River point source salinity
gmaze
#1 Unread post by gmaze »
I know that there have been many posts on this subject and I have gone through them to see if there was already and answer. I did not see one, but I may have just missed it.
I have added rivers into my domain. The bathymetry was created using SeaGrid. I have checked several times to make sure that my river source points are in the correct locations and they are. I am running the code with both salinity and temperature. Both are showing unrealistic values.
The background salinity is 35 and the rivers have a salinity of 30. The maximum final surface salinity is 59.
If you could point me in the proper direction to a solution I would be forever grateful.
ana_psource:
      SUBROUTINE ana_psource (ng, tile, model)
!! svn $Id: ana_psource.h 585 2012-01-03 18:44:28Z arango $
!! Copyright (c) 2002-2012 The ROMS/TOMS Group                         !
!!   Licensed under a MIT/X style license                              !
!!   See License_ROMS.txt                                              !
!  This subroutine sets analytical tracer and mass point Sources       !
!  and/or Sinks.  River runoff can be consider as a point source.      !
      USE mod_param
      USE mod_grid
      USE mod_ncparam
      USE mod_ocean
      USE mod_sources
      USE mod_stepping
      integer, intent(in) :: ng, tile, model
#include "tile.h"
      CALL ana_psource_tile (ng, tile, model,                           &
     &                       LBi, UBi, LBj, UBj,                        &
     &                       IminS, ImaxS, JminS, JmaxS,                &
     &                       nnew(ng), knew(ng), Msrc(ng), Nsrc(ng),    &
     &                       OCEAN(ng) % zeta,                          &
     &                       OCEAN(ng) % ubar,                          &
     &                       OCEAN(ng) % vbar,                          &
#ifdef SOLVE3D
     &                       OCEAN(ng) % u,                             &
     &                       OCEAN(ng) % v,                             &
     &                       GRID(ng) % z_w,                            &
     &                       GRID(ng) % h,                              &
     &                       GRID(ng) % on_u,                           &
     &                       GRID(ng) % om_v,                           &
     &                       SOURCES(ng) % Isrc,                        &
     &                       SOURCES(ng) % Jsrc,                        &
     &                       SOURCES(ng) % Dsrc,                        &
#ifdef SOLVE3D
# if defined UV_PSOURCE || defined Q_PSOURCE
     &                       SOURCES(ng) % Qshape,                      &
     &                       SOURCES(ng) % Qsrc,                        &
# ifdef TS_PSOURCE
     &                       SOURCES(ng) % Tsrc,                        &
     &                       SOURCES(ng) % Qbar)
! Set analytical header file name used.
#ifdef DISTRIBUTE
      IF (Lanafile) THEN
#else
      IF (Lanafile.and.(tile.eq.0)) THEN
        ANANAME(20)=__FILE__
      RETURN
      END SUBROUTINE ana_psource
      SUBROUTINE ana_psource_tile (ng, tile, model,                     &
     &                             nnew, knew, Msrc, Nsrc,              &
     &                             zeta, ubar, vbar,                    &
#ifdef SOLVE3D
     &                             u, v, z_w,                           &
     &                             h, on_u, om_v,                       &
     &                             Isrc, Jsrc, Dsrc,                    &
#ifdef SOLVE3D
     &                             Qshape, Qsrc,                        &
# ifdef TS_PSOURCE
     &                             Tsrc,                                &
     &                             Qbar)
      USE mod_param
      USE mod_parallel
      USE mod_scalars
#ifdef SEDIMENT
      USE mod_sediment
#ifdef DISTRIBUTE
      USE distribute_mod, ONLY : mp_bcastf, mp_bcasti
      USE distribute_mod, ONLY : mp_collect, mp_reduce
!  Imported variable declarations.
      integer, intent(in) :: LBi, UBi, LBj, UBj
      integer, intent(in) :: IminS, ImaxS, JminS, JmaxS
      integer, intent(in) :: nnew, knew
      integer, intent(in) :: Msrc
      integer, intent(out) :: Nsrc
#ifdef ASSUMED_SHAPE
      integer, intent(inout) :: Isrc(:)
      integer, intent(inout) :: Jsrc(:)
      real(r8), intent(in) :: zeta(LBi:,LBj:,:)
      real(r8), intent(in) :: ubar(LBi:,LBj:,:)
      real(r8), intent(in) :: vbar(LBi:,LBj:,:)
# ifdef SOLVE3D
      real(r8), intent(in) :: u(LBi:,LBj:,:,:)
      real(r8), intent(in) :: v(LBi:,LBj:,:,:)
      real(r8), intent(in) :: z_w(LBi:,LBj:,0:)
      real(r8), intent(in) :: h(LBi:,LBj:)
      real(r8), intent(in) :: on_u(LBi:,LBj:)
      real(r8), intent(in) :: om_v(LBi:,LBj:)
      real(r8), intent(inout) :: Dsrc(:)
      real(r8), intent(inout) :: Qbar(:)
# ifdef SOLVE3D
      real(r8), intent(inout) :: Qshape(:,:)
      real(r8), intent(inout) :: Qsrc(:,:)
#  endif
#  ifdef TS_PSOURCE
      real(r8), intent(inout) :: Tsrc(:,:,:)
#  endif
#else
      integer, intent(inout) :: Isrc(Msrc)
      integer, intent(inout) :: Jsrc(Msrc)
      real(r8), intent(in) :: zeta(LBi:UBi,LBj:UBj,3)
      real(r8), intent(in) :: ubar(LBi:UBi,LBj:UBj,3)
      real(r8), intent(in) :: vbar(LBi:UBi,LBj:UBj,3)
# ifdef SOLVE3D
      real(r8), intent(in) :: u(LBi:UBi,LBj:UBj,N(ng),2)
      real(r8), intent(in) :: v(LBi:UBi,LBj:UBj,N(ng),2)
      real(r8), intent(in) :: z_w(LBi:UBi,LBj:UBj,0:N(ng))
      real(r8), intent(in) :: h(LBi:UBi,LBj:UBj)
      real(r8), intent(in) :: on_u(LBi:UBi,LBj:UBj)
      real(r8), intent(in) :: om_v(LBi:UBi,LBj:UBj)
      real(r8), intent(inout) :: Dsrc(Msrc)
      real(r8), intent(inout) :: Qbar(Msrc)
# ifdef SOLVE3D
      real(r8), intent(inout) :: Qshape(Msrc,N(ng))
      real(r8), intent(inout) :: Qsrc(Msrc,N(ng))
#  endif
#  ifdef TS_PSOURCE
      real(r8), intent(inout) :: Tsrc(Msrc,N(ng),NT(ng))
#  endif
!  Local variable declarations.
      integer :: Npts, NSUB, is, i, j, k, ised
      real(r8) :: Pspv = 0.0_r8
      real(r8), save :: area_east, area_west
      real(r8) :: cff, fac, my_area_east, my_area_west
#if defined DISTRIBUTE && defined SOLVE3D
      real(r8), dimension(Msrc*N(ng)) :: Pwrk
      real(r8), dimension(2) :: buffer
      character (len=3), dimension(2) :: io_handle
#include "set_bounds.h"
!  Set tracer and/or mass point sources and/or sink.
      IF (iic(ng).eq.ntstart(ng)) THEN
!  Set-up point Sources/Sink number (Nsrc), direction (Dsrc), I- and
!  J-grid locations (Isrc,Jsrc). Currently, the direction can be along
!  XI-direction (Dsrc = 0) or along ETA-direction (Dsrc > 0).  The
!  mass sources are located at U- or V-points so the grid locations
!  should range from 1 =< Isrc =< L  and  1 =< Jsrc =< M.
#if defined MINE
		Nsrc=2
		Dsrc(1)=1.0_r8
		Isrc(1)=76
		Jsrc(1)=64
		Dsrc(2)=0.0_r8
		Isrc(2)=95
		Jsrc(2)=63
#else
        ana_psource.h: No values provided for Nsrc, Dsrc, Isrc, Jsrc.
#ifdef DISTRIBUTE
!  Broadcast point sources/sinks information to all nodes.
        CALL mp_bcasti (ng, iNLM, Nsrc)
        CALL mp_bcasti (ng, iNLM, Isrc)
        CALL mp_bcasti (ng, iNLM, Jsrc)
        CALL mp_bcastf (ng, iNLM, Dsrc)
#if defined UV_PSOURCE || defined Q_PSOURCE
# ifdef SOLVE3D
!  If appropriate, set-up nondimensional shape function to distribute
!  mass point sources/sinks vertically.  It must add to unity!!.
#  ifdef DISTRIBUTE
      Qshape=Pspv
#  endif
      Npts=Msrc*N(ng)
#  if defined SED_TEST1
      DO k=1,N(ng)
        DO is=1,Nsrc
          i=Isrc(is)
          j=Jsrc(is)
          IF (((IstrR.le.i).and.(i.le.IendR)).and.                      &
     &        ((JstrR.le.j).and.(j.le.JendR))) THEN
            IF (ubar(i,j,knew).ne.0.0_r8) THEN
              cff=ABS(u(i,j,k,nnew)/ubar(i,j,knew))
            ELSE
              cff=1.0_r8
            Qshape(is,k)=cff*                                           &
     &                   (z_w(i-1,j,k    )-z_w(i-1,j,k-1)+              &
     &                    z_w(i  ,j,k    )-z_w(i  ,j,k-1))/             &
     &                   (z_w(i-1,j,N(ng))-z_w(i-1,j,0  )+              &
     &                    z_w(i  ,j,N(ng))-z_w(i  ,j,0  ))
#   ifdef DISTRIBUTE
      Pwrk=RESHAPE(Qshape,(/Npts/))
      CALL mp_collect (ng, iNLM, Npts, Pspv, Pwrk)
      Qshape=RESHAPE(Pwrk,(/Msrc,N(ng)/))
#   endif
#  elif defined MINE
      DO is=1,Nsrc
	DO k=1,N(ng)
	  IF (k.le.14) THEN
		Qshape(is,k)=0.0_r8
	  ELSE IF (k.gt.19) THEN
		Qshape(is,k)=1.0_r8
	  ELSE
		Qshape(is,k)=-0.0222_r8 *k*k+k-10.0_r8
#  else
!!  Notice that there is not need for distributed-memory communications
!!  here since the computation below does not have a parallel tile
!!  dependency. All the nodes are computing this simple statement.
      IF (DOMAIN(ng)%NorthEast_Test(tile)) THEN
        DO k=1,N(ng)
          DO is=1,Nsrc
            Qshape(is,k)=1.0_r8/REAL(N(ng),r8)
#  endif
!  Set-up vertically integrated mass transport (m3/s) of point
!  Sources/Sinks (positive in the positive U- or V-direction and
!  viceversa).
# ifdef DISTRIBUTE
      Qbar=Pspv
# if defined MINE
      fac=1.0_r8
      is=1
      Qbar(is)=fac*50.0_r8
	 is=2
	 Qbar(is)=fac*100.0_r8*(-1.0_r8)
#  ifdef DISTRIBUTE
      CALL mp_collect (ng, iNLM, Msrc, Pspv, Qbar)
#  endif
# else
      ana_psource.h: No values provided for Qbar.
# ifdef SOLVE3D
!  Set-up mass transport profile (m3/s) of point Sources/Sinks.
        DO k=1,N(ng)
          DO is=1,Nsrc
            Qsrc(is,k)=Qbar(is)*Qshape(is,k)
#if defined TS_PSOURCE && defined SOLVE3D
!  Set-up tracer (tracer units) point Sources/Sinks.
# if defined MINE
        DO k=1,N(ng)
          DO is=1,Nsrc
            Tsrc(is,k,itemp)=20.0_r8
            Tsrc(is,k,isalt)=30.0_r8
# else
      ana_psource.h: No values provided for Tsrc.
      RETURN
      END SUBROUTINE ana_psource_tile
options:
** svn $Id: mine.h 585 2012-01-03 18:44:28Z arango $
** Copyright (c) 2002-2012 The ROMS/TOMS Group                               **
**   Licensed under a MIT/X style license                                    **
**   See License_ROMS.txt                                                    **
** Options for Upwelling Test.
** Application flag:   MINE
** Input script:       ocean_mine.in
#define UV_LDRAG
#undef  MIX_GEO_UV
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#undef  TS_MPDATA
#undef  TS_DIF4
#undef  MIX_GEO_TS
#define MIX_S_TS
#define WET_DRY
#define SPLINES
#define DIAGNOSTICS_TS
#define DIAGNOSTICS_UV
#define T_PASSIVE
#define TS_PSOURCE
#define UV_PSOURCE
#define DEBUGGING
#define ANA_INITIAL
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_SMFLUX
#define ANA_SPFLUX
#define ANA_BPFLUX
#define ANA_PASSIVE
#define ANA_PSOURCE
#ifdef BULK_FLUXES
# define ANA_WINDS
# define ANA_SRFLUX
# define ANA_TAIR
# define ANA_HUMID
# define ANA_PAIR
# define LONGWAVE /* use Berliand relation */
#else
# define ANA_VMIX
#if defined BIO_FENNEL  || defined ECOSIM || \
    defined NPZD_POWELL || defined NEMURO
# define ANA_BIOLOGY
# define ANA_SPFLUX
# define ANA_BPFLUX
# define ANA_SRFLUX
#if defined NEMURO
# define HOLLING_GRAZING
# undef  IVLEV_EXPLICIT
#ifdef BIO_FENNEL
# define CARBON
# define DENITRIFICATION
# define BIO_SEDIMENT
# define DIAGNOSTICS_BIO
#ifdef PERFECT_RESTART
# undef  AVERAGES
# undef  DIAGNOSTICS_BIO
# undef  DIAGNOSTICS_TS
# undef  DIAGNOSTICS_UV
# define OUT_DOUBLE
final salinity, surface
final salinity, vertical profile
gmaze
Re: River point source salinity
#2 Unread post by gmaze »
I have changed the vertical mixing to use MY25_MIXING and it has improved somewhat. The vertical profile looks like it should, but the surface temperature and salinity values are still more extreme than they should be.
