radiation / sst issue
jalves
#1 Unread post by jalves »
I have used the bulk_fluxes option, to force the model with shortwave (swrad) and longwave downwelling radiation (lwrad_down), among other variables, but I am getting SST somewhat higher (1 to 2 ºC) than the local observations or satellite temperatures.
The input radiations seem to me to have the expected values and as the currents also have normal values to the region I am studying, I think this is a radiation issue. Has someone had a similar problem and can give me any hint to lower the sea surface temperature?
Note: I am using roms-2.2
Thanks in advance,
jose
We've had this happen when using NCEP. I believe the collective wisdom is that it is underestimating the amount of low clouds, therefore overestimating the radiation hitting the water.
jacopo
#3 Unread post by jacopo »
some simple checks:
Remember you have to feed ROMS with 'net' shortwave, i.e., albedo effect already taken into account.
Remember to define DIURNAL_SRFLUX if you are using daily values of shortwave radiation
Remember to adjoust the values (in mod_scalars.F) of
        real(r8) :: blk_ZQ =  10.0_r8          ! (m)
        real(r8) :: blk_ZT =  10.0_r8          ! (m)
        real(r8) :: blk_ZW = 10.0_r8          ! (m)
according to your meteo input data.
well ... just in case you didn't :lol:
Jacopo
