LTRANS "jumped over a u element"
I was running LTRANS and came across the problem of "jumped over a u element" or "jumped over a v element" problem (error info listed below)
" Previous Location:
x: -7221945.47253313 y: 2073598.67415 247
lon: -64.8772335292822 lat: 18.3081033479963
Current Location:
x: -7221948.21037701 y: 2073618.07464950
lon: -64.8772581242805 lat: 18.3082688073524
The Program Cannot Continue and Will Terminate
Any suggestions how to overcome this problem?
Thanks.
Current Location:
Thanks.
Re: LTRANS "jumped over a u element"
I haven't run LTRANS, but perhaps it's complaining that the time-step is too long? It probably has the same sort of CFL condition as the ROMS model.
Decrease the internal timestep in LTRANS.data. The variable name is idt.fanqing wrote:Hi,
Current Location:
Thanks.
Yes, changing the time step seems to have solved the problem. Thanks!
Is there a recommended idt value, maybe depending on the spatial resolution?
Yes, the value is highly dependent on the spatial resolution and the particle velocities.fanqing wrote:Is there a recommended idt value, maybe depending on the spatial resolution?
The model will not allow a particle to move through a gridcell without being effected by its properties, so smaller gridcells and larger velocities require smaller idt values.
Can LTRANS be used to simulate oil spill trajectory and fate?
Fanqi
Fanqi
LTRANS was designed for tracking biological critters within the ocean. You could probably use it to track surface objects, but I doubt it has the oil weathering processes or the effect of winds on oil.
One could of course add them since the source is out there.
I just found it was used for this purpose:
http://omgrhe.meas.ncsu.edu/RHE/Northet ... npress.pdf
Yes, actually it can!fanqing wrote:Can LTRANS be used to simulate oil spill trajectory and fate?
Fanqi
We have not released this code to the public yet, but I believe some others have independently done so. Keep on the look out for LTRANS 3.0!
