For inlet test I have updates its files as suggested in forum. I could compile it but for running, some errors appear. forum has been checked for solving them but its suggestions (for example set 1 cpu for swan) cannot help me therefore I send .log file contains created after run command:
$ Mpirun –np 8 ./oceanG coupling_inlet_test.in>run.log
Coupled Input File name = coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 003
Waves Model MPI nodes: 004 - 007
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
Sunday - October 12, 2013 - 5:00:00 PM
Inlet Test Case
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /home/fkomijani/mpich2/bin/mpif90
Compiler flags : -frepack-arrays -g -fbounds-check -I/home/fkomijani/MCT/include -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script : /home/fkomijani/projects/INLET_test/inlet_test/ocean_inlet_test.in
SVN Revision : exported
Local Root : /home/fkomijani/ROMS/TRUNK
Header Dir : /home/fkomijani/projects/INLET_test/inlet_test
Header file : inlet_test.h
Analytical Dir: /home/fkomijani/ROMS/TRUNK/ROMS/Functionals
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 4, Tiling: 002x002
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
into restart fields.
to standard output.
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idBath) Write out time-dependent bathymetry.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
Physical parameters File: /home/fkomijani/projects/INLET_test/inlet_test/ocean_inlet_test.in
Input Grid File: /home/fkomijani/projects//INLET_test/inlet_test/inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 002x002
tile Istr Iend Jstr Jend Npts
0 1 38 1 35 10640
1 39 75 1 35 10360
2 1 38 36 70 10640
3 39 75 36 70 10360
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 38.50 0.50 35.50 RHO-points
1 38.50 75.50 0.50 35.50 RHO-points
2 0.50 38.50 35.50 70.50 RHO-points
3 38.50 75.50 35.50 70.50 RHO-points
0 1.00 38.50 0.50 35.50 U-points
1 38.50 75.00 0.50 35.50 U-points
2 1.00 38.50 35.50 70.50 U-points
3 38.50 75.00 35.50 70.50 U-points
0 0.50 38.50 1.00 35.50 V-points
1 38.50 75.50 1.00 35.50 V-points
2 0.50 38.50 35.50 70.00 V-points
3 38.50 75.50 35.50 70.00 V-points
HaloSizeI(1) = 150
HaloSizeJ(1) = 144
TileSide(1) = 44
TileSize(1) = 1848
Sediment Parameters, Grid: 01
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
zeta 1 Gradient Closed Gradient Gradient
ubar 1 Gradient Closed Gradient Reduced
vbar 1 Gradient Closed Gradient Reduced
u 1 Gradient Closed Gradient Gradient
v 1 Gradient Closed Gradient Gradient
temp 1 Gradient Closed Gradient Gradient
salt 1 Gradient Closed Gradient Gradient
mud_01 1 Gradient Closed Gradient Gradient
tke 1 Gradient Closed Gradient Gradient
INLET_TEST Inlet Test Case
ANA_SEDIMENT Analytical sediment initial conditions.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR05 Nearshore Radiation Stress Terms (Mellor 2005).
NEARSHORE_MELLOR08 Nearshore Radiation Stress Terms (Mellor 2008).
NONLINEAR Nonlinear Model.
SED_MORPH Allow bottom model elevation to evolve.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
CHECKDEFS - only one radiation stress formulation is allowed.
as you can see there is not any thing that shows swan model is computing.
And also in linux shell this error appears:
MCT::m_MCTWorld::clean_: deallocate(MCTW,...) error, stat =2
That MCT_world.mod located in mct/include directory.
And I get Terminating error: Inputfile missing Message in PRINT and Errfile files.
i need your experience to sort out what cause these problems.
thanks in advance for your attention and guidance
cheers
fereshte
