problems in ROMS tide simulation
baipeng_up
#1 Unread post by baipeng_up »
Hi
I was running a real tide case recent days, and I only provide only 1 tide forcing file for the ROMS, no initial file, no climatory file, also no other foring files. Additionally, I used TPXO7 data for making the tide forcing file. But, the program was always blowing up, and the result seemed to be good when the program had ran for 0.8day,then the result becomed worse and worse. I had tried to smooth the grid file, set the "DT" (in the *.in file) smaller, the program could only run for a few steps further and then still blowing up.
Does anyone get into the same trouble with me?
Here is my *.h configuration:
#define UV_ADV /* Advection of momentum */
#define UV_COR /* Coriolis term */
#define UV_QDRAG /* Use quadratic bottom drag law */
#define UV_VIS2 /* Harmonic mixing of momentum */
#define UV_C4ADVECTION
#define DJ_GRADPS /* Splines Density Jacobian */
#define MIX_S_TS /* Mixing of tracers along constant S-surfaces */
!#define MIX_GEO_TS
#define TS_DIF2 /* Harmonic mixing of tracers */
#define TS_U3HADVECTION /* Third-order upstream horizontal advection of tracers */
#define TS_C4VADVECTION /* Fourth-order centered vertical advection of tracers */
#undef TS_SVADVECTION
#undef TS_MPDATA /* ??? TS_U3HADVECTION TS_C4VADVECTION ??? */
#define SOLVE3D /* Solving 3D Primitive Equations */
#define SALINITY /* Using salinity */
#undef NONLIN_EOS /* Nonlinear Equation of State for seawater */
#undef PROFILE /* Define for time profiling */
#undef SPHERICAL /* Define if lat/lon coordinates rather than x/y */
#undef SPLINES
#define MASKING /* Land/Sea masking */
#undef DIAGNOSTICS_UV /* define if writing out momentum diagnostics */
#undef DIAGNOSTICS_TS /* define if writing out tracer diagnostics */
#define AVERAGES /* ?Define to write out time-averaged model fields */
** Vertical Mixing parameterization
#undef FORWARD_MIXING
#define MY25_MIXING
#undef LMD_MIXING /* Large/McWilliams/Doney interior mixing */
#undef GLS_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX /* LMD diffusivity due to shear instability */
# define LMD_CONVEC /* LMD convective mixing due to shear instability */
# define LMD_SKPP /* KPP surface boundary layer mixing */
# define LMD_NONLOCAL /* LMD convective nonlocal transport */
#if defined GLS_MIXING
# define CHARNOK /* Charnok Surface Roughness From Wind Stress */
# define CRAIG_BANNER /* Craig and Banner Wave Breaking Surface Flux */
# define KANTHA_CLAYSON /* Kantha and Clayson stability function */
# define N2S2_HORAVG /* Horizontal Smoothing of Buoyancy/Shea */
# define CANUTO_A
#if defined MY25_MIXING
# define KANTHA_CLAYSON /* Define for Kantha and Clayson stability function. */
# define K_C2ADVECTION /* Define for 2th-order centered advection. */
# define K_C4ADVECTION /* Define for 4th-order centered advection. */
**Bottom boundary condition settings
#define ANA_BTFLUX /* Analytical kinematic bottom temperature flux */
#define ANA_BSFLUX /* Analytical kinematic bottom salinity flux */
#define ANA_SMFLUX
#define ANA_STFLUX /* Analytical kinematic surface temperature flux */
#define ANA_SSFLUX /* analytical surface salt flux defaults to zero */
#define ANA_INITIAL
**define UV_TIDES to specify boundary tidal currents from data e.g. ADCIRC
** undef UV_TIDES to compute tidal currents using reduced physics
#define SSH_TIDES /* read tidal SSH from file */
#undef UV_TIDES /* read tidal U and V from file */
#define FSOBC_REDUCED
#define ANA_FSOBC
#define ANA_M2OBC
#ifdef SSH_TIDES
# define ADD_FSOBC
#ifdef UV_TIDES
# undef FSOBC_REDUCED /* boundary pg is calculated using bounday zeta */
# define ADD_M2OBC
** Boundary Condition Specifications
#define RADIATION_2D
/* e.g. FSCHAPMAN FSGRADIENT FSRADIATION */
#define EAST_FSCHAPMAN
#define SOUTH_FSCHAPMAN /* Define for a Chapman condition on the free surface */
#define NORTH_FSCHAPMAN
#define WEST_FSCHAPMAN
/* e.g. M2FLATHER M2GRADIENT M2RADIATION */
#define EAST_M2FLATHER
#define SOUTH_M2FLATHER /* Define for a Flather condition on the 2-D momentum */
#define NORTH_M2FLATHER
#define WEST_M2FLATHER
#define EAST_M3RADIATION
#define SOUTH_M3RADIATION /* use if 3D momentum radiation condition*/
#define NORTH_M3RADIATION
#define WEST_M3RADIATION
/* e.g.TRADIATION TGRADIENT */
#define EAST_TRADIATION
#define SOUTH_TRADIATION /* Define for a radiation condition on tracers */
#define NORTH_TRADIATION
#define WEST_TRADIATION
#undef EAST_VOLCONS
#undef SOUTH_VOLCONS /* Define for Southern edge mass conservation enforcement */
#undef NORTH_VOLCONS
#undef WEST_VOLCONS
/* If you define SPONGE or allow for a nudging layer at the boundaries,
** you need to provide the appropriate "ana_hmixcoef.h" and "ana_nudgcoef.h"
** for your application. See examples in ROMS/Func
#undef SPONGE /* Define to use SSH climatology as 2D inflow */
[/color]
Thanks a lot!
Regards.
Re: problems in ROMS tide simulation
If you are using TPXO, why not extract the velocities and use them too?
Many of us have troubles with ROMS, but there's more than one kind of trouble. Where do the fields go bad and how do they look?
geo_ytwin
#3 Unread post by geo_ytwin »
What is the horizontal resolution and minimum water depth of your model? In my experience, increaing the hmin will also help the model integrate forward. In addition, you can try to reduce the resolution in the begining. When the model can run smoothly, then more detailed work is needed to refine the model and optimize the results.
baipeng_up
#4 Unread post by baipeng_up »
geo_ytwin wrote:What is the horizontal resolution and minimum water depth of your model? In my experience, increaing the hmin will also help the model integrate forward. In addition, you can try to reduce the resolution in the begining. When the model can run smoothly, then more detailed work is needed to refine the model and optimize the results.
The horizontal resolution is 1/20° and the minimum water depth "DCRIT" was set to 3.0m.
Tanks for your suggestion, I'll try them later. What's more, I use the EASYGRID for generating the grid file, I set the maximum "r-factor value" to 0.3 in the *.m file, but the "smooth_bath" function can only limit the "r-value" to about 0.37, so I doubt may be the grid file I prepare for the ROMS is bad and could I know what tools do you usually use for generating the "_grd.nc" file? I appreciate it very much for all you replies!
baipeng_up
#5 Unread post by baipeng_up »
kate wrote:If you are using TPXO, why not extract the velocities and use them too?
Tanks for your reply! I just want to see the result only forced by the "Amplitude" and the "Phase",I think we could get a good result only by provide "H" and "g", and I'll add the tide velocities later.
I plot the "Zeta" (free surface height) of the ROMS result, and I can see regular rising-tide and falling-tide pattern at about 0.8day, this pattern will last for about 3 modeling days and then the "Zeta" field lose the regular pattern and become messy, what's more, my model ran for about 11 modeling days totally.
Additionally, I use the EASYGRID for generating the "_grd.nc" file, I set the maximum "r-factor value" to 0.3, but the "smooth_bath" function can not be up to the standard, I doubt may be the grid file is bad, so what tools do you usually use for generating the grid file? I appreciate it very much for all your replies!
#6 Unread post by kate »
But does zeta go bad everywhere or just certain places? What sort of places? Is this a 2-D simulation or could things be going bad in some other way first? Why do you suspect your grid file of being bad?
geo_ytwin
#7 Unread post by geo_ytwin »
Sometimes I use seagrid to generate my grid. Generally, I will directly make my grid by matlab.
Also,roms_tools downloaded from IRD is the toolbox I used.
baipeng_up
#8 Unread post by baipeng_up »
geo_ytwin wrote:Sometimes I use seagrid to generate my grid. Generally, I will directly make my grid by matlab.
Ok, I get it.
Thanks a lot!
baipeng_up
#9 Unread post by baipeng_up »
kate wrote:But does zeta go bad everywhere or just certain places? What sort of places? Is this a 2-D simulation or could things be going bad in some other way first? Why do you suspect your grid file of being bad?
The zeta goes bad everywhere, and I checked the r-value of my grid, the result is too big. I haven't check other variables except zeta yet, I feel that it will be a long way for me to learn ROMS. I re-maked the grid file today, I want to get rid of the problems of the grid first, if the result was still bad, then I'll check other things.
Thanks a lot!
LiuZHQ
#10 Unread post by LiuZHQ »
looks like you're adapting Flahter and Chapman to simulate the tidal current. To me, it is important that we provide tidal current (suggested by Kate) to this sort of OBC in Flather form (an "active" OBC in fact) to include both the tidal current and the tidal wave correctly.
Or, if you insist, use clamp for zeta OBC and radiation for all the other components. But, this kind of setup is bad and I can not grantee the resutls to be reasonable.
ZQ
anthena
#11 Unread post by anthena »
Hi all
When I simulated the tide in Bohai Sea, I confront a problem: the phase of M2 S2 K1 O1 is not good(fig 01), compared to other results(fig NAO_m2),there are large errors. I know the topography and bottom firction are significant to tide. the depth of Bobai Sea is used the newest data ectracted from digital ocean atlas, the boundary condition is forced by 4 tides (M2 S2 K1 O1 )ecactracd from TPX07 tidal data, then modified with NAO99 data, the tidal forcing i checed is right, and i have tried to change the quadratic drag coefficient from 0.0015 to 0.005, the results were no good. I am confused that is there any other parameters needing to change? Give me some advice, please, thank you.
The following is my model setting:
SVN Revision : 671M
Resolution, Grid 01: 0146x0120x014, Parallel Nodes: 6, Tiling: 002x003
100800 ntimes Number of timesteps for 3-D equations.
30.000 dt Timestep size (s) for 3-D equations.
1440 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
120 nHIS Number of timesteps between the writing fields
into history file.
2880 ndefHIS Number of timesteps between creation of new
history files.
1.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.5000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
2.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
6.5000E-04 rdrg Linear bottom drag coefficient (m/s).
4.5000E-03 rdrg2 Quadratic bottom drag coefficient.
1.3000E-02 Zob Bottom roughness (m).
0.0000E+00 Zos Surface roughness (m).
4.5000E+00 theta_s S-coordinate surface control parameter.
6.0000E-01 theta_b S-coordinate bottom control parameter.
3.000 Tcline S-coordinate surface/bottom layer width (m) used
20120428.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
2.0000E+00 obcfac Factor between passive and active
8.000 T0 Background potential temperature (C) constant.
31.000 S0 Background salinity (PSU) constant.
of State.
BOHAI BohaiSeamodeling
ADD_FSOBC Adding tidal elevation to processed OBC data.
ADD_M2OBC Adding tidal currents to processed OBC data.
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_TIDES Add tidal currents to 2D momentum climatologies.
RDRG2=0.003
RDRG2=0.003
others' better result
baipeng_up
#12 Unread post by baipeng_up »
anthena wrote:Hi all
SVN Revision : 671M
to standard output.
into history file.
history files.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
The attachment 01.jpg is no longer available
Hi
From your post I know that your forcing file is generated according to the TPXO7 data. Recently, I was modeling tides of the Beibu Gulf(China), also, I use the TPXO7 data for making the tide forcing file, however the result is unsatisfying, so I checked the forcing file and found that are some abnormal values in some areas, so I suggest you should check your tide foring file first.
anthena
#13 Unread post by anthena »
Hi baipeng_up, I know there are some errors in TPX07,in the model I used the amplitude and phase got from NAO99, but the tidal current components is from TPX07, is this the reason of bas simulation?
baipeng_up
#14 Unread post by baipeng_up »
anthena wrote:Hi baipeng_up, I know there are some errors in TPX07,in the model I used the amplitude and phase got from NAO99, but the tidal current components is from TPX07, is this the reason of bas simulation?
Hi anthena, why not turnning off the "UV_TIDES" in the *.h file and just use the amplitude and phase as the forcing factors, as far as I know, we can get good result by only defining "SSH_TIDES", you could try this, if the result goes fine, you can say the tidal current components derived from TPX07 is bad. Additionaly, you could do more contrast numerical experiment, this will help you figure out the problem.
Chang
#15 Unread post by Chang »
hello baipei_up
i am also runing roms application about bohai sea,i meet the same problem which the result of zeta and velocity is bad due adding tide forcing.can you tell me how you solve it.And can you tell me how to analyze the amplitude and phase of tide according the zeta?could you send me a copy of your program? thank you very much!my email address is 2454518664@qq.com
