Opened 2 years ago
Closed 2 years ago
#948 closed upgrade (Done)
IMPORTANT: Updated ROMS standard input files and build script
Priority: | major | Milestone: | Release ROMS/TOMS 4.2 |
Component: | Nonlinear | Version: | 4.1 |
Description
- This update includes the changes discussed in src:ticket:945 to ROMS input scripts (roms_*.in), build scripts (build_roms.* and cbuild_roms.*), and metadata file varinfo.yaml.
- The makefile was updated to rename of macro SCRATCH_DIR to BUILD_DIR. Code was added for backward compatibility with old make configuration files (Compilers/*.mk):
BUILD_DIR ?= Build_roms # Backward compatability with old build scripts and make configuration # files (*.mk). The BUILD_DIR macro is preferred. ifdef SCRATCH_DIR BUILD_DIR := $(SCRATCH_DIR) else SCRATCH_DIR := $(BUILD_DIR) endif
- Similarly, the make configuration in Compilers/*.mk were updated to rename macro SCRATCH_DIR to BUILD_DIR.
- Corrected spelling in the source code documentation. We need to use Charnock instead. However, the roughness variable is still charnok_alpha, and the CPP option is still CHARNOK.
- Added the logical switch for implicit omega in read_phypar.F:
# ifdef OMEGA_IMPLICIT IF (Hout(idOvil,ng)) WRITE (out,170) Hout(idOvil,ng), & & 'Hout(idOvil)', & & 'Write out omega implicit vertical velocity.' # endif
Note:
See TracTickets
for help on using tickets.
