Problems using Multiple Input files in COAWST
robjenkinsiii
#1 Unread post by robjenkinsiii »
I have several yearly forcing files for SUSTR and SVSTR.
The model runs fine with an individual year ( the first file ) but will not run when I introduce the continuation mark ( | ) and the next two years of files.
I follow the syntax for multiple time-split files in ocean.in but It still does not work.
Is there some CCP option or other setting that I am missing?
In ocean in I simply change ...
     NFFILES == 3                         ! number of unique forcing files
!changed Rob's version Jan 2014
     FRCNAME == delriv_2006_2012_frc.nc   \            ! forcing file 1, grid 1
                delbayfrc2006.nc          \
                roms_narr_2006.nc
to ...
                delbayfrc2006.nc          \
                roms_narr_2006.nc |
                roms_narr_2007.nc |
                roms_narr_2008.nc
And the model no longer runs.
For the non-working case, The log file reports...
             Output Restart File:  OutputNARR/ocean_rst.nc
        Prefix for History Files:  OutputNARR/ocean_his
        Physical parameters File:  ocean.in
                 Input Grid File:  delbay_grd.nc
    Input Nonlinear Initial File:  delbayini2006.nc
           Input Forcing File 01:  delriv_2006_2012_frc.nc
           Input Forcing File 02:  delbayfrc2006.nc
 READ_PHYPAR - could not find input file:
Elapsed CPU time (seconds):
 Node   # 11 CPU:       0.104
 Node   #  1 CPU:       0.103
 Node   #  2 CPU:       0.106
 Node   #  3 CPU:       0.106
 Node   #  4 CPU:       0.103
 Node   #  5 CPU:       0.104
 Node   #  6 CPU:       0.103
 Node   #  7 CPU:       0.103
 Node   #  8 CPU:       0.104
 Node   #  9 CPU:       0.103
 Node   # 10 CPU:       0.103
 Node   #  0 CPU:       0.103
 Total:                 1.246
                                              Total:         0.000    0.0000
  Message Passage: data broadcast ..................         0.080  ( 6.4158 %)
                                              Total:         0.080    6.4158
 All percentages are with respect to total time =            1.246
coawstM:13200 terminated with signal 11 at PC=99000c SP=7ffff3bf0cf0.  Backtrace:
coawstM:13201 terminated with signal 11 at PC=99000c SP=7fff4db12dc0.  Backtrace:
coawstM:13191 terminated with signal 11 at PC=99000c SP=7fffd3fde7c0.  Backtrace:
coawstM:13192 terminated with signal 11 at PC=99000c SP=7fffb789bdb0.  Backtrace:
coawstM:13193 terminated with signal 11 at PC=99000c SP=7fffd7ca22a0.  Backtrace:
coawstM:13194 terminated with signal 11 at PC=99000c SP=7fff79be6730.  Backtrace:
coawstM:13195 terminated with signal 11 at PC=99000c SP=7fff16563d60.  Backtrace:
coawstM:13196 terminated with signal 11 at PC=99000c SP=7fff5b0bd9b0.  Backtrace:
coawstM:13197 terminated with signal 11 at PC=99000c SP=7fff6c689d50.  Backtrace:
coawstM:13198 terminated with signal 11 at PC=99000c SP=7fff5ad2bb10.  Backtrace:
coawstM:13199 terminated with signal 11 at PC=99000c SP=7fff7b886e40.  Backtrace:
coawstM:13202 terminated with signal 11 at PC=99000c SP=7fff37b475a0.  Backtrace:
 ROMS/TOMS - I/O error ............... exit_flag:   4
 ERROR: I/O related problem.
All the files are in the working directory.
I've searched the forum, the wiki, and the manual and I've yet to find an answer to my problem.
Any tips would be greatly appreciated.
Thanks!
robjenkinsiii
Re: Problems using Multiple Input files in COAWST
#2 Unread post by robjenkinsiii »
Additionally, I should say that I have been running this application successfully for several months and I also scoured by ocean.in file for errant characters like tabs, etc.
#3 Unread post by jcwarner »
we have this set up the same was as Rutgers, so i am not sure why it is giving an issue.
does it work for
delbayfrc2006.nc \
roms_narr_2006.nc |
roms_narr_2007.nc
or even try
delbayfrc2006.nc \
roms_narr_2006.nc |
roms_narr_2007.nc
robjenkinsiii
#4 Unread post by robjenkinsiii »
Thank you for your quick reply,
I tried both methods and both produced the same error, with ROMS unable to find the wind forcing input files.
#5 Unread post by jcwarner »
try
roms_narr_2006.nc |
roms_narr_2007.nc \
delbayfrc2006.nc
