Opened 2 years ago
Closed 2 years ago
#938 closed bug (Fixed)
VERY IMPORTANT: Update CMake and corrected bug
Reported by: arango Owned by:
Priority: major Milestone: Release ROMS/TOMS 4.1
Component: Nonlinear Version: 4.0
Keywords: Cc:
  • Updated CMake flags for GNU (Compilers/compiler_flags_GNU_Fortran.cmake) and Intel (Compilers/compiler_flags_Intel_Fortran.cmake) compilers.
  • Update the information in Compilers/roms_compiler_flags.cmake to ROMS BUILD TYPE, ROMS COMPILER FLAGS, and internal macro my_fflags.
  • Corrected bug ESM/coupling_esmf.yaml, ESM/coupling_esmf_coamps.yaml, and ESM/coupling_esmf_wrf.yaml. We need the extrapolation_method to have a value of nearest instead of none. By default, the ESMF/NUOPC library needs the specification of the regrid and extrapolation methods in all the import and export fields:
     - standard_name:       downward_shortwave_flux_at_sea_water_surface
        long_name:           surface downward shortwave radiation flux
        short_name:          dSWrad
        data_variables:      [dswrad, time]
        source_units:        W m-2
        destination_units:   W m-2
        source_grid:         cell_center
        destination_grid:    cell_center
        add_offset:          0.0d0
        scale:               1.0d0
        debug_write:         false
        connected_to:        *ATM                                   # swdown
        regrid_method:       bilinear
        extrapolate_method:  nearest
    Many thanks to Fernando Pareja for bringing this to my attention.
Change History (1)
comment:1 by arango, 2 years ago
Description: modified (diff)
Resolution: Fixed
Status: newclosed
Summary: VERY IMPORTANT: Consolidation and refactoring of ROMS repositories to GitHubVERY IMPORTANT: Update CMake and corrected bug
Type: upgradebug
