Dear all
I have ran into a problem.My result of Roms is abnormal,the temp is more high in the northern of my areas.
My test_south.in is :
! Cha Chapman
! Cla Clamped
! Clo Closed
! Gra Gradient | 4 |
! Nes Nested | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics 2 j=1
! i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Clo Cha Cha Clo ! free-surface
LBC(isUbar) == Clo Fla Fla Clo ! 2D U-momentum
LBC(isVbar) == Clo Fla Fla Clo ! 2D V-momentum
LBC(isUvel) == Clo RadNud RadNud Clo ! 3D U-momentum
LBC(isVvel) == Clo RadNud RadNud Clo ! 3D V-momentum
LBC(isMtke) == Clo Gra Gra Clo ! mixing TKE
LBC(isTvar) == Clo RadNud RadNud Clo \ ! temperature
Clo RadNud RadNud Clo ! salinity
! conditions keywords.
ad_LBC(isFsur) == Clo Clo Clo Clo ! free-surface
ad_LBC(isUbar) == Clo Clo Clo Clo ! 2D U-momentum
ad_LBC(isVbar) == Clo Clo Clo Clo ! 2D U-momentum
ad_LBC(isUvel) == Clo Clo Clo Clo ! 3D U-momentum
ad_LBC(isVvel) == Clo Clo Clo Clo ! 3D V-momentum
ad_LBC(isMtke) == Clo Clo Clo Clo ! mixing TKE
ad_LBC(isTvar) == Clo Clo Clo Clo \ ! temperature
Clo Clo Clo Clo ! salinity
! conservation, except if tidal forcing enabled. [1:Ngrids].
VolCons(west) == F ! western boundary
VolCons(east) == T ! eastern boundary
VolCons(south) == T ! southern boundary
ad_VolCons(east) == T ! eastern boundary
ad_VolCons(south) == T ! southern boundary
! Time-Stepping parameters.
NTIMES == 103680 !20 years
DT == 600.0d0
NDTFAST == 180
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
! Input/Output parameters.
NRREC == 0
LcycleRST == T
NRST == 51840
NSTA == 1
NFLT == 1
NINFO == 1
LDEFOUT == T
NHIS == 0
NDEFHIS == 0
NTSAVG == 1
NAVG == 4320
NDEFAVG == 51840
NTSDIA == 1
NDIA == 0
NDEFDIA == 0
LcycleTLM == F
NTLM == 720
NDEFTLM == 0
LcycleADJ == F
NADJ == 720
NDEFADJ == 0
NSFF == 720
NOBC == 720
! GST output and check pointing restart parameters.
LmultiGST = F ! one eigenvector per file
Ritz_tol = 1.0d-15
TNU2 == 20.0d0 20.0d0 ! m2/s
TNU4 == 2*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
VISC2 == 100.0d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
AKT_BAK ==5.0d-6 5.0d-6 ! m2/s
AKV_BAK == 5.0d-5 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
GLS_P == 3.0d0 ! K-epsilon
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.005d0 ! m
Zos == 0.02d0 ! m
BLK_ZQ == 2.0d0 ! air humidity
BLK_ZT == 2.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
! Minimum depth for wetting and drying.
DCRIT == 0.10d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
! Set vertical, terrain-following coordinates transformation equation and
! stretching function (see below for details), [1:Ngrids].
Vtransform == 2 ! transformation equation
Vstretching == 4 ! stretching function
! Vertical S-coordinates parameters (see below for details), [1:Ngrids].
THETA_S == 3.0d0 ! surface stretching parameter
THETA_B == 0.3d0 ! bottom stretching parameter
TCLINE == 100.0d0 ! critical depth (m)
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! NetCDF units attribute.
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = -1.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 2*5.0d0 ! days
ZNUDG == 5.0d0 ! days
M2NUDG == 5.0d0 ! days
M3NUDG == 5.0d0 ! days
OBCFAC == 120.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 10.0d0 ! Celsius
S0 == 35.0d0 ! PSU
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 7.6d-4 ! 1/PSU
GAMMA2 == 1.0d0
! Logical switches (TRUE/FALSE) to specify which variables to process for
! tracer climatology: [1:NAT+NPT,Ngrids]. See glossary below for details.
!LtracerCLM == T T ! temperature, salinity, inert
!LsshCLM == T ! sea-surface height
!Lm2CLM == T ! 2D momentum
!Lm3CLM == T ! 3D momentum
! Logical switches (TRUE/FALSE) to nudge the desired climatology field(s).
!If not analytical climatology fields, users need to turn ON the logical switches
!above to process the fields from the climatology NetCDF file that are needed for nudging.
!LnudgeTCLM == T T ! temperature, salinity
!LnudgeM2CLM == T ! 2D momentum
!LnudgeM3CLM == T ! 3D momentum
! Logical switches (TRUE/FALSE) to specify which variables to consider on
! tracers point Sources/Sinks (like river runoff): [1:NAT+NPT,Ngrids].
! See glossary below for details.
LtracerSrc == F F ! temperature, salinity, inert
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
Lstate(isFsur) == F ! free-surface
Lstate(isTvar) == F F ! NT tracers
! Logical switches (TRUE/FALSE) to specify the state variables for
! which Forcing Singular Vectors or Stochastic Optimals is required.
Fstate(isFsur) == F ! free-surface
Fstate(isUstr) == T ! surface U-stress
Fstate(isVstr) == T ! surface V-stress
! Stochastic Optimals time decorrelation scale (days) assumed for
! red noise processes.
SO_decay == 2.0d0 ! days
! Stochastic Optimals surface forcing standard deviation for
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracers flux
! HISTORY output file.
Hout(idUvel) == T ! u 3D U-velocity
Hout(idu3dE) == T ! u_eastward 3D U-eastward at RHO-points
Hout(idv3dN) == T ! v_northward 3D V-northward at RHO-points
Hout(idWvel) == F ! w 3D W-velocity
Hout(idOvel) == F ! omega omega vertical velocity
Hout(idUbar) == F ! ubar 2D U-velocity
Hout(idVbar) == F ! vbar 2D V-velocity
Hout(idBath) == F ! bath time-dependent bathymetry
! tracers other than biological and sediment tracers. An inert passive tracer
! is one that it is only advected and diffused. Other processes are ignored.
! These tracers include, for example, dyes, pollutants, oil spills, etc.
! NPT values are expected. However, these switches can be activated using
! compact parameter specification.
Hout(inert) == F ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of exposed sediment
! layer properties into HISTORY output file. Currently, MBOTP properties
! are expected for the bottom boundary layer and/or sediment models:
! idBott( 1=isd50) grain_diameter mean grain diameter
! idBott( 2=idens) grain_density mean grain density
! idBott( 3=iwsed) settling_vel mean settling velocity
! idBott( 4=itauc) erosion_stres critical erosion stress
! idBott( 5=irlen) ripple_length ripple length
! idBott( 6=irhgt) ripple_height ripple height
! idBott( 7=ibwav) bed_wave_amp wave excursion amplitude
! idBott( 8=izdef) Zo_def default bottom roughness
! idBott( 9=izapp) Zo_app apparent bottom roughness
! idBott(10=izNik) Zo_Nik Nikuradse bottom roughness
! idBott(11=izbio) Zo_bio biological bottom roughness
! idBott(12=izbfm) Zo_bedform bed form bottom roughness
! idBott(13=izbld) Zo_bedload bed load bottom roughness
! idBott(14=izwbl) Zo_wbl wave bottom roughness
! idBott(15=iactv) active_layer_thickness active layer thickness
! idBott(16=ishgt) saltation saltation height
! 1 1 1 1 1 1 1
! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
Hout(idBott) == F F F F F F F F F F F F F F F F
! Logical switches (TRUE/FALSE) to activate writing of time-averaged
! fields into AVERAGE output file.
Aout(idUvel) == T ! u 3D U-velocity
Aout(idu3dE) == T ! u_eastward 3D U-eastward at RHO-points
Aout(idv3dN) == T ! v_northward 3D V-northward at RHO-points
Aout(idWvel) == F ! w 3D W-velocity
Aout(idOvel) == F ! omega omega vertical velocity
Aout(idUbar) == F ! ubar 2D U-velocity
Aout(idVbar) == F ! vbar 2D V-velocity
Aout(idTsur) == T T ! shflux, ssflux surface net heat and salt flux
Aout(idv2dD) == F ! vbar_detided detided 2D V-velocity
Do have any problem with this setup,such as Vertical mixing coefficient.
Then my test.h is
/**************************** Basic physics options **************************/
#define MIX_GEO_TS /* mixing on geopotential (constant Z) surfaces */
#define MIX_S_UV /* use if mixing along constant S-surfaces */
/*************************** Basic numerics options **************************/
!#define SPHERICAL
#define SPLINES /* use to activate parabolic splines reconstruction */
#define TS_U3HADVECTION /* define if 3rd-order upstream horiz. advection */
#define TS_C4VADVECTION /* use if 4th-order centered vertical advection */
#define PROFILE /* use if time profiling */
/************************************ Outputs ********************************/
!#define DIAGNOSTICS_UV
!#define DIAGNOSTICS_TS
/*********************** Surface and bottom boundary conditions **************/
/* Bottom boundary conditions */
#define ANA_BSFLUX /* analytical bottom salinity flux */
#define ANA_BTFLUX /* analytical bottom temperature flux */
#define UV_QDRAG /* use to turn ON or OFF linear bottom friction */
/* Surface boundary conditions */
!#define QCORRECTION
!#define SRELAXATION
!#define BULK_FLUXES
!#ifdef BULK_FLUXES
!#define EMINUSP
!#endif
/********************* Vertical subgridscale turbulence closure ***************/
#ifdef SOLVE3D
!# define GLS_MIXING /* Activate Generic Length-Scale mixing */
!# define MY25_MIXING
# define LMD_MIXING
# ifdef LMD_MIXING
# define LMD_SKPP
!# define LMD_BKPP
# define LMD_RIMIX
# define LMD_CONVEC
!# define ANA_CLOUD /* Wilkin, J., 2006 */
!# define LMD_NONLOCAL
# ifdef MY25_MIXING
# define N2S2_HORAVG /* Activate horizontal smoothing of buoyancy/shear */
# ifdef GLS_MIXING
# define KANTHA_CLAYSON /* Kantha and Clayson stability function formulation */
# define CANUTO_A /* Canuto A-stability function formulation */
# define CANUTO_B /* Canuto B-stability function formulation */
/*********************************** Open boundary conditions ***********************/
/************************************* Biology ************************************/
#if defined BIO_FENNEL || defined ECOSIM || \
defined NPZD_POWELL || defined NEMURO
# define ANA_BIOLOGY
# define ANA_SPFLUX
# define ANA_BPFLUX
# define ANA_SRFLUX
#if defined NEMURO
# define HOLLING_GRAZING
# undef IVLEV_EXPLICIT
#ifdef BIO_FENNEL
# define CARBON
# define DENITRIFICATION
# define BIO_SEDIMENT
# define DIAGNOSTICS_BIO
/********************************* Other applications *****************************/
#ifdef PERFECT_RESTART
# undef AVERAGES
# undef DIAGNOSTICS_BIO
# undef DIAGNOSTICS_TS
# undef DIAGNOSTICS_UV
# define OUT_DOUBLE
thanks in advanse.
My test_south.in
Re: My test_south.in
Is this a surface heating problem or a boundary condition problem? How are you providing the surface heat fluxes? You've commented out BULK_FLUX, so you must be providing some heat flux from outside. If so, you should also provide the dQdSST term.
Hello,kate.kate wrote:Is this a surface heating problem or a boundary condition problem? How are you providing the surface heat fluxes? You've commented out BULK_FLUX, so you must be providing some heat flux from outside. If so, you should also provide the dQdSST term.
I made a forced field data by agrifroms.There are shflux,swflux,sst,sss,srflux and dQdsst.As you said,I have commented out BULK_FLUX,if I open BULK_FLUX,can the problem be solved? Or if I still commented out BULK_FLUX,how can i make the dQdSST term into my ROMS,I make '#define QCORRECTION',then i find my temp is normal,but my SSH is so little,look at the picture.is the swflux not provided into ROMS?
thanks in advance!
- the SSH is very very little!
- QQ图片20141010143044.jpg (78.61 KiB) Viewed 3452 times
So you are saying:
* With QCORRECTION, SST looks good, SSH looks bad.
* Without QCORRECTION, SST looks bad, SSH looks good.
Is that right? I don't know how that could be.
kate,I don't mean 'Without QCORRECTION, SST looks bad, SSH looks good'.without QCORRECTION,the SST and SSH are all bad,but if with QCORRECTION,the SST looks better than without QCORRECTION,but the minimize is too small.and the SSH is like Previous figure.So i choose open SRELAXATION term,but the result looks no significant progress.kate wrote:So you are saying:
In my test.h,which is Missing some switch or not? do the SRELAXATION need open?what's more ,my Vertical mixing coefficients need to change bigger?
When i make my test.h like follows:
#define VISC_GRID
!#define TCLM_NUDGING
!#define SPHERICAL
#define M2CLIMATOLOGY
#define TCLIMATOLOGY
#define ZCLIMATOLOGY
#define M2CLM_NUDGING
#define ZCLM_NUDGING
#define QCORRECTION
#define SCORRECTION
!#ifdef BULK_FLUXES
!#define EMINUSP
!#endif
#ifdef SOLVE3D
# define LMD_MIXING
# ifdef LMD_MIXING
# define LMD_SKPP
!# define LMD_BKPP
# define LMD_RIMIX
# define LMD_CONVEC
# ifdef MY25_MIXING
# ifdef GLS_MIXING
# define ANA_SPFLUX
# define ANA_BPFLUX
# define ANA_SRFLUX
#if defined NEMURO
#ifdef BIO_FENNEL
# define CARBON
# undef AVERAGES
# define OUT_DOUBLE
The result of my ROMS is so surprise!
kate, I created a climate state data,like forcing filed and initial filed .
Thanks a lot!
- the ssh is very bad.
the sst is so monstrosity,and with some islands is very small - QQ截图20141011152337.jpg (265.38 KiB) Viewed 3431 times
