hello
when i want to use nudging method about 3d-field, shoud i need u and v values in climate_file??
if i need u,v values in clim_file, i can't slove this problem.
how can i do??
i have a question about nudging
- 11.png (9.94 KiB) Viewed 3652 times
Re: i have a question about nudging
You have choices. One option is to start by only nudging to T and S and see how that works for you. If you also need nudging to u,v, here are the dimensions of things for one of my files:
Oops, I see I'm going to have to add a "time" attribute to all of these, making the velocities match salt. Anyway, all your horizontal dimensions should look something like this.
dimensions:
s_rho = 50 ;
s_w = 51 ;
eta_rho = 1090 ;
xi_rho = 690 ;
eta_u = 1090 ;
xi_u = 689 ;
eta_v = 1089 ;
xi_v = 690 ;
eta_psi = 1089 ;
xi_psi = 689 ;
ocean_time = UNLIMITED ; // (12 currently)
double salt(ocean_time, s_rho, eta_rho, xi_rho) ;
salt:_FillValue = -9.98999971057742e+33 ;
salt:long_name = "salinity" ;
salt:units = "PSU" ;
salt:field = "salinity, scalar, series" ;
salt:time = "ocean_time" ;
double u(ocean_time, s_rho, eta_u, xi_u) ;
u:_FillValue = -9.98999971057742e+33 ;
u:long_name = "3D u-momentum component" ;
u:units = "meter second-1" ;
u:field = "u-velocity, scalar, series" ;
double ubar(ocean_time, eta_u, xi_u) ;
ubar:_FillValue = -9.98999971057742e+33 ;
ubar:long_name = "2D u-momentum component" ;
ubar:units = "meter second-1" ;
ubar:field = "ubar-velocity,, scalar, series" ;
double v(ocean_time, s_rho, eta_v, xi_v) ;
v:_FillValue = -9.98999971057742e+33 ;
v:long_name = "3D v-momentum component" ;
v:units = "meter second-1" ;
v:field = "v-velocity, scalar, series" ;
There are CDL templates for the various ROMS files in the folder Data/ROMS/CDL (starting from the same level in the hierarchy where you see: Atmosphere, Data, Master, User, makefile ... ROMS etc.)
You can copy and edit those to match your grid dimensions, being careful to maintain the +/- 1 in the respective dimensions. Then create an empty netcdf file with, e.g.
ncgen -b -o myfile.nc template.cdl
