Opened 2 years ago
Closed 2 years ago
#940 closed bug (Fixed)
Important: Corrected the state indices counters
Priority: | major | Milestone: | Release ROMS/TOMS 4.2 |
Component: | Nonlinear | Version: | 4.2 |
Description ¶
- Corrected conflict with the state variables counters for isMtke and isWvel. In mod_ncparam.F, we now have:
! ! Set IDs for state some state variables. ! ic=5 #ifdef SOLVE3D DO i=1,MT ic=ic+1 isTvar(i)=ic END DO # if defined GLS_MIXING || defined MY25_MIXING ic=ic+1 isMtke=ic # endif ic=ic+1 isWvel=ic #endif #if defined ADJUST_WSTRESS || defined FORCING_SV || \ defined HESSIAN_FSV || defined SO_SEMI || \ defined STOCHASTIC_OPT isUstr=ic+1 isVstr=ic+2 ic=ic+2 #endif #ifdef SOLVE3D # if defined ADJUST_STFLUX || defined FORCING_SV || \ defined HESSIAN_FSV || defined SO_SEMI || \ defined STOCHASTIC_OPT DO i=1,MT ic=ic+1 isTsur(i)=ic END DO # endif #endif
The state variables indices (order is necessary). Currently, the maximum number of state variables in 3D applications is 9+2*MT. If MT=2 (temperature and salinity), the state variables have the following order:1, 2, 3,4,5, 6, 7, 8,9, 10, 11, 12, 13 zeta,ubar, vbar,u,v,Tvar(1),Tvar(2),TKE,W,Ustr,Vstr,Tsur(1),Tsur(2)
Many thanks to John Warner for bringing this issue to my attention.
- Provided more information in mod_param.F for state variables lateral boundary conditions indices to the LBC structure:
#ifdef SOLVE3D nLBCvar=5+MT ! zeta, ubar, vbar, u, v, Tvar(1:MT) # if defined GLS_MIXING || defined MY25_MIXING nLBCvar=nLBCvar+1 ! TKE # endif #else nLBCvar=3 ! zeta, ubar, vbar #endif
- The state variables in mod_scalars.F are allocated as vectors of size 9+2*MT.
Change History (1)
comment:1 by , 2 years ago
Resolution: | → Fixed |
Status: | new → closed |
Version: | 4.1 → 4.2 |
Note:
See TracTickets
for help on using tickets.
