318796E-02  8.352360E-01  1.025486E+00
#12 Unread post by kate »
I don't see what the problem is. Yes, it is reading the forcing files for time 0 and for time 6 hours, then it linearly time-interpolates between them to the current model time. It always has two time records in memory for this interpolation. Once six hours pass, it will read hour 12, and so on.
