LTRANS "jumped over a u element"
Information about ongoing ROMS/TOMS applications
fanqing
#1 Unread post by fanqing »
I was running LTRANS and came across the problem of "jumped over a u element" or "jumped over a v element" problem (error info listed below)
" Previous Location:
x: -7221945.47253313 y: 2073598.67415 247
lon: -64.8772335292822 lat: 18.3081033479963
Current Location:
x: -7221948.21037701 y: 2073618.07464950
lon: -64.8772581242805 lat: 18.3082688073524
The Program Cannot Continue and Will Terminate
Any suggestions how to overcome this problem?
Thanks.
Re: LTRANS "jumped over a u element"
I haven't run LTRANS, but perhaps it's complaining that the time-step is too long? It probably has the same sort of CFL condition as the ROMS model.
ian
#3 Unread post by ian »
fanqing wrote:Hi,
Current Location:
Thanks.
Decrease the internal timestep in LTRANS.data. The variable name is idt.
fanqing
#4 Unread post by fanqing »
Yes, changing the time step seems to have solved the problem. Thanks!
fanqing
#5 Unread post by fanqing »
Is there a recommended idt value, maybe depending on the spatial resolution?
ian
#6 Unread post by ian »
fanqing wrote:Is there a recommended idt value, maybe depending on the spatial resolution?
Yes, the value is highly dependent on the spatial resolution and the particle velocities.
The model will not allow a particle to move through a gridcell without being effected by its properties, so smaller gridcells and larger velocities require smaller idt values.
fanqing
#7 Unread post by fanqing »
Can LTRANS be used to simulate oil spill trajectory and fate?
Fanqi
#8 Unread post by kate »
LTRANS was designed for tracking biological critters within the ocean. You could probably use it to track surface objects, but I doubt it has the oil weathering processes or the effect of winds on oil.
One could of course add them since the source is out there.
fanqing
#9 Unread post by fanqing »
I just found it was used for this purpose:
http://omgrhe.meas.ncsu.edu/RHE/Northet ... npress.pdf
ian
#10 Unread post by ian »
fanqing wrote:Can LTRANS be used to simulate oil spill trajectory and fate?
Fanqi
Yes, actually it can!
We have not released this code to the public yet, but I believe some others have independently done so. Keep on the look out for LTRANS 3.0!
