#956 closed upgrade (Done)
Important: Added YAML Parser Test
Reported by: arango Owned by:
Keywords: Cc:
The YAML Parser (ROMS/Utility/yaml_parser.F) requires features of the Fortran 2003 standard and some elements of the Fortran 2008 standard, available in modern compilers. In the past, we have reports of Users having issues compiling with older versions of gfortran or incomplete implementation of the Object-Oriented Programming (OOP) principles from the 2003 standard. Therefore, a standalone program is added (ROMS/Programs/yaml_parser_test.F) to test the compilers.
To compile and link, use the following:
ifort -o yaml_parser_test.x yaml_parser_test.F
gfortran -o yaml_parser_test.x yaml_parser_test.F
Then, to execute, use:
> yaml_parser_test.x
 Enter YAML filename:  ../../ESM/coupling_esmf.yaml
 Enter YAML filename:  ../../ESM/roms_cmeps.yaml
 Enter YAML filename:  ../External/varinfo.yaml
The YAML tree dictionary and extraction are written to standard output.
Examine that program if you are interested in modern OOP Fortran code that uses CLASS objects, inheritance, and other advanced capabilities. Unfortunately, modern Fortran does not use templates like C++. Maybe they will considered in the future.
For example, for roms_cmeps.yaml, I get:
 Enter YAML filename: roms_cmeps.yaml
YAML Tree Dictinary, file: 'roms_cmeps.yaml'
L=0001 % convention: CF
L=0002 % project: FV3-ROMS CMEPS couping in the WATL Application
L=0003 % title: Hurricane Dorian Test
L=0004 % date: 2019-08-29T00:00:00Z
L=0005 % forecast_length: PT96H
L=0006 % coupling_step: 180.0d0
L=0007 % linked_grid: 1
L=0008 % ATM_component: FV3
L=0009 % DATA_component: data.nc
L=0010 % OCN_component: ROMS
L=0011 % CoupledSet: ESM_01
L=0012 % ExportState: Export_ESM_01
L=0013 % ImportState: Import_ESM_01
L=0014 % PETlayoutOption: 0
L=0015 % CouplingType: 2
L=0016 % DebugLevel: 1
L=0017 % TraceLevel: 0
L=0018 % standard_input:
L=0019 %   OCN_component: roms_watl.in
L=0020 %   ATM_component: namelist
L=0021 % state variables: [sea_surface_height_above_geoid, barotropic_sea_water_x_velocity, barotropic_sea_water_y_velocity, sea_water_x_velocity, sea_water_y_velocity, sea_water_potential_temperature, sea_water_practical_salinity]
L=0022 % export:
L=0023 %   - standard_name: sea_surface_temperature
L=0024 %     long_name: sea surface temperature
L=0025 %     short_name: SST
L=0026 %     data_variables: [temperature, time]
L=0027 %     source_units: C
L=0028 %     destination_units: K
L=0029 %     source_grid: cell_center
L=0030 %     destination_grid: cell_center
L=0031 %     add_offset: 273.15d0
L=0032 %     scale: 1.0d0
L=0033 %     debug_write: false
L=0034 %     connected_to: ROMS
L=0035 %     map_type: mapnstod
L=0036 %     map_norm: none
L=0037 % import:
L=0038 %   - standard_name: net_downward_shortwave_flux_at_sea_water_surface
L=0039 %     long_name: surface net shortwave radiation flux
L=0040 %     short_name: SWrad
L=0041 %     data_variables: [swrad, time]
L=0042 %     source_units: W m-2
L=0043 %     destination_units: W m-2
L=0044 %     source_grid: cell_center
L=0045 %     destination_grid: cell_center
L=0046 %     add_offset: 0.0d0
L=0047 %     scale: 1.0d0
L=0048 %     debug_write: false
L=0049 %     connected_to: FV3
L=0050 %     map_type: mapbilnr
L=0051 %     map_norm: none
L=0052 %   - standard_name: surface_air_pressure
L=0053 %     long_name: surface air pressure
L=0054 %     short_name: Pair
L=0055 %     data_variables: [pmsl, time]
L=0056 %     source_units: N m-2
L=0057 %     destination_units: mb
L=0058 %     source_grid: cell_center
L=0059 %     destination_grid: cell_center
L=0060 %     add_offset: 0.0d0
L=0061 %     scale: 1.0d0
L=0062 %     debug_write: false
L=0063 %     connected_to: FV3
L=0064 %     map_type: mapbilnr
L=0065 %     map_norm: none
L=0066 %   - standard_name: surface_downward_heat_flux_in_sea_water
L=0067 %     long_name: surface net heat flux
L=0068 %     short_name: shflux
L=0069 %     data_variables: [shf, time]
L=0070 %     source_units: W m-2
L=0071 %     destination_units: Celsius m s-1
L=0072 %     source_grid: cell_center
L=0073 %     destination_grid: cell_center
L=0074 %     add_offset: 0.0d0
L=0075 %     scale: 1.0d0
L=0076 %     debug_write: false
L=0077 %     connected_to: FV3
L=0078 %     map_type: mapbilnr
L=0079 %     map_norm: none
L=0080 %   - standard_name: surface_upward_water_flux
L=0081 %     long_name: surface freshwater flux (E-P)
L=0082 %     short_name: swflux
L=0083 %     data_variables: [swf, time]
L=0084 %     source_units: kg m-2 s-1
L=0085 %     destination_units: kg m-2 s-1
L=0086 %     source_grid: cell_center
L=0087 %     destination_grid: cell_center
L=0088 %     add_offset: 0.0d0
L=0089 %     scale: 1.0d0
L=0090 %     debug_write: false
L=0091 %     connected_to: FV3
L=0092 %     map_type: mapbilnr
L=0093 %     map_norm: none
L=0094 %   - standard_name: surface_downward_x_stress
L=0095 %     long_name: surface eastward wind stress
L=0096 %     short_name: sustr
L=0097 %     data_variables: [taux, time]
L=0098 %     source_units: N m-2
L=0099 %     destination_units: m-2 s-2
L=0100 %     source_grid: cell_center
L=0101 %     destination_grid: left_right_edge
L=0102 %     add_offset: 0.0d0
L=0103 %     scale: 1.0d0
L=0104 %     debug_write: false
L=0105 %     connected_to: FV3
L=0106 %     map_type: mapbilnr
L=0107 %     map_norm: none
L=0108 %   - standard_name: surface_downward_y_stress
L=0109 %     long_name: surface northward wind stress
L=0110 %     short_name: svstr
L=0111 %     data_variables: [tauy, time]
L=0112 %     source_units: N m-2
L=0113 %     destination_units: m-2 s-2
L=0114 %     source_grid: cell_center
L=0115 %     destination_grid: lower_upper_edge
L=0116 %     add_offset: 0.0d0
L=0117 %     scale: 1.0d0
L=0118 %     debug_write: false
L=0119 %     connected_to: FV3
L=0120 %     map_type: mapbilnr
L=0121 %     map_norm: none
L=0122 % bulk_fluxes import:
L=0123 %   - standard_name: net_downward_shortwave_flux_at_sea_water_surface
L=0124 %     long_name: surface shortwave radiation flux
L=0125 %     short_name: SWrad
L=0126 %     data_variables: [swrad, time]
L=0127 %     source_units: W m-2
L=0128 %     destination_units: W m-2
L=0129 %     source_grid: cell_center
L=0130 %     destination_grid: cell_center
L=0131 %     add_offset: 0.0d0
L=0132 %     scale: 1.0d0
L=0133 %     debug_write: false
L=0134 %     connected_to: FV3
L=0135 %     map_type: mapbilnr
L=0136 %     map_norm: none
L=0137 %   - standard_name: surface_net_downward_longwave_flux
L=0138 %     long_name: surface downward longwave radiation flux
L=0139 %     short_name: dLWrad
L=0140 %     data_variables: [lwrad_down, time]
L=0141 %     source_units: W m-2
L=0142 %     destination_units: W m-2
L=0143 %     source_grid: cell_center
L=0144 %     destination_grid: cell_center
L=0145 %     add_offset: 0.0d0
L=0146 %     scale: 1.0d0
L=0147 %     debug_write: false
L=0148 %     connected_to: FV3
L=0149 %     map_type: mapbilnr
L=0150 %     map_norm: none
L=0151 %   - standard_name: surface_air_pressure
L=0152 %     long_name: surface air pressure
L=0153 %     short_name: Pair
L=0154 %     data_variables: [pmsl, time]
L=0155 %     source_units: N m-2
L=0156 %     destination_units: mb
L=0157 %     source_grid: cell_center
L=0158 %     destination_grid: cell_center
L=0159 %     add_offset: 0.0d0
L=0160 %     scale: 1.0d0
L=0161 %     debug_write: false
L=0162 %     connected_to: FV3
L=0163 %     map_type: mapbilnr
L=0164 %     map_norm: none
L=0165 %   - standard_name: surface_air_temperature
L=0166 %     long_name: surface (2m) air temperature
L=0167 %     short_name: Tair
L=0168 %     data_variables: [tsfc, time]
L=0169 %     source_units: K
L=0170 %     destination_units: C
L=0171 %     source_grid: cell_center
L=0172 %     destination_grid: cell_center
L=0173 %     add_offset: -273.15d0
L=0174 %     scale: 1.0d0
L=0175 %     debug_write: false
L=0176 %     connected_to: FV3
L=0177 %     map_type: mapbilnr
L=0178 %     map_norm: none
L=0179 %   - standard_name: surface_relative_humidity
L=0180 %     long_name: surface relative humidity
L=0181 %     short_name: Qair
L=0182 %     data_variables: [rhumidity, time]
L=0183 %     source_units: percent
L=0184 %     destination_units: fraction
L=0185 %     source_grid: cell_center
L=0186 %     destination_grid: cell_center
L=0187 %     add_offset: 0.0d0
L=0188 %     scale: 0.01d0
L=0189 %     debug_write: false
L=0190 %     connected_to: FV3
L=0191 %     map_type: mapbilnr
L=0192 %     map_norm: none
L=0193 %   - standard_name: precipitation_flux
L=0194 %     long_name: precipitation rate
L=0195 %     short_name: rain
L=0196 %     data_variables: [rainfall, time]
L=0197 %     source_units: kg m-2 s-1
L=0198 %     destination_units: kg m-2 s-1
L=0199 %     source_grid: cell_center
L=0200 %     destination_grid: cell_center
L=0201 %     add_offset: 0.0d0
L=0202 %     scale: 1.0d0
L=0203 %     debug_write: false
L=0204 %     connected_to: FV3
L=0205 %     map_type: mapbilnr
L=0206 %     map_norm: none
L=0207 %   - standard_name: surface_eastward_wind
L=0208 %     long_name: surface eastward wind
L=0209 %     short_name: Uwind
L=0210 %     data_variables: [uwind, time]
L=0211 %     source_units: m s-1
L=0212 %     destination_units: m s-1
L=0213 %     source_grid: cell_center
L=0214 %     destination_grid: cell_center
L=0215 %     add_offset: 0.0d0
L=0216 %     scale: 1.0d0
L=0217 %     debug_write: false
L=0218 %     connected_to: FV3
L=0219 %     map_type: mapbilnr
L=0220 %     map_norm: none
L=0221 %   - standard_name: surface_northward_wind
L=0222 %     long_name: surface northward wind
L=0223 %     short_name: Vwind
L=0224 %     data_variables: [vwind, time]
L=0225 %     source_units: m s-1
L=0226 %     destination_units: m s-1
L=0227 %     source_grid: cell_center
L=0228 %     destination_grid: cell_center
L=0229 %     add_offset: 0.0d0
L=0230 %     scale: 1.0d0
L=0231 %     debug_write: false
L=0232 %     connected_to: FV3
L=0233 %     map_type: mapbilnr
L=0234 %     map_norm: none
Coupling Metadata Dictionary, key: 'export',
============================  File: roms_cmeps.yaml
    short_name:           SST
    data_netcdf_variable: temperature
    data_netcdf_time:     time
    source_units:         C
    add_offset:            2.73150000E+02
    scale:                 1.00000000E+00
    debug_write:          F
    connected:            T
    connected_to:         ROMS
    map_type:             mapnstod
    map_norm:             none
Coupling Metadata Dictionary, key: 'import',
    short_name:           SWrad
    data_netcdf_variable: swrad
    source_units:         W m-2
    add_offset:            0.00000000E+00
    debug_write:          F
    connected:            T
    connected_to:         FV3
    map_type:             mapbilnr
    map_norm:             none
    short_name:           Pair
    data_netcdf_variable: pmsl
    source_units:         N m-2
    debug_write:          F
    connected:            T
    connected_to:         FV3
    map_type:             mapbilnr
    map_norm:             none
    short_name:           shflux
    data_netcdf_variable: shf
    source_units:         W m-2
    debug_write:          F
    connected:            T
    connected_to:         FV3
    map_type:             mapbilnr
    map_norm:             none
    short_name:           swflux
    data_netcdf_variable: swf
    debug_write:          F
    connected:            T
    connected_to:         FV3
    map_type:             mapbilnr
    map_norm:             none
    short_name:           sustr
    data_netcdf_variable: taux
    source_units:         N m-2
    debug_write:          F
    connected:            T
    connected_to:         FV3
    map_type:             mapbilnr
    map_norm:             none
    short_name:           svstr
    data_netcdf_variable: tauy
    source_units:         N m-2
    debug_write:          F
    connected:            T
    connected_to:         FV3
    map_type:             mapbilnr
    map_norm:             none
Change History (1)
comment:1 by arango, 21 months ago
Description: modified (diff)
Resolution: Done
Status: newclosed
