swan+roms test
fereshteh
Location: inio:Iranian National Institute for Oceanography
swan+roms test
#1 Unread post by fereshteh »
Dear
For inlet test I have updates its files as suggested in forum. I could compile it but for running, some errors appear. forum has been checked for solving them but its suggestions (for example set 1 cpu for swan) cannot help me therefore I send .log file contains created after run command:
$ Mpirun –np 8 ./oceanG coupling_inlet_test.in>run.log
(for Ntilei=2 Ntilej=2 Nthreads(oceans0=4) and Nthreads (waves)=4)
Coupled Input File name = coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 003
Waves Model MPI nodes: 004 - 007
Sunday - October 12, 2013 - 5:00:00 PM
Inlet Test Case
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /home/fkomijani/mpich2/bin/mpif90
Compiler flags : -frepack-arrays -g -fbounds-check -I/home/fkomijani/MCT/include -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script : /home/fkomijani/projects/INLET_test/inlet_test/ocean_inlet_test.in
SVN Revision : exported
Local Root : /home/fkomijani/ROMS/TRUNK
Header Dir : /home/fkomijani/projects/INLET_test/inlet_test
Header file : inlet_test.h
Analytical Dir: /home/fkomijani/ROMS/TRUNK/ROMS/Functionals
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 4, Tiling: 002x002
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
720 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
Physical parameters File: /home/fkomijani/projects/INLET_test/inlet_test/ocean_inlet_test.in
Input Grid File: /home/fkomijani/projects//INLET_test/inlet_test/inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 002x002
tile Istr Iend Jstr Jend Npts
0 1 38 1 35 10640
1 39 75 1 35 10360
2 1 38 36 70 10640
3 39 75 36 70 10360
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 38.50 0.50 35.50 RHO-points
1 38.50 75.50 0.50 35.50 RHO-points
2 0.50 38.50 35.50 70.50 RHO-points
3 38.50 75.50 35.50 70.50 RHO-points
0 1.00 38.50 0.50 35.50 U-points
1 38.50 75.00 0.50 35.50 U-points
2 1.00 38.50 35.50 70.50 U-points
3 38.50 75.00 35.50 70.50 U-points
0 0.50 38.50 1.00 35.50 V-points
1 38.50 75.50 1.00 35.50 V-points
2 0.50 38.50 35.50 70.00 V-points
3 38.50 75.50 35.50 70.00 V-points
HaloSizeI(1) = 150
HaloSizeJ(1) = 144
TileSide(1) = 44
TileSize(1) = 1848
Sediment Parameters, Grid: 01
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
tau_ce tau_cd nl_tnu2 nl_tnu4 Akt_bak Tnudg
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idSbed) Write out BED property 03: bed_porosity
zeta 1 Gradient Closed Gradient Gradient
ubar 1 Gradient Closed Gradient Reduced
vbar 1 Gradient Closed Gradient Reduced
u 1 Gradient Closed Gradient Gradient
v 1 Gradient Closed Gradient Gradient
temp 1 Gradient Closed Gradient Gradient
salt 1 Gradient Closed Gradient Gradient
mud_01 1 Gradient Closed Gradient Gradient
tke 1 Gradient Closed Gradient Gradient
INLET_TEST Inlet Test Case
ANA_SEDIMENT Analytical sediment initial conditions.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR05 Nearshore Radiation Stress Terms (Mellor 2005).
NEARSHORE_MELLOR08 Nearshore Radiation Stress Terms (Mellor 2008).
NONLINEAR Nonlinear Model.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
CHECKDEFS - only one radiation stress formulation is allowed.
Elapsed CPU time (seconds):
ERROR: Illegal model configuration.
as you can see there is not any thing that shows swan model is computing.
And also in linux shell this error appears:
MCT::m_MCTWorld::clean_: deallocate(MCTW,...) error, stat =2
That MCT_world.mod located in mct/include directory.
And I get Terminating error: Inputfile missing Message in PRINT and Errfile files.
i need your experience to sort out what cause these problems.
thanks in advance for your attention and guidance
cheers
fereshte
redhat007
Re: swan+roms test
#2 Unread post by redhat007 »
dear
i can solve above problem ( :D ) by
#define nearshore_mellor08
inlet test is running from 2 days ago :shock: .
would you please tell me estimated time for this test when use 8 processors.
Is there any way that while it is running, i find that every thing is OK.
thank you
fereshte
fereshteh
Re: swan+roms test
#3 Unread post by fereshteh »
dear all
in inlet test, after solving some errors which appear in Print_xx files and Errofile_xx files, now mentioned test is running but again some empty Print_xx files and Errofile_xx files created in project directory while linux shell shows model is still running.
i check created .log file. End of it shows nodes for ocean model are active but there is not any thing about swan nodes. i set 4 cpu for swan test
Process Information
node # 0 (pid= 2055) is active
node # 2 (pid= 2075) is active
node # 1 (pid= 2055) is active
node # 3 (pid= 2055) is active
but after 2 weeks running does not finished also no thing change.
it seems that model running has problem. would you please help me find what is the problem?
also is there any command which shows processes when model is running?
all the best
fereshte
Re: swan+roms test
#4 Unread post by jcwarner »
how about trying it with just one proc for roms, and one for swan.
that job should only take about 20 minutes to run, or something like that. the ocean_his.nc should be written to, and you would see output immediately. IF you are getting Err* files, then there is something wrong with SWAN. most likely it can not find the bathy.bot or grd file.
fereshteh
Re: swan+roms test
#5 Unread post by fereshteh »
dear Warner
At first thanks for your suggestion . i use it and set
Ntilei=1, Ntilej=1 ,Nthreads (ocean)=1 and Nthreads (waves)=1
but in every run which 1 cpu set for swan model (in this example:also 1 procc for ocean model) it reply
mpirun -np 2 ./oceanG coupling_inlet-test.in>mpi.log
application called MPI_Abort(comm=0x84000002, 4) - process 0
and in Errorfile and print files, input file missing error appears.
those problems happen when ever 1 cpu set for swan while different number set for ocean model ( 1 to 4)
it is necessary to say that i bring out _coor.grd and _bathy.bot files from Data folder and put them beside swan_inlet_test.in, then in READGRID and READINP portions, just call those file's names, respectively.
i don't have idea how can solve this error therefore i request you guide me.
all the best
fereshte
jafar1979
Re: swan+roms test
#6 Unread post by jafar1979 »
dear Warner
i am sure that MPICH2 (release 1.4.1p1 )installation was correct
/configure FC=gfortran CC=gcc  --prefix=/home/<user>/mpich2_install_new 2>&1 |tee c.txt
make 2>&1 |tee m.txt
make install  2>&1 |tee mi.txt
because i was able to run upwelling test in parallel mode successfully.
and about MCT i do
export USE_MPI=on # distributed-memory parallelism
export USE_MPIF90=on # compile with mpif90 script
export which_MPI=mpich2 # compile with MPICH2 library
#export which_MPI=openmpi
if [ "${which_MPI}" = "mpich2" ]; then
export ESMF_DIR=/opt/gfortransoft/mpich2/esmf
##export MCT_INCDIR=/opt/gfortransoft/mpich2/mct/include
##export MCT_LIBDIR=/opt/gfortransoft/mpich2/mct/lib
export MCT_INCDIR=/home/fkomijani/MCT_install/include
export MCT_LIBDIR=/home/fkomijani/MCT_install/lib
in build.bash file and
ifdef USE_MCT
MCT_INCDIR ?= /home/fkomijani/MCT_install/include
MCT_LIBDIR ?= /home/fkomijani/MCT_install/lib
FFLAGS += -I$(MCT_INCDIR)
LIBS += -L$(MCT_LIBDIR) -lmct -lmpeu
in linux_gfortran.mk file.
also read all posts about inlet test. but i dont know what is the problem.
would you please help me to sort out it.
thanks in advance
all the best
fereshte
Re: swan+roms test
#7 Unread post by jcwarner »
i think you mean:
mpirun -np 2 ./oceanG coupling_inlet_test.in>mpi.log
( undescores in the input file name, not dash -)
If you move the files, then you need to tell it the new paths. I have not run the test case as distributed by Rutgers lately. But you should just follow the input files.
It first points to the coupling_inlet_test.in
In that file, it should list the paths to the ocn and wav input files. in those files they list the paths to the grids etc. the way i had it set up, you would not have needed to move any files.
check the paths to the files and see if they are correct. is there anything in the PRINT or ERR* files?
jafar1979
Re: swan+roms test
#8 Unread post by jafar1979 »
hi
i guess that bug in mpich2 release 1.4.1p1 cause above problem, therefore i installed release 3.0.4 but it can not help me. as i told before when more that 1 cpu used for swan, PRINT or ERR* files are empty but when 1 cpu used for it, there is input file missing error in those files and in terminal page
arise.
about input files change:
swan_inlet_test.in keeps with out any changes.
in couplig_inlet_test changes are as: 1-INPname(ocean)=/home/..../test/ocean_inlet_test.in 2- INPname(waves)=/home/..../test/swan-inlet-test.in 3-CLPname=/home/.../test/coupling.dat
in ocean_inlet_test.in changes are as: 1- VARNAME=/home/.../test/varinfo.dat 2- GRDNAME=/home/.../test/inlet_test_grid.nc
as well as some changes in build.bash file for MCT requested path, USE_MPI,USE_MPIF90,mpich2 and so on.
with regard this post what you think about reason of this problem?
thanks
Re: swan+roms test
#9 Unread post by jcwarner »
if the Err and Print files have errors, then the errors are with swan, not roms.
did you relly have the swan input file listed as
or
2- INPname(waves)=/home/..../test/swan_inlet_test.in
is that the real path, all those dots?
sometimes swan does not like the path name to be more than 72 characters.
jafar1979
Re: swan+roms test
#10 Unread post by jafar1979 »
Dear Warner
many many thanks
i can not believe that my fault is long path name. now Swan is preparing computation. but recent error is:
at line 420 of file ocpids.f90
Fortran runtime error:actual string length is shorter than the declared one for dummy argument 'timstr' (15/24)
base on NTIMES=34560, DT=5 s ocean model run time is 2 days. and base on swan model' s input, this model run for 25 days. 20000101 25 DAY 20000126
does following error appear for this different run times? but why after modifing swan run time for 2 days, this error arise again :?:
thanks again for your attention
jafar1979
Re: swan+roms test
#11 Unread post by jafar1979 »
dear Warner
about my last post:
At line 420 of file ocpids.f90
Fortran runtime error: Actual string length is shorter than the declared one for dummy argument 'timstr' (15/24)
swan model break when it what to give current from ROMS model.
i check ocpids.f90 file (and ocpids.F) it includes :
  --------Fortran 90 date-time routines --------
  CHARACTER TIMSTR *24, CDUMMY *5                                     30.82
      INTEGER   IDUMMY(8)                                                 30.82
      CALL DATE_AND_TIME (TIMSTR(1:8), TIMSTR(10:20), CDUMMY, IDUMMY)     30.70
:     CALL DTSTTI (1, TIMSTR, PRCTIM)                                     30.70
      RETURN
      END SUBROUTINE OCDTIM
 line420:     SUBROUTINE DTSTTI (IOPT, TIMSTR, DTTIME)
which this information taken from ocpids.F that located in Trunk/Waves/SWAN/Src .it seem that timstr length in SWAN and ROMS model are not equal. as you can see its length in SWAN model is 24 and in ROMS model is 15 (base on above error message). at first i tried to set timstr to 15 length but with regard that it called in different function it can help me.
Now would you pleas give me an idea to fix this error
thanks in advance
Re: swan+roms test
#12 Unread post by jcwarner »
i remember this error, and it has been corrected in future versions of swan. If you really want to do roms+swan coupling, perhaps you could use our coawst system which has an updated version of swan, and vortex force instead of mellor method, grid refinement in swan, etc. send me an email at
jcwarner@usgs.gov
and i can set you up.
-john
m567tej
Location: Iranian National Institute for Oceanography and Atmospheric Sciences
Re: swan+roms test
#13 Unread post by m567tej »
dear fereshteh
Do you have any change into roms grid file and make swan files again or no? I ran all four INLET_Test cases without any error. As Warner said, try to run them by 1 processor for ROMS and 1 processor for SWAN. In general, the coupled model can be run only when your number of processor are equal to number of grids*sub_models. Although you can use an unlimited number of processors when you run only ROMS. If you want to run a coupled model with more processors, make mosaic sub-grids and then make swan files for each sub_grid again.
jafar1979
Re: swan+roms test
#14 Unread post by jafar1979 »
dear m567tej
thanks for your kindly reply.
actually i used 1 processor for ROMS and 1 processor for SWAN but that error appear. also i did not make change into ROMS grid file.
i think you use COAWST which has SWAN40.91. is not it? because as Warner said in Rutgers version (SWAN40.51) there is such error
thanks
