I went to 'http://coast-enviro.er.usgs.gov/models/Latte/in/', and downloaded all the files except "varinfo.dat" (it goes wrong when download it). The same thing happened when dealing with ./original/ file.
I want to know if the 'varinfo.dat' file here is the same with that used in the UPWELLING case. Since someplace told that they are different --
Installing and Running ROMS for First Time Users
<https://www.myroms.org/wiki/index.php/ROMS_UNSW2008>
__________________________
Create a latte_c project directory
We have placed the CPP options file latte_c.h, standand input ocean_lattec.in, and a modified varinfo.dat in /srv/ckpt/roms/shared/latte_c/Forward.
if different, how to modify the file ?
Zhao
where can I get the "varinfo.dat" in "laTTE" simulation?
- Location: Nanjing Uni. of Info. Sci. & Tech. (nanjing institute of meterology)
Re: where can I get the "varinfo.dat" in "laTTE" simulation?
is there any cue ?
I guess someone else also met with this problem.
- Location: National and Kapodistrian University of Athens
Hello Kee,
I'm new in ROMS and in ocean modeling so i can't really help you. I wanted also to run the Latte test case but i found the following discussion saying that latte needs to be updated so i didn't even try to run it.... Check this and good luck
viewtopic.php?f=31&t=2080&p=10595&hilit=laTTE#p10595
Evridiki
Evridiki
Hi evridiki,evridiki wrote:Hello Kee,
Evridiki
Thanks for your kindly reply!
I will consider.
If I get some results I inform you.
succeed in "laTTE" simulation
Evridiki
Hi Evridiki,
there is good news.
I successfully carried out the LATTE case. some figures are in the attachment. you can have a look.
BTW, the Varinfo.dat file is also given, and other files can be found in
and the instruction is in https://www.myroms.org/wiki/index.php/CSTMS_UNSW2008
If you have any questions, just leave yr words here.
Cheer up
zhao
- varinfo.dat
- (146.17 KiB) Downloaded 651 times
- Location: University of Maryland Center for Environ. Sci.
Re: succeed in "laTTE" simulation
kee wrote:evridiki wrote:Hello Kee,
Evridiki
Hi Evridiki,
there is good news.
Cheer up
zhao
Hi, Kee,
I am trying to run the LaTTE case too and looking for the input file latte_c.h, ocean_lattec.in and varinfo.dat. I go to the website http://coast-enviro.er.usgs.gov/models/Latte/ and find that this link is invalid now. Could you help to provide these three files?
Thanks!
Wenfei
I created the LATTE test case for a ROMS User Workshop in 2009 and have not updated the files since. That test case is well out of date. Sorry.
