Opened 18 years ago
Closed 18 years ago
#89 closed bug (Fixed)
Small adjoint bug and few typos
Component: | Adjoint | Version: | 3.1 |
Description ¶
The routine step3d_uv.F assigns the value of local variable AK(i,N(ng)) twice. This reassigment is redundant in the nonlinear, tangent linear, and representer model and doesn't affect the results. However, this constitutes a bug in the adjoint model since reassigments are added twice.
There is also few typos associated with 4DVAR adjustement of surface forcing fields in routines ad_wrt_his.F, tl_wrt_his.F, and cost_grad.F. Many thanks to Gregoire Broquet for reporting these typos.
The routine step2d_LF_AM3.h has an unnecessary specification of I_RANGE and J_RANGE when updating rzeta. This is not a bug. Similar cleaning is done in the TLM, RPM, and ADM versions of this routine.
Corrected a bug in nemuro.h when computing zooplankton egestion. Many thanks to Al Hermann for reporting this bug.
Change History (1)
comment:1 by , 18 years ago
Resolution: | → Fixed |
Status: | new → closed |
Summary: | Small adjoint bug → Small adjoint bug and few typos |
