Opened 2 years ago
Closed 23 months ago
#951 closed upgrade (Done)
IMPORTANT: Option VAR_RHO_2D in the TLM, RPM, and ADM
Priority: | major | Milestone: | Release ROMS/TOMS 4.2 |
Component: | Nonlinear | Version: | 4.1 |
Description
The option VAR_RHO_2D activates the baroclinic pressure gradient response to the perturbation of the free surface in the presence of stratification and bathymetry. This option does not pass the sanity check of the tangent linear (TLM) and adjoint (ADM) models. Thus, in globaldefs.h we had the constraint,
#ifdef SOLVE3D # if !(defined ADJOINT || defined TANGENT) # define VAR_RHO_2D # endif #endif
which also affects the nonlinear kernel. This constraint is removed, and we use VAR_RHO_2D_NOT_YET in the TLM, RPM, and ADM kernels instead. Removing this term can be considered part of the linearization.
Note:
See TracTickets
for help on using tickets.
