Opened 2 years ago
Closed 23 months ago
#946 closed bug (Fixed)
SetFillVal argument missing when writing vertical coordinates
Reported by: | wilkin | Owned by: | |
Priority: | minor | Milestone: | Release ROMS/TOMS 4.2 |
Component: | Nonlinear | Version: | 4.1 |
- The variables associated with depth are special in ROMS because of wetting/drying and other algorithms. We cannot add a _FillValue in output NetCDF files. Although the output variables z_rho, z_u, z_v, and z_w are defined with SetFillVal = .FALSE. in module def_his.F, the same optional variable is missing when writing in wrt_his.F and wrt_quick. For example, we need to have in wrt_his.F instead:
! ! Write time-varying depths of RHO-points. ! IF (Hout(idpthR,ng)) THEN scale=1.0_dp gtype=gfactor*r3dvar status=nf_fwrite3d(ng, model, HIS(ng)%ncid, & & HIS(ng)%Vid(idpthR), & & HIS(ng)%Rindex, gtype, & & LBi, UBi, LBj, UBj, 1, N(ng), scale, & # ifdef MASKING & GRID(ng) % rmask, & # endif & GRID(ng) % z_r, & & SetFillVal = .FALSE.) IF (FoundError(status, nf90_noerr, __LINE__, MyFile)) THEN IF (Master) THEN WRITE (stdout,10) TRIM(Vname(1,idpthR)), HIS(ng)%Rindex END IF exit_flag=3 ioerror=status RETURN END IF END IF
To avoid those land values being read in MATLAB as 1e+37. Those variables were written correctly in wrt_dai.F, which is used for EnKF and 4D-Var.
- Corrected typo in def_his.F when defining implicit omega vertical velocity.
- Updated metadata varinfo.yaml to include omega_implicit and added scale factor 1/rho0 for wave dissipation variables.
Change History (1)
comment:1 by , 23 months ago
Resolution: | → Fixed |
Status: | new → closed |
Summary: | _FillValue attribute for coordinates z_rho etc. → SetFillVal argument missing when writing vertical coordinates |
Note:
See TracTickets
for help on using tickets.
