#969 closed defect (Fixed)
VERY IMPORTANT: Mixed precision for Split 4D-Var
Reported by: arango Owned by:
Keywords: Cc:
Description
A few routines were updated to allow compiling and running split 4D-Var with mixed precision.
The split 4D-Var algorithms (like RBL4DVAR_SPLIT) recommend the mixed precision approach to accelerate computations. The executing script (see submit_split_rbl4dvar.sh) uses multiple ROMS executables, which runs the outer loop in double precision (nonlinear background trajectory, prior) and single precision in the inner loops (tangent linear and adjoint minimization, increment phase).
In this update, several of the variables needed by the RPCG solver are declared in double precision to reduce the impact of rounding error and the convergence of the minimization algorithm (rpcg_lanczos.F) when computing dot-products and Ritz eigenvalues and eigenvectors.
We use the real(dp) to declare specific internal variables in such cases. For example, in rpcg_lanczos.F, we have:
!  Local variable declarations.
      logical :: Ltrans, Laug
      integer :: i, ic, j, iobs, ivec, Lscale, info
      real(dp) :: zbet, eps, preducv, preducy
      real(dp) :: Jopt, Jf, Jmod, Jdata, Jb, Jobs, Jact, cff
      real(dp), dimension(NinnLoop) :: zu, zgam, zfact, ztemp3
      real(dp), dimension(NinnLoop) :: ztemp1, ztemp2, zu1, zu2
      real(dp), dimension(NinnLoop) :: ztemp4
      real(dp), dimension(Ndatum(ng)+1) :: px, pgrad, zw, zt
      real(dp), dimension(Ndatum(ng)+1) :: zhv, zht, zd
      real(dp), dimension(Ninner,3) :: zwork
      real(dp), dimension(2*(NinnLoop-1)) :: work
      real(dp), dimension(Ninner,Ninner) :: zgv
Many thanks to Pariza Heidary (NOAA) and Julia Levin for bringing this to my attention.
Change History (1)
comment:1 by arango, 12 months ago
Resolution: Fixed
Status: newclosed
